jpx(at)qenesis.com Guest
Posted: Sun Nov 18, 2007 8:38 am Post subject: Radio interlock |
I had interesting plans to install my com antennas on each wing to
keep them farther apart. The idea was that two pilots could each use
one of the radios simultaneously - say to talk with ATC and FSS (as
opposed to merely monitoring the second channel).
An avionics tech I talked with recently said there was no way to
transmit simultaneously. The intense field strength produced by one
radio transmitting would damage the receive section of the other
radio. Thus there is a lockout connection wired between the radios,
so that the non-transmitting radio grounds its antenna as self
protection while the other transmits.
This sounds quite logical and valid, but I have no pinouts for radios
to confirm this is indeed the case.
True ??
Jeff Page
Dream Aircraft Tundra #10
mprather(at)spro.net Guest
Posted: Sun Nov 18, 2007 9:41 am Post subject: Radio interlock |
Huh.. Sounds logical, but I recently got a ride in a Pilatus that had a
comm system that allowed talking/receiving on two different frequencies at
the same time. I was talking to an FBO on the unicom while the pilot was
talking to the SLC approach controller. Not sure how they make that work,
but it seemed to be okay. Possibly each receiver was being relayed-out
while the other transmitter was operating and I just didn't notice it.
Matt-
True ??
Jeff Page
BobsV35B(at)aol.com Guest
Posted: Sun Nov 18, 2007 9:55 am Post subject: Radio interlock |
Good Morning Matt,
Every air carrier aircraft I ever flew that was equipped with VHF Communication radios allowed simultaneous use of both transmitters. My WAG would be that it is, and was, a matter of proper spacing of the antennas.
I wonder if an antenna on the top of a metal airplane would interfere with one on the belly? My Bonanza Has such an arrangement, but I have never attempted simultaneous use of the radios.
Inquisitive minds want to know!
Happy Skies,
Old Bob
AKA
Bob Siegfried
Ancient Aviator
Stearman N3977A
Brookeridge Air Park LL22
Downers Grove, IL 60516
630 985-8503
In a message dated 11/18/2007 11:43:55 A.M. Central Standard Time, mprather(at)spro.net writes:
| Quote: | Huh.. Sounds logical, but I recently got a ride in a Pilatus that had a
Matt-
See what's new at AOL.com and Make AOL Your Homepage.
rjquillin
Posted: Sun Nov 18, 2007 10:01 am Post subject: Radio interlock |
At 08:35 11/18/2007, you wrote:
Anetnna separation is indeed a factor, but not the only one. Small
A/C inherently have a more difficult time due to the difficulties
encountered in achieving separation. Small composite or fabric makes
it even more difficult due to the lack of metal ground plane
area. OTOH, large metal A/C can take advantage of both separation,
as well as the RF shadow created by the ground referenced skin, and
place antennae on the top and bottom; thus achieving both separation
and shielding. This type of an installation can be quiet effective
for satisfactory, simultaneous com usage.
| Quote: | The idea was that two pilots could each use
This is a supported function, split, on at least some of the PS audio
panels, with caveats mentioned above perhaps necessary for a
successful outcome.
| Quote: | An avionics tech I talked with recently said there was no way to
Some radios do have an interlock function to prevent inadvertent
transmissions from one interfering with reception on the other. This
is an option, not a requirement, and not all radios or audio panels
have this 'feature'.
| Quote: | This sounds quite logical and valid, but I have no pinouts for radios
True ??
Jeff Page
Ron Q.
Posted: Sun Nov 18, 2007 10:05 am Post subject: Radio interlock |
Just another thought.
My recollection is that we were told to avoid transmitting on the same frequency that the other radio was receiving. Other than that caution, I recall no difficulties involved.
Happy Skies,
Old Bob
AKA
Bob Siegfried
Ancient Aviator
Stearman N3977A
630 985-8503
In a message dated 11/18/2007 11:57:30 A.M. Central Standard Time, BobsV35B(at)aol.com writes:
| Quote: | Every air carrier aircraft I ever flew that was equipped with VHF Communication radios allowed simultaneous use of both transmitters. My WAG would be that it is, and was, a matter of proper spacing of the antennas.
mlas(at)cox.net Guest
Posted: Sun Nov 18, 2007 7:43 pm Post subject: Radio interlock |
Jeff,
We use more then one VHF transmitter on the airliners all the time. I
have used both VHF transmitters on my Lancair at the same time with only
36" between antennas without a problem.
Mike Larkin
nuckolls.bob(at)cox.net Guest
Posted: Sun Nov 18, 2007 8:23 pm Post subject: Radio interlock |
At 11:35 AM 11/18/2007 -0500, you wrote:
Not true. Depending on the quality of the receivers
in each radio, the "listening" transceiver may be
overloaded by an adjacent "talking" radio but the further
apart they are in frequency of interest, you may be able
to carry on dual conversations. I've never found it
necessary to "protect" a non-transmitting radio from
one that is transmitting.
( -Thomas Paine 1776- )
Posted: Sun Nov 18, 2007 9:08 pm Post subject: Radio interlock |
Thanks Bob.. That jogged my memory. The real challenge would be to run
multiple transceivers through a single antenna..
Matt-
<nuckolls.bob(at)cox.net>
fvalarm(at)rapidnet.net Guest
Posted: Sun Nov 18, 2007 11:06 pm Post subject: Radio interlock |
If transmitting simultaneously on two radios was dangerous for the radios,
why would the high end audio panels allow this?
Bevan
Posted: Mon Nov 19, 2007 6:33 am Post subject: Radio interlock |
At 10:02 PM 11/18/2007 -0700, you wrote:
That CAN be done. It's most commonly accomplished with
carefully crafted filters that go in series with the antenna
feedlines for each radio. A good example of this technology
is a critter called a "duplexer".
Back in the days when I was working with amateur radio repeater
stations, it was useful have a single antenna for both
RECEIVING an exceedingly tiny incoming signal (0.5 microvolts)
on one frequency while simultaneously TRANSMITTING that same
information on a second frequency (typically 600 KHz removed from
receive) with a strength on the order of 50 volts or 10 million
times stronger!
I've built the device shown here several times:
http://www.repeater-builder.com/rbtip/2mduplexer.html
The thing is built of pieces of 4" copper tubing. The
six cavities are distributed with three in the transmitter
antenna line, three in the receiver. They are crafted with
mirror image band-pass/band-reject response curves
shown here:
http://www.repeater-builder.com/pix/dupfig15.jpg
Note that each cavity set strongly rejects one
frequency while strongly passing another. With these
devices properly crafted and tuned to match the
frequencies of the transmitter and receiver, full
duplex operation of the two devices can be accomplished
on one antenna.
Obviously, this technology is useful ONLY for one
pair of frequencies. For example, I could craft a
duplexer to allow a pair of transceivers to use
a single antenna on 119.5 and 121.6 . . . but as
soon as I rotated set the frequencies to any other
combination, this finely tuned isolation between
the two transceivers would be lost. The other down
side of this technology is that the duplexer would use
up most of your baggage compartment!
gmcjetpilot
Posted: Mon Nov 19, 2007 7:13 pm Post subject: Radio interlock |
| Quote: | From: Jeff Page <jpx(at)qenesis.com>
Subject: Radio interlock
Do you really need it? I fly two crew planes and we rarely if ever are chatting on two radios at the some time, even though we have 4 radios.
I think one antenna on top of the plane and bottom would be a better separation than wing tips. G
Be a better pen pal. [quote][b]
Posted: Mon Nov 19, 2007 10:24 pm Post subject: Radio interlock |
Thanks for the numerous replies and comments to my question concerning
transmitting simultaneously with two radios.
Unanimously everyone said it can be made to work, with the usual
caveats of mounting the antennas with sufficient spacing, etc.
I was also pointed to commercial audio panels that offer this configuration.
So I am back to planning this and will report back in a couple of
years when my airplane is flying to indicate how it all worked out.
Meanwhile, there is a particular avionics tech's advice I will be
ignoring from here on !
Thanks !
Jeff Page
Posted: Tue Nov 20, 2007 6:37 am Post subject: Radio interlock |
| Quote: | >I had interesting plans to install my com antennas on each wing to
use >one of the radios simultaneously - say to talk with ATC and
FSS (as >opposed to merely monitoring the second channel).
Yes. When flying in the USA, I am often trying with difficulty to
raise FSS so I can open my flight plan immediately after takeoff.
This is a high workload time, since I am watching for other traffic
near the airport and also contacting departure to get flight
following. With two pilots and two radios, one can talk with ATC and
the other to FSS.
Top and bottom would be better separation, but I will be installing
amphibious floats, so I am concerned that the wires and floats will
interfere with the radio (assuming I don't manage to break the antenna
off by accident).
Jeff Page
bicyclop(at)pacbell.net Guest
Posted: Tue Nov 20, 2007 10:32 pm Post subject: Radio interlock |
Bob Archer used to sell (and probably still does) an antenna switch
which allows for reception on two radios simultaneously and locks out
the non-transmitting radio (whichever one it is) upon closing the PTT of
either.
Pax,
Ed Holyoke
Robert L. Nuckolls, III wrote:
> <mprather(at)spro.net>
times stronger!
shown here:
on one antenna.
Posted: Wed Nov 21, 2007 4:05 pm Post subject: Radio interlock |
At 10:23 PM 11/20/2007 -0800, you wrote:
Bob Archer used to sell (and probably still does) an antenna switch which
allows for reception on two radios simultaneously and locks out the
non-transmitting radio (whichever one it is) upon closing the PTT of either.
Now, THAT'S a different set of circumstances and design
goals. Here there is acknowledgment of risk to a receiver
from a transmitter's output for DIRECTLY paralleled transceivers
on a single antenna. This is a very useful alternative to the
dual antenna installation where it's acceptable to have
the non-transmitting transceiver become unusable while
talking on the other.
