PROBLEM. Electrical Grounding with a primed airframe.
Geoff Heap
PostPosted: Thu Nov 22, 2007 1:11 pm    Post subject: PROBLEM. Electrical Grounding with a primed airframe. Reply with quote
I could use some advice or comment. Over the years, as I built my airframe I primed everything just before riveting/assembly. With the knowledge I have now that seems dumb. With the battery behind the passenger seat how can I ground it back there. All airframe parts are isolated from each other electrically. Will the rivets help me out? Would they give me the continuity I need? Do I need to run a ground wire all the way back to the engine block?
Lost in Lindenwold
912/dynon 180/icom-a210/garmin 296.
Tim Juhl
PostPosted: Thu Nov 22, 2007 2:54 pm    Post subject: Re: PROBLEM. Electrical Grounding with a primed airframe. Reply with quote
The idea of running two cables and having a common ground point is a good one. That said, the large number of rivets used in your plane's construction should provide ample continuity for ground return for lights, strobes, etc.
______________
CFII
Champ L16A flying
Zodiac XL - Jabiru 3300A
Almost done! It'll fly in spring!
larry(at)macsmachine.com
PostPosted: Thu Nov 22, 2007 3:38 pm    Post subject: PROBLEM. Electrical Grounding with a primed airframe. Reply with quote
Geoff,
I don't think you have a lot to worry about if you have but a small
amount of sandpaper
or Scotch Brite. The link below shows the tray and base I used to get a
ground via the
cross support. Probably a dozen rivets involved, but you see the ground
for both batteries
and I've never had any difficulty with the back feed or connections.
Much easier to change
batteries this way as well. check out the link.
http://www.macsmachine.com/images/electrical/full/chargebatteryconnection.gif
Lost in Lindenwold
http://forums.matronics.com/viewtopic.php?p=147968#147968
Afterfxllc(at)aol.com
PostPosted: Thu Nov 22, 2007 4:39 pm    Post subject: PROBLEM. Electrical Grounding with a primed airframe. Reply with quote
I ran 2 wires and grounded to the engine Mount. My battery is also behind the seat. I don't like the idea of using the airframe as the main grounding point. If the plane didn't have a starter it would be fine but it does so I think 2 wires is the way to go.
This was a rough pic of the battery and not finished but you get the idea.
In a message dated 11/22/2007 4:12:45 P.M. Eastern Standard Time, stol10(at)comcast.net writes:
--> Zenith-List message posted by: "Geoff Heap" <stol10(at)comcast.net>
  Lost in Lindenwold
Check out AOL Money & Finance's list of the hottest products and top money wasters of 2007.
 Filesize:  14.61 KB
 Viewed:  694 Time(s)
bryanmmartin
PostPosted: Thu Nov 22, 2007 4:43 pm    Post subject: PROBLEM. Electrical Grounding with a primed airframe. Reply with quote
You should run a separate ground cable from the battery negative
terminal to the engine block. Don't rely on the chassis ground to carry
the starting current to the engine.
On my plane, my battery is behind the passenger seat. I have a 4 gauge
wire from the negative terminal to a brass bolt passing though the
firewall. On the front side of the firewall a 4 gauge wire continues
from the brass bolt to the engine block. I also have a common grounding
terminal block at the point where the brass bolt passes through the
firewall. I got the brass bolt and terminal block from B & C Specialty
Products.
Lost in Lindenwold
Bryan Martin
Zenith 601XL N61BM
Ram Subaru, Stratus redrive
Bryan Martin
do not archive.
bryanmmartin
PostPosted: Thu Nov 22, 2007 4:47 pm    Post subject: PROBLEM. Electrical Grounding with a primed airframe. Reply with quote
firewall. On the front side of the firewall, a 4 gauge wire continues
firewall. Most of my ground wires connect to this terminal block. I got
the brass bolt and terminal block from B & C Specialty Products.
Lost in Lindenwold
Bryan Martin
Zenith 601XL N61BM
Bryan Martin
do not archive.
dougsnash(at)yahoo.com
PostPosted: Thu Nov 22, 2007 6:04 pm    Post subject: PROBLEM. Electrical Grounding with a primed airframe. Reply with quote
Hey Geoff, I'm going to go a little farther than
everyone else in saying, run a groundwire for
everything. Don't rely on the airframe for grounding
at all. Yes this is more work now but it is still
easier than trying to track down a bad ground
somewhere later on. It is especially important to
ground the strobes well as this will help eliminate
the zot, zot, zot in your headset as they run.
Personally, I have a bunch of the buss bar terminal
strips that Wicks sells on order. I am going to have
a power buss and a return buss for everything. Of
course I'm only building a day/night VFR equipped
CH-701 so the additional weight of the extra grouond
wire should not be excessive. If someone were building
a more complicated panel they might want to save the
weight. But if that were the case, ,they would also
be looking for the redundancy as well.
Maybe I'm a little paranoid about the grounding issues
but I chase electrons for a living and they can be
tricky little devils at times.
Best of luck with your project.
Doug MacDonald
Industrial Electronics Tech.
CH-701 Scratch Builder
Fuse on gear, working on wings
NW Ontario, Canada.
> Lost in Lindenwold
Never miss a thing. Make Yahoo your home page.
http://www.yahoo.com/r/hs
Geoff Heap
PostPosted: Fri Nov 23, 2007 5:06 am    Post subject: Re: PROBLEM. Electrical Grounding with a primed airframe. Reply with quote
As usual everyone came through. Thanks for the help. This is why I send Matt Draille 60 bucks every year. I have to go with the majority. I'm sure I wont regret having a better electrical system.
Now the question becomes. How close can I have these two cables to each other? I'm assuming it would be a problem running them side by side....Geoff
PostPosted: Fri Nov 23, 2007 7:12 am    Post subject: PROBLEM. Electrical Grounding with a primed airframe. Reply with quote
I run both of them on the right side and tuck them into the trim below the canopy arm. Then run the ground to the engine mount and then ground the mount to the engine. I also run the starter relay on the inside of the firewall so the only high voltage that passes thru the firewall is when the starter is engaged.
Jeff
In a message dated 11/23/2007 8:08:02 A.M. Eastern Standard Time, stol10(at)comcast.net writes:
http://forums.matronics.com/viewtopic.php?p=148043#148043
dredmoody(at)cox.net
PostPosted: Fri Nov 23, 2007 10:44 am    Post subject: PROBLEM. Electrical Grounding with a primed airframe. Reply with quote
The rivets ought to do the job. To test whether or not you have continuity through the airframe, use a charged battery and a long jumper wire (14 - 16 AWG). Clip the jumper wire to the formed head of a rivet the rear of the fuselage. Connect the other end of the wire to one lead of a multimeter and check continuity to some part of the airframe near the firewall. If you don't have decent continuity, you may have to install a ground buss back in the aft section and run a heavy wire (12 - 14 AWG) all the way back to the firewall area ground buss.
All my airframe parts have been either primed or primed and painted as I assembled the plane and I have continuity through out my airframe so I doubt that you'll have a problem.
Dred
PostPosted: Fri Nov 23, 2007 10:47 am    Post subject: PROBLEM. Electrical Grounding with a primed airframe. Reply with quote
Good for lights..... not good for the strobes, strobe driver, or electrical motors. Those tend to be electrically noisy and should have a dedicted shielded ground wire with the shield grounded at one end as near the engine as possible.
Dred
PostPosted: Fri Nov 23, 2007 11:00 am    Post subject: PROBLEM. Electrical Grounding with a primed airframe. Reply with quote
Might be good to run them as a twisted pair. Electronic gurus on the list can confirm or correct.
Dred
steveadams
PostPosted: Sat Nov 24, 2007 10:40 am    Post subject: Re: PROBLEM. Electrical Grounding with a primed airframe. Reply with quote
I don't know if you follow Bob Nucholls stuff in the Aeroelectric section, but this topic has come up there numerous times. I'm no electrical expert so I can only say what I have done and what experts like Bob have recommended. Basically with an aluminum airframe there is no reason to run a ground cable forward to the firewall. There is enough contact with the rivets, even if everything is primed, to provide an ample path for the electrons to flow. You'll find more resistance in a 2 G cable than you'll see in the airframe. You can also safely ground pitot heat, landing lights, and position lights locally.
s.c.richards(at)homecall.
PostPosted: Mon Nov 26, 2007 2:45 am    Post subject: PROBLEM. Electrical Grounding with a primed airframe. Reply with quote
Hi Geoff
In Rays 601 HD we ran two cables 4AWG together under
left longeron section below canopy, negative ground bolted to shelf in front
of fire wall with strap to engine & a wire to common panel ground. Master
Contactor near battery in rear. Did not fancy starting current passing
though rivets. The avionics alternative feed was fed from a small fuse near
battery. Other circuits we ran a + & - together Intercom & aerial cables we
ran on right hand side
Should have used 2 AWG to reduce volts drop but this is heavy. so
we keep the battery float charged & it starts OK.
G CBDG Continental 0-200 179 Hrs
Clive
billmileski
PostPosted: Mon Nov 26, 2007 7:20 am    Post subject: Re: PROBLEM. Electrical Grounding with a primed airframe. Reply with quote
I have a 701 with a 912S, and a battery behind the access panel in the bottom of the rear fuse. The battery is grounded to the airframe nearby, with a ring lug and AN3, with primer cleaned off with thinner first. Even with the old 912 starter (not new high torque one) the engine spins up quickly at start, year-round, and I would think this is preferable to the weight and complexity of the additional ground cable.
The strobe power supplies are at the wing tips, and their +12V power wires are unshielded. The output to the strobes, however, is shielded, which seems to make sense, as this is the high voltage transient signal. That said, I do hear a very slight whine of the power supplies charging, in the headsets.
Bill Mileski
Ledyard, CT
701 912S 114hrs
