		vetdrem
				 Posted: Tue Nov 27, 2007 3:05 pm    Post subject: taxy with the wings folded |
				I sure hope that this isn't viewed as a REALLY stupid question, but, here goes.
 Can a Kitfox be taxied with the wings folded?  It sure would make the trip from my hanger to the runway a lot easier.  I don't know if the differential braking would snap the tail wheel out of the detents and allow turns or not.
 Please be kink, I'm sensitive.
 vetdrem
  |  | - The Matronics Kitfox-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
		Float Flyr
				 Posted: Tue Nov 27, 2007 4:17 pm    Post subject: taxy with the wings folded |
				With the extra weight on the tail wheel I personally wouldn't try it.  Also
 if the tail spring breaks you will also lose your wings.
 Noel
 [quote] --
  _________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
		josandt(at)verizon.net Guest
		LarryM
				 Posted: Tue Nov 27, 2007 5:13 pm    Post subject: Re: taxy with the wings folded |
				I concur with Noel.
 Larry
		Tom Jones
				 Posted: Tue Nov 27, 2007 5:35 pm    Post subject: Re: taxy with the wings folded |
				Vetdrem, I'll be kind,
 When I think about taxing with the wings folded all kinds of reasons not to come to mind.  The weight on the tail spring is a major deterrent.
 I take it that between your hangar and the runway there are obstructions to spreading the wings?  I would invest in a four wheel motorcycle, an old pickup, riding lawnmower, utility trailer, anything I could set the tail wheel on with the wings folded and tow it out there.
  _________________ Tom Jones
Classic IV
Ellensburg, WA |
		temco(at)telusplanet.net Guest
				 Posted: Tue Nov 27, 2007 5:50 pm    Post subject: taxy with the wings folded |
 I think what the writer probably meant was ""please be kind I'm sensitive""
 meaning that don't flame me as I'm just asking a question that some may
 perceive to be a silly.
 DO NOT ARCHIVE
 Hope that helps.
 Ted Palamarek
 Kitfox IV - 912
 Edmonton, Ab
		Guy Buchanan
				 Posted: Tue Nov 27, 2007 8:46 pm    Post subject: taxy with the wings folded |
				At 03:05 PM 11/27/2007, you wrote:
  	  | Quote: | 	 		  I sure hope that this isn't viewed as a REALLY stupid question, but,
 here goes.
 OMIGAWD, that is the STUPIDEST question I ever heard! I CAN'T believe
 you asked it.   (We entertain all questions here, even ones you may
 think are stupid. And we frequently give stupid answers. By the way,
 I actually didn't think it was a very stupid question. You'll have to
 try a lot harder.)
 Of course a Kitfox can be taxied with the wings folded.You'll only be
 able to go straight ahead, and you'll want to be exceedingly careful
 because of the excessive load on the tailwheel, wings, and fuselage,
 but it will taxi just fine. (It won't turn because the flaperons lie
 next to the rudder, preventing it, and subsequently the tail wheel,
 from turning. You could rig the wings to fold partially to a position
 that would allow the rudder full travel and you'd be able to turn.
 You'd then just have to deal with the loads issue.)
 Guy Buchanan
 San Diego, CA
Deceased K-IV 1200
A glider pilot too. |
		MichaelGibbs(at)cox.net Guest
				 Posted: Tue Nov 27, 2007 9:20 pm    Post subject: taxy with the wings folded |
				Guys sez:
  	  | Quote: | 	 		  Of course a Kitfox can be taxied with the wings folded.You'll only
 be able to go straight ahead, and you'll want to be exceedingly
 careful because of the excessive load on the tailwheel, wings, and
 fuselage, but it will taxi just fine.
 I have to respectfully disagree with my esteemed colleague.  I think
 trying to taxi a Kitfox with the wings folded is a really, really bad
 idea.  It seems like a sure-fire way to damage the tail wheel
 assembly, at least, and likely the entire airplane since you won't be
 able to steer.
 Mike G.
 N728KF
 Phoenix, AZ
		Michel
				 Posted: Tue Nov 27, 2007 11:45 pm    Post subject: taxy with the wings folded |
				On Nov 28, 2007, at 2:35 AM, Tom Jones wrote:
  	  | Quote: | 	 		   I take it that between your hangar and the runway there are
  there.
 I was once considering folding my wings, not to taxi but to get easier
 in the hangar. I thought that the best way to manoeuvre the plane would
 then be by building a tail dolly. Imagine a pyramid upside-down, built
 in steel or even wood. On the 'top' a free-castoring wheel. On the
 'base' two holes in which I put a long bolt that goes in the tube used
 for an eventual dorsal fin (at least, on my model 3 - don't know about
 other models). The rest of the 'base' is padded to receive the
 fuselage.
 To put on the dolly, I fix the bolt then lift the tail and the
 'pyramid' goes in an upside-down position.
 The advantages are: It is easier to fold the wings when the plane is
 level; less weight pulling the wings backward. It is then probably
 possible to fold and unfold the wings alone. Next, you don't have to
 remove the fuel that may leak from having the wing folded.
 If one has to taxi that one, one should also consider putting a stopper
 on the pedals so that no pressure is put on the rudder while one is
 still able to 'steer' by differential braking.
 Just a thought.
 Michel Verheughe
 Norway
 Kitfox 3 - Jabiru 2200
		occom
				 Posted: Wed Nov 28, 2007 3:10 am    Post subject: taxy with the wings folded |
				I thought about this and the first thing that came to mind is that you
 likely wont taxi far, and you have to bleed the fuel system before takeoff.
 Most kitfoxes with wings folded have a limited fuel load to keep the vents
 from bleeding fuel. As you fold the wings what fuel there is tends to move
 away from the pickups, so you may be running on the header tank only and
 introducing air.
 People who actually have FLYING Kitfoxes may find this is wrong, it's just
 the way I figured it would turn out.
 Dave Goddard- Mod IV 1050/582
		dave
				 Posted: Wed Nov 28, 2007 5:17 am    Post subject: Re: taxy with the wings folded |
				I few of my thoughts on the "idea"
 I would not want to travel with  folded wings without wing root braces.
 Then you have to fold out your wings and possibly would have missing hardware that you forgot, hence a trip back to hangar.
 Heavy load on tail wheel spring.
 Lack of being able to have full fuel tanks.
 End of flapperons come into cabin and might hit you in back of head?
 Where you going to put turtle deck ?
 If Controlled airport -- might be an issue trying to get a clearance to unfold your wings on taxiway.?
 Basically I have no idea why anyone would to do this, perhaps you could advise us of the reason you ask to do this ? If there an issue  of taxing with wings folded?  Your Kitfox wings are likely 10 times or more stronger  rigged than folded, alot of strain  on the rear spar at the first rib.   Besides,  you are better off getting it all rigged and checked over without having the feeling of having to rush .
  _________________ Realtime Kitfox movies to separate  the internet  chatter from the truth
Hundreds of Kitfox Movies
Most viewed Kitfox on youtube
Most popular on youtube
Highest rated on youtube |
		Float Flyr
				 Posted: Wed Nov 28, 2007 10:05 am    Post subject: taxy with the wings folded |
				Get an old skidoo and mount tundra tires where the skis are...makes a great
 little tractor.  Without going the power route you could make a dolly for
 the tail wheel.   It should take the load just in front of the tail spring
 and the dolly will need to be able to handle a load of close to 150 lb. To
 give a margin of strength.  Open the wings, temporarily to put the tail up
 on the dolly and to take it down.  You could leave the tail up on the dolly
 in the garage too.
 I think an American Flyer wagon will probably be a bit too light but you can
 build something using old bicycle wheels.  The larger the wheel the easier
 it will be to pull.  Oh yes pulling is easier than pushing.
 Noel
 [quote] --
Kitfox III-A
		Float Flyr
				 Posted: Wed Nov 28, 2007 10:06 am    Post subject: taxy with the wings folded |
				No silly questions in my book.  I'd sooner a person ask than damage his
 plane.
 Noel
 [quote] --
Kitfox III-A
		n85ae
				 Posted: Wed Nov 28, 2007 1:56 pm    Post subject: Re: taxy with the wings folded |
				OK, I haven't been flamed in a while so I'll just blurt it out. I know a lot
 of people are thinking it anyway.
 You're crazy, that is a stupid idea for more reason's than there is time
 in the day to answer. If you reply, with the same question my four year
 old would, which is "why?". Then in my opinion you should be banished
 from the list - Forever.
 Ok, one little elaboration. BECAUSE the next question you'll ask is -
 Can I fly it with the wings folded, sort of like an F-14?
 Ok, I don't text message on the cellphone, but I think the appropriate
 mesg would be ROFLMAO
 Jeff.
		Fox5flyer Guest
				 Posted: Wed Nov 28, 2007 4:49 pm    Post subject: taxy with the wings folded |
				Gee whiz Jeff, you shouldn't sugar coat things so much!
 Deke
 Subject: Re: taxy with the wings folded
  lot
  Jeff.
  http://forums.matronics.com/viewtopic.php?p=149183#149183
		kirkhull(at)kc.rr.com Guest
				 Posted: Wed Nov 28, 2007 5:06 pm    Post subject: taxy with the wings folded |
				Ok you must have some kind of obstruction between the hanger and the runway
 that you cannot pass with the wings out.  That said I would not taxi with
 the wings folded as you have cut the mounting surface in half ( front wing
 bolt removed ) and left the leading edge unsupported.  This could cause a
 twisting force on the wing that it was not designed to take.  In a worst
 case scenario breaking the epoxy joint between the spar and rib in a place
 that is not easily found.  That is just my opinion and I am in no way an
 expert.
		n85ae
				 Posted: Thu Nov 29, 2007 6:50 am    Post subject: Re: taxy with the wings folded |
				Oh, yeah I know, this is the kinder, gentler, more diplomatic version of
 me. Plus it's the holiday season and all.
 OK - Perhaps, there's a reasonable explanation for wanting to taxi with
 wings folded, but it's just too good an opportunity to pass up.
 Jeff
  	  | Fox5flyer wrote: | 	 		  Gee whiz Jeff, you shouldn't sugar coat things so much!
 Deke
		Float Flyr
				 Posted: Thu Nov 29, 2007 2:22 pm    Post subject: taxy with the wings folded |
				Michel:
 I like the idea of your inverted pyramid.  I think you could use the through
 tubes in the frame for the tow bar.  I agree 100% with it being easier to
 fold the wings with the tail up.  It would also be easy to install a tow bar
 (for handling) on the lip of the inverted pyramid.
 As for taxiing with the wings folded ... Not on my plane!  Tail up or down!
 Noel
  	  | Quote: | 	 		   I was once considering folding my wings, not to taxi but to get easier
  fuselage.
  Just a thought.
  Michel Verheughe
  Norway
Kitfox III-A
		Float Flyr
				 Posted: Thu Nov 29, 2007 2:33 pm    Post subject: taxy with the wings folded |
				If you consider yourself flamed, I'll consider myself flamed too.
 Noel
 P.S. Can is expect to gain a bit of airspeed if I fly with the wings
 folded???  Will it affect any VGs???  Lol
 [quote] --
Kitfox III-A
		kitfoxmike
				 Posted: Thu Nov 29, 2007 2:44 pm    Post subject: Re: taxy with the wings folded |
				if you taxi with the wings open, it opens the doors for a lot of fun when there is a bunch of snow on the taxi ways.  Get yourself going and hit one brake and get it sliding sideways, real fun.
