		B747crew
				 Posted: Thu Nov 29, 2007 4:40 pm    Post subject: M14 P TBO |
				I'm wondering if there is an established TBO on the M14P or are there just general guidelines based on inspection/ compressions.
    In addition I"d like to get feedback from the group as to individual experience in terms of service before overhaul did became necessary.
   Thanks very much and thanks to the members of this forum for the exceptional information I find here on a regular basis.
  _________________ Jack Snodgrass
4305 Claridge Ct.
Apex, NC 27539
919-745-7434 |
		cliff(at)gesoco.com Guest
				 Posted: Thu Nov 29, 2007 5:54 pm    Post subject: M14 P TBO |
				The Soviet System required overhaul of the entire aircraft every 500hrs
 or 5 years.
 Engines, being part of the aircraft were subject to the same rules.
 After the forth overhaul the engine was scrapped.
 On the data plate of each engine is a place to stamp the overhaul-
 usually a roman numeral to identify how many overhauls the engine has
 received.
 Motorstar, one of the manufacturers of these engines, has a recommended
 TBO of 1500hrs.
 Like Lycoming and Continental, this is not a guarantee that the engine
 will run to TBO, but *should* be overhauled at this time.
 My experience has found that most engines suffer from old age or mishap
 long before they're worn out.
 Most notably the rubber and non-metallic parts degrade quite rapidly
 after 7-8 years of age.
 The ignition harnesses are very prone to breakdown.
 I recommend replacing the harnesses with BIW 5mm steel core silicone
 wiring.
 We purchase it from Savage Magneto in California.
 I know of two Yak-52TW with more than 650hrs that are running strong.
 so...use it or lose it -grin-
 Cheers,
 Cliff
 B747crew wrote:
  Jack Snodgrass
  4305 Claridge Ct.
  Apex, NC 27539
  808-371-2739
 Clifford Coy
 Director of Maintenance
 Border Air Ltd
 629 Airport Rd.
 Swanton, VT 05488
 802-868-2822 TEL
 802-868-4465 FAX
 Skype: callto:Cliff.Coy <callto:cliff.coy>
				 Posted: Thu Nov 29, 2007 7:23 pm    Post subject: M14 P TBO |
				There is not a published TBO for the M-14 to my knowledge. It generally
 flown for 500 hours with pretty much doing minimal maintenance adding oil
 ect. It then underwent an IRAN at depot where what was out of tolerance was
 replaced.
 Doc
		dsavarese(at)elmore.rr.co Guest
				 Posted: Fri Nov 30, 2007 5:48 am    Post subject: M14 P TBO |
				One must remember though, it did not matter what the condition of the engine
 was at 500 hours.  It was removed regardless and as Doc said, IRAN'd.
 Typical military type requirement.
 There are many stories/rumors that have been passed around over the years
 that tell about an M14 type engine running a power generator or ground power
 unit (or something similar which runs 24-7).  Anyway, as the story goes, the
 engine ran non-stop for 20,000 or was it 30,000 hours with only oil added to
 the engine as required.  Then it was removed and thrown away and another
 engine installed.  BTW, The story came from a very reliable source.  Is it
 possible?  I suppose so.  Pretty far fetched though.  Do I think the M14
 will run for 20,000 hours.  No, I personally don't.  Do I think the M14 will
 run for 1500 or 2000 hours.  Certainly.  If you really want to see a major
 difference in hours/longevity of the M14P, look at an original engine log
 book from a Yak 18T versus one from a Yak 52.  It all depends on how it was
 intended to be used.
 Dennis
		fish(at)aviation-tech.com Guest
				 Posted: Fri Nov 30, 2007 6:56 am    Post subject: M14 P TBO |
				Dennis,
 I beleive the stories. When I was in A&P school, my engine
 instructor was contracted to do maintenance on ground
 generators (constant run type). He found the same thing when
 the engines were shut down after 10-12 years of constant
 running. He checked them and they were put back on line, to
 run for anouther ? long.
 The reason for this is in the thermal expansion. All the
 wear occures during the starting cycle, before they can get
 to operating temp. Once an engine has oil flow, and temp has
 expanded the engine to its fullest. Very little wear will
 occur.
 Also ground based engines are optimised to run at one
 Temp/RPM for max efficiency. Engine tollerances are set to
 use this range.
 If we wanted to run our engines in only one regime (and
 constant) they would also probably last a long time also.
 Fly Safe
 John Fischer
 Yak-52, N213YA
 ----- Original Message Follows -----
 From: "A. Dennis Savarese" <dsavarese(at)elmore.rr.com>
 To: <yak-list(at)matronics.com>
 Subject: Re: M14 P TBO
 Date: Fri, 30 Nov 2007 07:47:53 -0600
  condition of the engine  was at 500 hours.  It was removed
  regardless and as Doc said, IRAN'd.  Typical military type
  requirement.
  over the years  that tell about an M14 type engine running
  a power generator or ground power  unit (or something
  only oil added to  the engine as required.  Then it was
  removed and thrown away and another  engine installed.
  think the M14  will run for 20,000 hours.  No, I
  personally don't.  Do I think the M14 will  run for 1500
  major  difference in hours/longevity of the M14P, look at
  an original engine log  book from a Yak 18T versus one
  from a Yak 52.  It all depends on how it was  intended to
  be used. Dennis
		cjpilot710(at)aol.com Guest
				 Posted: Fri Nov 30, 2007 8:53 am    Post subject: M14 P TBO |
				I got to echo Dennis.
  I am going on my experience only.  The M-14p in my CJ has 1350+ hours  since new, all put on by me.  I have a 10 micron oil filter and have used  only 50 or 60 weight detergent oil.  I've never used multi grade except  when the other stuff was not available.  At 430 hours I had to do a ring  job because the factory had installed a scraper ring where the oil ring should  have been.  So the present rings have over 900 hours on them.  At  present the compressions are even and down to the low 70s.  I can  hear a little air out the breather.  With the except of the ring failure at  430 hours, I've never seen any metal in the filter which I've changed out every  30 to 40 hours along with the oil.
  I still get 34" mp and 2850 rpm (I set the prop governor for that and  perhaps to conservative) for takeoffs here at sea level.  For acro I  need only 32" and 2300 rpm for what I do.  At cruise I use 2000 rpm and 28"  mp until I reach an altitude where the throttle is wide open.  I use that  power setting for climb also.
  Like Craig, I used the smallest accelerator jet I had in the parts  kit.  No problems there.
  Every engine is a product of how it is used.  These engine are  great.  They can take a lot of abuse.  Just like the big engines, if  you "baby" them, they last a lot longer.  On the 1830s we always ALWAY stay  "over square".  We never let the prop drive the engine.  The thrust  bearings and such were designed for the power to drive prop.  For instance  we make our approach in the B-24 using our cruise rpm, 2,000, and never let the  mp drop below 21".   If we fuck-up and are high, the B-24 does  beautiful slip or we will pull the rpm back to 1800 and the mp to 20"  If  we have to go around throttles are advanced to 35" and props than move to  2300.  During the war crews were taught to set the rpm at 2300 on the  downwind leg and use any throttle setting down to idle for the  approach.  But engine were cheap and plentiful.
  The guts of the M-14 are a little beefier compared to the big 1820 and  1830s but the principles are the same.  I try to keep my power over  square as much as possible.
  The best thing to add to any engine particularly a radial, is a  preoiler.  The greatest wear happens during starting.  I read  somewhere it accounts for over 70%.  We have used it on the B-24 for a  number of years and have seen much better engine wear on the B-17 in the last  couple of years since we starting using it on the 1820 which are beefier than  1830.  I have a preoiler on my M-14 and I believe it, the 10 micron filter,  and the way I operate it, is the reason for its longevity.  So far.   :>)
  BTW#2 I watch my fuel flow drop almost  2 g/h by dropping my rpm  way back.
  Didn't old Chuck Lindberge show us how it was done with the troops in  WW2?
  Jim "Pappy" Goolsby
   In a message dated 11/30/2007 8:49:52 A.M. Eastern Standard Time,  dsavarese(at)elmore.rr.com writes:
  [quote]-->    Yak-List message posted by: "A. Dennis Savarese"    <dsavarese(at)elmore.rr.com>
 Dennis
		brian-1927(at)lloyd.com Guest
				 Posted: Fri Nov 30, 2007 11:14 am    Post subject: M14 P TBO |
				On Nov 30, 2007, at 5:47 AM, A. Dennis Savarese wrote:
  	  | Quote: | 	 		   Do I think the M14 will run for 20,000 hours.  No, I personally
  don't.  Do I think the M14 will run for 1500 or 2000 hours.
  Certainly.  If you really want to see a major difference in hours/
  longevity of the M14P, look at an original engine log book from a
 Dennis, I agree with you wholeheartedly. If you want a 2000 hour life
 from an M14P, run it at reduced power. Pull the RPM (%) back and run
 at lower power settings. You will get less wear from the engine.
 Also, fly it straight-and-level at a constant power setting with all
 the temps at their optimum points. Don't do any aerobatics.
 If you work the engine hard and do lots of acro, expect the engine to
 have a shorter life, maybe even 500 hours.
 Remember, a military org wants high dispatch reliability and is
 willing to pay for it, especially if they don't have to "pay" for it.
 Pulling the engine at 500 hours prophylactically pretty much ensures
 that one gets the engine before it has time to develop any problems
 in the field. Fix everything and put it back. It will again run a
 long time with minimal maintenance. We don't have that luxury here so
 we need to keep closer tabs on the internal operations of the engine.
 Of course, one could keep two engines around and swap them every 500
 hours. Pull the NIS engine apart and check everything. Put it back
 together with new bearings, rings, and gaskets. Something to think
 about.
 Brian Lloyd                         3191 Western Drive
 brianl AT lloyd DOT com             Cameron Park, CA 95682
 +1.916.367.2131 (voice)             +1.270.912.0788 (fax)
 PGP key ID:          12095C52A32A1B6C
 PGP key fingerprint: 3B1D BA11 4913 3254 B6E0  CC09 1209 5C52 A32A 1B6C
		wlannon(at)persona.ca Guest
				 Posted: Fri Nov 30, 2007 1:49 pm    Post subject: M14 P TBO |
				As mentioned in a previous post the Ivchenko engines (of which the M14 is a
 derivative) have been used in the oil industry as pump engines running on
 natural gas. In this instance it is quite possible they could run for 20,000
 hrs.
 In years past the RR Merlin was utilized for this function in Canada.
 Running at nowhere near maximum power at constant RPM 24 Hrs per day on
 absolutely clean burning fuel they ran for years. Maybe 100,000 hrs TBO.
 Long since replaced by turbines which probably run forever.
 Walt
				 Posted: Fri Nov 30, 2007 10:22 pm    Post subject: M14 P TBO |
				On Nov 30, 2007, at 12:21 PM, Walter Lannon wrote:
  M14 is a derivative) have been used in the oil industry as pump
  engines running on natural gas. In this instance it is quite
  possible they could run for 20,000 hrs.
  Canada. Running at nowhere near maximum power at constant RPM 24
  Hrs per day on absolutely clean burning fuel they ran for years.
 I know that Allisons were used to do that but I have never heard of a
 Merlin pressed into that service. The Merlin did not have the
 strongest of valve trains and it also had that two-stage blower,
 neither of which was conducive to longevity.
 brian HYPHEN 1927 AT lloyd DOT com    Cameron Park, CA 95682
 — Antoine de Saint-Exupéry
