Fergus Kyle
  Joined: 03 Jun 2007 Posts: 291 Location: Burlington ON Canada
				 Posted: Thu Nov 29, 2007 8:48 pm    Post subject: Harvard/ SNJ/Texan checklists |
				Subject: Harvard/ SNJ/Texan checklists
  This is the memory Vital Action checklist required of every cadet prior to
 presence at "flights" (hangar line training), in the Empire and Commonwealth
 Air Training Plans
  which produced 1/4 million flyers in WW II and 45,000 post war.  There were
 of course variations according to aircraft type and theatre, but I used it
 for most a/c until jets arrived - Lanc, C45, Dak, etc., even the T33.  It is
 generally possible to accomplish these while in formation without looking
 into the cockpit too often. When that's needed the leader usually calls for
 a loosening out.
  B4 T/O - HTMPFFGGS
  HARNESS 	tight, locked
  HOOD	open/closed
  HYDRAULICS	pressure
  TRIM		t/o
  TENSION	tight
  TEMPS,PRESS	in green
  MIXTURE	rich
   CARBHEAT	cold
  PITCH	fine
  FUEL		fullest tank
  FLAPS	takeoff
  GILLS		set
  GYROS	unlocked (not gunsight*)
  SWITCHES	as req'd
  AFTER T/O - BUMPH
  BRAKES	on
  UNDERCART - up
  MIXTURE	climb set
   CARBHEAT	set
  PIITCH 	climb rpm
  HOOD	closed
  INITIAL - UGBUM
  UNDERCART down
  GAS		fullest tank
  BRAKES	test
  UNDERCART 3 green
  MIXTURE	rich
   CARBHEAT	hot check
  FINAL - UPFH
  UNDERCART horn check
  PITCH	fine
  FLAPS	as req'd
  HARNESS	tight,locked
  * applicable only to armament aircraft, ignored elsewhere.
  |  | - The Matronics Europa-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
