Dual battery
william(at)gbta.net
PostPosted: Thu Nov 29, 2007 10:10 pm    Post subject: Dual battery Reply with quote
I'm ready to build my battery box and need to modify it to fit dual battery's. Only problem is that I don't know which battery to use. Any suggestions??? How does one decide on which battery is the "right" battery, and where can I find measurements for these batteries so I know how big to make the tray.
rv(at)thelefflers.com
PostPosted: Fri Nov 30, 2007 3:34 am    Post subject: Dual battery Reply with quote
Bill,
I¨m about ready to do the same.
Most people I believe are using the Odyssey 680.
Pictures of Dan Lloyd¨s solution can be found at:
http://www.myrv10.com/tips/mods/DansBatteryBox/index.html
Bob Condrey¨s can be found at:
http://www.myrv10.com/tips/mods/DualBatteries/Bob_Condreys_Batteries.jpg
Bob¨s solution appears to be the easiest to construct.
Specs are:
PC 680 Specs:
<![if !supportLists]>, <![endif]>Motorcycle / Powersports / Marine / Medium Duty
<![if !supportLists]>, <![endif]>Ahr (amp hours) (at)20 hr. rate 17 Ahr
<![if !supportLists]>, <![endif]>Pulse Discharge (HCA)
<![if !supportLists]>, <![endif]>5 sec. 680 A
<![if !supportLists]>, <![endif]>10 sec. 595 A
<![if !supportLists]>, <![endif]>20 sec. 525 A
<![if !supportLists]>, <![endif]>HCA (at) 80━F (27━C) 370 A
<![if !supportLists]>, <![endif]>CA (at) 32━F (0━C) 300 A
<![if !supportLists]>, <![endif]>CCA 220 A
<![if !supportLists]>, <![endif]>Reserve Capacity (at) 25 A 25 min.
<![if !supportLists]>, <![endif]>Cycle Life (Deep cycle capability) 400 (at) 100% DOD (depth of discharge)
<![if !supportLists]>, <![endif]>500 (at) 80% DOD
<![if !supportLists]>, <![endif]>Temperature Range -40━F (-40━C) to 176━F (80━C)
<![if !supportLists]>, <![endif]>Resistance at 1 kHz (at) 77━F 7m ヘ
<![if !supportLists]>, <![endif]>Short circuit current 1800 A
<![if !supportLists]>, <![endif]>Terminals Female threaded for M6 stainless bolt
<![if !supportLists]>, <![endif]>Max. installation torque 50 in-lb.
DIMENSIONS
<![if !supportLists]>, <![endif]>Length 7 �� in. 7.27 in. 184.7 mm
<![if !supportLists]>, <![endif]>Width 3 1/16 in. 3.11 in. 79.0 mm
<![if !supportLists]>, <![endif]>Height* 6 5/8 in. 6.67 in. 169.4 mm
<![if !supportLists]>, <![endif]>Weight 15.4 lb. 7.0 kg
<![if !supportLists]>, <![endif]>*Height is measure to top of terminal
Other Features
<![if !supportLists]>, <![endif]>2 year replacement warranty in powersports, motorcycle and specialty applications
<![if !supportLists]>, <![endif]>Available with protective metal jacket (PC 680 MJ)
<![if !supportLists]>, <![endif]>Available with non-corrosive, brass automotive terminal or 5/16 ̄ stainless steel stud
<![if !supportLists]>, <![endif]>Can be mounted in any orientation (not recommended for inverted use)
<![if !supportLists]>, <![endif]>12 year design life with 6 to 10 year service life
<![if !supportLists]>, <![endif]>Fully charged out of box
<![if !supportLists]>, <![endif]>2 year shelf life (at) 77━F (25━C)
#40684
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Bill & Tami Britton
Sent: Friday, November 30, 2007 1:12 AM
Subject: Dual battery
__________ NOD32 2694 (20071130) Information __________
rnewman(at)tcwtech.com
PostPosted: Fri Nov 30, 2007 4:34 am    Post subject: Dual battery Reply with quote
<![if !supportLists]><![endif]><![if !supportLists]><![endif]><![if !supportLists]><![endif]><![if !supportLists]><![endif]><![if !supportLists]><![endif]><![if !supportLists]><![endif]><![if !supportLists]><![endif]><![if !supportLists]><![endif]><![if !supportLists]><![endif]><![if !supportLists]><![endif]><![if !supportLists]><![endif]><![if !supportLists]><![endif]><![if !supportLists]><![endif]><![if !supportLists]><![endif]><![if !supportLists]><![endif]><![if !supportLists]><![endif]><![if !supportLists]><![endif]><![if !supportLists]><![endif]><![if !supportLists]><![endif]><![if !supportLists]><![endif]><![if !supportLists]><![endif]><![if !supportLists]><![endif]><![if !supportLists]><![endif]><![if !supportLists]><![endif]><![if !supportLists]><![endif]><![if !supportLists]><![endif]><![if !supportLists]><![endif]><![if !supportLists]><![endif]><![if !supportLists]><![endif]> Here's by dual battery installation. I've built a pair of equipment shelves that attach to the Van's standard battery/ bellcrank center plate.
Regarding the batteries. They are both Panasonic LCR SLA type batteries. The main battery is a 28 Amp-hour. The auxilary battery is a 17 amp-hour type. (although a 20 amp-hour is now available in the exact same size). I've used the 28 amp-hour battery in our Glastar for 3 years now and it has worked very well. When I did my search for batteries I was looking for something equivalent to the Concord battery that's been designed to mount in the RV-10 battery tray (Coincidently this is the same size battery mount used in the Glastar). I found that the Panasonic battery is dimmesionally similar to the Concord battery (about 3/4" shorter in lenght, other dimesions the same) and about 75%or less of the cost. Also the Panasonic batteries were available from many distributors. (including Digi-key) Recently I found the 28 amp hour battery for sale in PartsExpress for $74.50 (www.parts-express.com) although I have not tried to order it from them.
Panasonic 28 amp-hour (6.50x 4.92x 7.07") model# LC-x1228P � Digi-key part # P049-ND $95
Panasonic 17 amp-hour ( 7.12x2.99x6.58" ) model # LC-RD1217P Digi-key part #P174-ND $60
Panasonic 20 amp-hour ( 7.12x2.99x6.58" ) model # LC-x1220P Digi-key part #P231-ND $75
Regrads,
Bob Newman
www.tcwtech.com
 Filesize:  175.07 KB
 Viewed:  397 Time(s)
 Filesize:  185.19 KB
 Viewed:  395 Time(s)
jesse(at)saintaviation.co
PostPosted: Fri Nov 30, 2007 5:12 am    Post subject: Dual battery Reply with quote
Do you have some more close-ups of how you mounted the ends of your table/shelf to the stiffeners and the battery tray? I really like the look of that installation, probably replacing the ELT with the Strobe PS for my needs.
Jesse Saint
Saint Aviation, Inc.
Cell: 352-427-0285
Fax: 815-377-3694
Regrads,
Bob Newman
www.tcwtech.com
<battery area-2.jpg><battery area-1.JPG>
Deems Davis
PostPosted: Fri Nov 30, 2007 5:36 am    Post subject: Dual battery Reply with quote
Bill, I used dual PC 680's
here's a link to some photos :
http://deemsrv10.com/album/Sec%2039%20Control%20System/slides/DSC02860.html
click forward through a series of 6-7 photos.
Deems Davis # 406
'punch' list is down to 2 pages (from 3 1/2)
rnewman(at)lutron.com
PostPosted: Fri Nov 30, 2007 5:49 am    Post subject: Dual battery Reply with quote
Jesse,
I have more photo's of the tray design and mounting. This weekend
I was planning on editing those pictures along with the pictures of side
step bushings I designed and put them up on my web site. I forgot to
put my strobe power supply on the tray, but it's suppose to be on
there. I'll add that and put it up with all the pictures. I will
get to it Saturday and post a link on Sunday. I've been planning a
RV-10 section of my web site for the purpose of showing modifications to
my -10.
Best regards,
Bob Newman
www.tcwtech.com
william(at)gbta.net
PostPosted: Fri Nov 30, 2007 8:16 am    Post subject: Dual battery Reply with quote
Thanks for the information and pictures on the Battery/trays. Bob, I really
like the looks of that accessories tray that you built. If you get some
pictures of it please let me know. This would be a good time to work
something like that into my build. As for the battery tray dimensions, I
think I'll probably go with PC680s. The length is 7.27" and the width is
3.11". Do I need to buy the batteries and build the box to exact dimensions
of the 2 batteries or is it acceptable to just build the tray maybe 1/4"
larger on each side so that I know the batteries will fit later on when I
get them.
Thanks again for all the input,
Bill Britton
planesmith(at)hotmail.com
PostPosted: Fri Nov 30, 2007 1:42 pm    Post subject: Dual battery Reply with quote
Has anyone come up with a way to mount a 7ah�battery up under the insturment panel or on the backside of the firewall? One of the smaller gel cells used in alarm systems seems like a nice backup battery for the EFIS system.
Vern Smith (#324 doors & cabin top)
> From: william(at)gbta.net
[quote] To: rv10-list(at)matronics.com
Subject: Re: Dual battery
Date: Fri, 30 Nov 2007 08:24:58 -0600
--> RV10-List message posted by: "Bill & Tami Britton" <william(at)gbta.net>
get them.
Bill Britton
n212pj(at)gmail.com
PostPosted: Fri Nov 30, 2007 1:46 pm    Post subject: Dual battery Reply with quote
<![if !supportLists]><![endif]><![if !supportLists]><![endif]><![if !supportLists]><![endif]><![if !supportLists]><![endif]><![if !supportLists]><![endif]><![if !supportLists]><![endif]><![if !supportLists]><![endif]><![if !supportLists]><![endif]><![if !supportLists]><![endif]><![if !supportLists]><![endif]><![if !supportLists]><![endif]><![if !supportLists]><![endif]><![if !supportLists]><![endif]><![if !supportLists]><![endif]><![if !supportLists]><![endif]><![if !supportLists]><![endif]><![if !supportLists]><![endif]><![if !supportLists]><![endif]><![if !supportLists]><![endif]><![if !supportLists]><![endif]><![if !supportLists]><![endif]><![if !supportLists]><![endif]><![if !supportLists]><![endif]><![if !supportLists]><![endif]><![if !supportLists]><![endif]><![if !supportLists]><![endif]><![if !supportLists]><![endif]><![if !supportLists]><![endif]><![if !supportLists]><![endif]> Bob, nice. Curious about the materials used for the large shelf and the calculated extra weight.
John Jessen
40328
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Bob-tcw
Sent: Friday, November 30, 2007 4:32 AM
Regrads,
Bob Newman
www.tcwtech.com
PostPosted: Fri Nov 30, 2007 2:05 pm    Post subject: Dual battery Reply with quote
Bill, I'll be editing the pictures I have and putting them up on my
web site this weekend. I'll post the link when it's ready.
_Bob Newman
www.tcwtech.com
>> william(at)gbta.net 11/30/2007 9:24 AM >>>
really
some
I
is
dimensions
1/4"
I
get them.
Bill Britton
Bill Schlatterer
PostPosted: Fri Nov 30, 2007 6:15 pm    Post subject: Dual battery Reply with quote
Vern, this is in my 7 but the same concept probably works in the 10. Battery is suspended directly under the AHRS. The bus right beside it is the Aux Bat which feeds separate switches for the EFIS which allows it to be powered on before/while starting or in an emergency but disconnected from the main bus. The Aux Bat also charges from the main bus during normal operations through a D25 diode. As I remember it, the battery is a Panasonic P212 (7ah) recommended on the AE list.
Hope this helps.
Bill S
7a finishing
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Vernon Smith
Sent: Friday, November 30, 2007 10:43 AM
Subject: RE: Dual battery
Has anyone come up with a way to mount a 7ah battery up under the insturment panel or on the backside of the firewall? One of the smaller gel cells used in alarm systems seems like a nice backup battery for the EFIS system.
[quote] From: william(at)gbta.net
get them.
Bill Britton
 Filesize:  136.87 KB
 Viewed:  372 Time(s)
 Filesize:  101.86 KB
 Viewed:  431 Time(s)
 Filesize:  85.58 KB
 Viewed:  391 Time(s)
Bill Schlatterer
PostPosted: Fri Nov 30, 2007 6:19 pm    Post subject: Dual battery Reply with quote
Forgot this one. It shows the rear and front hold down brackets. On the front, it is just a little plate that is bolted in to hold it in place. Flush rivet on the inside.
Bill S
7a
get them.
Bill Britton
 Filesize:  118.41 KB
 Viewed:  405 Time(s)
PostPosted: Fri Nov 30, 2007 9:04 pm    Post subject: Dual battery Reply with quote
Bill,
This is exactly what I was looking for or something close to it. Originally, I was planning on two equal sized batteries behind the luggage area, but just didn't need that kind of capacity or weight in an Aux battery. Plus I like the idea of the shorter power leads with it mounted near the panel.
Vern
[quote] From: billschlatterer(at)sbcglobal.net
Date: Fri, 30 Nov 2007 20:14:10 -0600
.ExternalClass .EC_hmmessage P {padding-right:0px;padding-left:0px;padding-bottom:0px;padding-top:0px;} .ExternalClass EC_BODY.hmmessage {font-size:10pt;font-family:Tahoma;} Vern, this is in my 7 but the same concept probably works in the 10. Battery is suspended directly under the AHRS.� The bus right beside it is the Aux Bat which feeds separate switches for the EFIS which allows it to be powered on before/while starting or in an emergency but disconnected from the main bus. The Aux Bat also charges from the main bus during normal operations through a D25 diode. � As I remember it, the battery is a Panasonic P212 (7ah) recommended on the AE list.
Hope this helps.
Bill S
7a finishing
Vern Smith (#324 doors & cabin top)�
get them.
Bill Britton
MauleDriver(at)nc.rr.com
PostPosted: Sat Dec 01, 2007 9:18 am    Post subject: Dual battery Reply with quote
Bill, here is my solution for twin Odessey 680s, split buss and dual alternator (Z14).
[url=http://www.mykitlog.com/users/display_log.php?user=MauleDriver&project 24&category 155&log=43554&row=8]http://www.mykitlog.com/users/display_log.php?user=MauleDriver&project 24&category 155&log=43554&row=8[/url]
Thanks to everyone who has documented and posted their installations. I just built my solution on top of everyone who had done one before. This site and community is the best!
Bill "back to building after completing the Dishwasher install from hell - wondering if anyone has homebuilt an aircraft with a head" Watson
#40605
Durham NC
Bill & Tami Britton wrote: [quote] I'm ready to build my battery box and need to modify it to fit dual battery's. Only problem is that I don't know which battery to use. Any suggestions??? How does one decide on which battery is the "right" battery, and where can I find measurements for these batteries so I know how big to make the tray.
