rgf(at)dcn.davis.ca.us Guest
Posted: Fri Nov 30, 2007 2:49 pm Post subject: Looking for advice on Wing and Fuse Kit: QB or Standard |
On Monday December 3 a buddy and I will each order the kits for the -9A, and
of course we must choose between the Quick Build and Standard.
We understand the principle of trading dollars for time, and both of us lean
towards saving time. But we wonder what additional items or things might we
want to do to the fuselage or wing, that would be difficult to do if
starting from the QB? For instance, I might want to extend the fuel tank 4
or 5 gals on each side, and that would be almost impossible to do with the
QB wing.
Or again, I am interested in using a combined pitot tube/angle-of-attack. Is
this much harder to install with a QB wing?
Also, how long have you taken building the Standard wing?
If this has been asked before just point me to the thread....
[Also posted in the VAF ]
Ralph Finch
Davis, California
| - The Matronics RV9-List Email Forum - | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?RV9-List |
streiker
Posted: Fri Nov 30, 2007 3:07 pm Post subject: Looking for advice on Wing and Fuse Kit: QB or Standard |
You said: 'I might want to extend the fuel tank 4 or 5 gals on each
side'
Why? Is there some big mission deviation that you are planning?
Stephen (Steve) Streiker
_________________ Stephen D Streiker |
dthomas773(at)sbcglobal.n Guest
Posted: Fri Nov 30, 2007 3:22 pm Post subject: Looking for advice on Wing and Fuse Kit: QB or Standard |
Ralph,
I would think long, hard and seriously about
redesigning the fuel tanks whether it be QB or
standard kit. I would talk to Van's about tip tanks
first. Actually with an 0-320 engine the 36 gal
provided will give you well over 600 miles and 4 hours
of range.
If you do deside to redesign the wing you could get a
standard wing kit and still order a QB fuselage.
Dennis Thomas
Standard.
difficult to do if
QB wing.
wing?
thread....
Ralph Finch
Davis, California
Click on
about
Admin.
browse
Un/Subscription,
FAQ,
Forums!
rscott(at)cascadeaccess.c Guest
Posted: Fri Nov 30, 2007 3:28 pm Post subject: Looking for advice on Wing and Fuse Kit: QB or Standard |
This may or may not help, but the majority opinion, including from Van's
brother, is that if you can only do one QB kit, do the QB wing and the
slow build fuselage. Next step down in price is to do slow build both,
but order the prebuilt fuel tanks.
My slow build wings probably took me about 500 hrs.; probably a little
slower than most.
I wouldn't bother with more fuel. How often would you use the full fuel
capacity, anyway? The time it takes to enlarge the fuel tanks won't be
offset by the time saved with the longer range unless you fly long
distances most of the time. And by doing so, you negate the engineering
thought that went into the design and enter unknown territory.
Richard Scott
RV-9A Fuselage
QB wing.
Ralph Finch
Davis, California
aurbo(at)ak.net Guest
Posted: Fri Nov 30, 2007 4:48 pm Post subject: Looking for advice on Wing and Fuse Kit: QB or Standard |
Ralph,
Do you want to fly or build? I did the slow build wings and QB fuselage. If I did it again I would do QB for both.
Mike Ice
Cowling just about done
Posted: Fri Nov 30, 2007 4:56 pm Post subject: Looking for advice on Wing and Fuse Kit: QB or Standard |
Ralph
Quote: | From my experience, I can tell you that it is very easy to install the
"angle-of-attack" in the QB wing, at least the one which is now sold by
Advanced Control Systems.
I believe the one from Dynon will be more or less the same.
I also installed a heated pitot tube, from Gretz Aero, and it was very easy
to do it in the QB wing.
Further, if you do both before riveting the bottom skin, which comes in the
QB wing for you to do it, it will be a piece of cake.
Obviously the same cannot be done with your intention to extend the fuel
tanks. In order to do this, you should buy the standard wings; but you still
can buy the QB fuselage...
If money is not a problem, go for the QB!
It will save you a lot of building time and it permits all the changes and
additions you could possibly want, except extending the fuel tanks
Carlos
RV-9A
[quote] --
Posted: Fri Nov 30, 2007 5:14 pm Post subject: Looking for advice on Wing and Fuse Kit: QB or Standard |
Easy: tankering. If you can buy wholesale or have an auto-fuel capable
engine, you can do many mid-range trips both ways without refueling.
An extra 10 gal might not help a lot, but another 20 would certainly be
beneficial.
I bought slow build wings for my -7 kit because I wanted to add fuel
capacity, but in retrospect it wouldn't be that hard to add fuel after
the fact. There's a guy in FL doing 'hired gun' work on Mustang replica
kits. He starts with QB kits, cuts access holes on the bottom of the
leading edge 'D' cells, 'caulks' the joints & shop heads of the rivets &
seals up the holes.
On the -9, it might be even easier. Where are the lightening holes in
the spar, outside the existing tanks? You might be able to reach in
through those holes to seal the joints/rivet heads, then close the
lightening holes with sealed plates. Fuel pickup can go through the
spar, or if you skip a bay, you can put the pickup in the rib just like
the stock tank.
Having added 'wet wing' aux tanks to the -7 wing leading edges, I'm
confident that the technique described above on a QB wing would be a lot
easier and faster than what I did on the slow build wings.
If the -9 QB wing is like the -7 QB, with one of the bottom skins left
for the builder, then any of the other mods should be a non-event.
I don't really want to talk about how many hours I've got in the wings...
Charlie
side'
bill(at)repucci.com Guest
Posted: Fri Nov 30, 2007 5:46 pm Post subject: Looking for advice on Wing and Fuse Kit: QB or Standard |
Ralph,
Having paid myself around $8/hr to assemble my slow build, I would go
quick build, if I were doing it again.
As adding fuel, check out SafeAir1's option:
http://www.safeair1.com/HWA/HWA_Buying_Tanks.htm
Bill
rv9ralph(at)tailsrwaggin. Guest
Posted: Fri Nov 30, 2007 6:23 pm Post subject: Looking for advice on Wing and Fuse Kit: QB or Standard |
If it's more fuel that is your decision hinge point, look at the Hotel
Whisky (marketed by SafeAir1 extended tanks. The put a tubular tank in
the lightening holes of the leading edge ribs from the existing tank to
the tip with a filler in the tip, gets about 1 to 2 hours extended
range. It can easily be retrofitted or you can put the fuel bungs on
your existing tank either in construction or after it is built.
The website is: http://www.safeair1.com/index.htm
Ralph -- wings
Livermore, CA
Bob Perkinson
![](images/avatars/187783528146c31f0b12a13.jpg)
Joined: 10 Jan 2006 Posts: 51 Location: Hendersonville, Tennessee
Posted: Fri Nov 30, 2007 11:15 pm Post subject: Looking for advice on Wing and Fuse Kit: QB or Standard |
Charlie the retro fit on my RV9 wing tanks was fairly straight forward. Sealed up the last 3 outboard bays of the wing added all the necessary hard ware, Level indicators, low point sump, and fuel pick up, and a new filler ring at the wing tip and it came up with 14 gal extra space in each wing. Not that I want to travel around the world but I do want to get back from those long cross countries that terminate at someone’s back yard field with no way to fuel up unless I stop on the way home, I would have to leave earlier. And miss the fun.
Bob Perkinson
RV-9do not archive
[quote]-------------- Original message from Charlie England <ceengland(at)bellsouth.net>: --------------
[quote] --> RV9-List message posted by: Charlie England
beneficial.
seals up th e holes.
the stock tank.
Charlie
Streiker, Stephen D. wrote :
> --> RV9-List message posted by: "Streiker, Stephen D."
> side'
Posted: Sat Dec 01, 2007 3:35 am Post subject: Looking for advice on Wing and Fuse Kit: QB or Standard |
Guys
You are referring to the Hotel Whisky extra tanks, but I want to call your
attention to the fact that they don't have them for the -9.
I don't know why, but every time I ask them (and I've done it in the last 3
years or so), they keep answering that they still don't have the tanks for
the -9.
Maybe you could ask them now...
Let me add that I also think that it should be easy to adapt the tanks which
they sell for the -7 to be used on the -9, but before ordering them I would
like to have the kit in my hands and I am in the other side of the big pond
Carlos Trigo
RV-9A
Portugal
[quote] --
Posted: Sat Dec 01, 2007 8:52 am Post subject: Looking for advice on Wing and Fuse Kit: QB or Standard |
Bob,
Did you talk to Van's or have available to you
engineering support for this change? I would think 84
pounds that far outboard on the wing would seriously
degrade load factor safety margins.
Just curious.
Dennis Thomas
--- bobperk90658(at)bellsouth.net wrote:
[quote] Charlie the retro fit on my RV9 wing tanks was
the fun.
Bob Perkinson
RV-9
without refueling.
> beneficial.
wanted to add fuel
the bottom of the
> seals up the holes.
lightening holes in
able to reach in
can go through the
> the stock tank.
leading edges, I'm
build wings.
be a non-event.
> Charlie
Stephen D."
4 or 5 gals on each
> > side'
you are planning?
Posted: Sat Dec 01, 2007 12:02 pm Post subject: Looking for advice on Wing and Fuse Kit: QB or Standard |
Ralph,
Here are some complications you will encounter if you try this: The
fuel tank skins are thicker than the leading edge skins. The LE skin
feels pretty flimsy by comparison. If you simply seal in the leading
edge for one or 2 rib bays, that little tank won't be as strong as the
regular tank. I don't know if this is a problem. If you want to use
fuel tank skins just for the width of your additional tank area, you
will need to install an extra rib at the outboard end of your tank with
a splice strip; at least that's how the factory joined the tank skin
with the LE skin. And how are you going to cut a prebent skin to get a
nice straight edge so the joint will look good?
Maybe Van's, if you ask nicely, will provide you with a LE skin the
thickness of the tank skin, but I doubt it.
There is no provision in the spar for an additional rib at the joint
between your tank and the LE and I don't know if you could modify it.
You can't just use tank skins full width because the tank skins are an
inch or two shorter than the LE skins. Then you also have to route fuel
and vent lines.
My suggestion? Forget it. The closer you stick to the original design,
the faster the plane will go together, the sooner you will be flying.
Use a fuel injected engine, lean out, throttle back to get range.
After you are flying, then consider maybe a baggage compartment aux tank
like a friend of mine is building. Removable, & he only intends to use
it when flying solo. Estimates 5 gallons. Much simpler concept, no
structural questions. Has to keep it in mid for W&B, however, so he
will mount it up next to the seat back.
Richard Scott
RV-9A Fuselage
QB wing.
Ralph Finch
Davis, California
Bob Perkinson
Posted: Sat Dec 01, 2007 4:03 pm Post subject: Looking for advice on Wing and Fuse Kit: QB or Standard |
Dennis,<?xml:namespace prefix = o ns = "urn:schemas-microsoft-com:office:office" />
I have not personally run the numbers, but I am not the only one that has put a little extra weight out on the wings. Check out this RV-9A
http://www3.telus.net/haywire/RV-9/C-FSTB.htm
When I wrote to Van's they only told me that there had not been any engineering studies preformed on this modification.
I have the option to go without.
Bob Perkinson
[quote]-------------- Original message from <dthomas773(at)sbcglobal.net>: --------------
Quote: | --> RV9-List message posted by:
Bob,
Just curious.
Dennis Thomas
Posted: Sat Dec 01, 2007 9:23 pm Post subject: Looking for advice on Wing and Fuse Kit: QB or Standard |
I'm not an engineer, but people who are tell me that it actually
*improves* load safety margins. (It also degrades spin characteristics,
but that's not what you asked about )
Charlie
dthomas773(at)sbcglobal.net wrote:
Bob,
Just curious.
Dennis Thomas
> the fun.
> Bob Perkinson
> RV-9
> do not archive
> without refueling.
>> beneficial.
> wanted to add fuel
> the bottom of the
>> seals up the holes.
> lightening holes in
> able to reach in
> can go through the
>> the stock tank.
> leading edges, I'm
> build wings.
> be a non-event.
>> Charlie
> Stephen D."
> 4 or 5 gals on each
>>> side'
> you are planning?
Posted: Sat Dec 01, 2007 10:02 pm Post subject: Looking for advice on Wing and Fuse Kit: QB or Standard |
Vans' addressed the issues surrounding adding aux fuel tanks in an
RVAter article sometime in the last 18 months.
Ralph
Wings
Livermore
