		LarryM
				 Posted: Fri Nov 30, 2007 2:35 pm    Post subject: Carb Heat |
				Thought this might be helpful.  Now that winter is upon us, carb ice is less likely, however...
 Carb Heater
 I can’t remember my whole thought process, but it evolved from a fellow listee who used a 15w tail light bulb taped to his carb to successfully defeat carb ice.  Trying to improve from there, I had figured that 20w would provide approximately a maximum of 100F heat to the carb body which would be warm enough without being too hot.  I used NiCrA-30DGL at 30 awg, which is a glass-insulated wire.  I had calculated that 18” of wire would yield 9.8 ohm >20w >1.42amps (per carb).  I initially wanted to wrap the wire around the carb intake, but after concern for the rubber air filter mount and discovering that the aluminum carb conducts the heat so fast, that it did not matter where it was wrapped.  I then wrapped it around the easiest place, in the Bing’s case, around the slide housing.  I used high temperature silicon around the housing, and simply wrapped the wire into it.  I choose to connect it DC on a switch.  It can also be wired AC directly.  I use it as an “ANTI - ice” system, turning it on at engine start whenever conditions are conducive for icing.  It does not create enough heat to wait until ice is present before using it.  This is my personal untried opinion.  It does not degrade engine performance, as the air going in is just as cold, but the water cannot turn to ice because the carb body temp stays above freezing.  If I were to do it again, I would wire it directly to AC and have it always on.  (I keep mine on all of the time anyway)   Having not been plaque by carb ice, I did not do anymore testing.  Though I fly in conditions that the “carb ice chart” will show as being prone, I do not fly in mist, fog, etc.  This conversation does prompt me to further investigate the effectiveness of the heater, but in 2yrs, I haven’t a problem.  I would like to see what my carb body temp is with the heater on while actually flying in cold damp air. More heat requires more wattage/amps and less wire.
    I bought the wire from www.wiretronics.com  (209-296-8460).   They have a downloadable calculator that is real good to check (in my case to teach) things out.  They had a 20’ min order; you only need 18” per carb.  Perhaps someone wants to ‘group order’.  I gave my excess to guys around here who didn’t have any heat system.  You can also use it to make warm gloves, sock, etc.  I think it was about $40.00 total with shipping?
 Hope this helps,
 Larry
  |  | - The Matronics Kitfox-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
		wingnut
				 Posted: Fri Nov 30, 2007 5:16 pm    Post subject: Re: Carb Heat |
				What's the advantage of this over conventional carb heat based on hot air? Also, I might be paranoid but the idea of a light bulb in the vicinity of a carburetor sounds risky to me.
 What motor are you using? I've read that carb heat isn't really necessary on the Rotax 912. Anyone have thoughts on that?
  	  | Quote: | 	 		  |  can’t remember my whole thought process, but it evolved from a fellow listee who used a 15w tail light bulb taped to his carb to successfully defeat carb ice. |
  _________________ Luis Rodriguez
Model IV 1200
Rotax 912UL
Flying Weekly
Laurens, SC (34A) |
		john(at)leptron.com Guest
				 Posted: Fri Nov 30, 2007 6:17 pm    Post subject: Carb Heat |
				Carb heat is necessary on a 912, I have had ice, and it was not fun.
 John Oakley
 Speedster 4
 912ul and cap
		LarryM
				 Posted: Sat Dec 01, 2007 8:21 am    Post subject: Re: Carb Heat |
				Wingnunt,
   I didn't want to go through the hassle of making a carb heat muff, box, control etc.  This is A kind of do it and for get about it.  I always leave it on as there is no performance loss.  It's designed to keep the carb above freezing even when considering the evaporation due the venturi. After a few years, I have had no icing problems.  The 15W light bulb taped to the side of the carb work real good too.
   I don't think that any carb is immune from carb ice.  I had a car that always iced up on me. (British no less - I can imagine how it performed over there with all those days of good carb ice weather)   I had to build a heat muff directed on the carb.  The throttle body on my injected VW van would ice up as well.  The throttle body manufacture had made a system to allow hot water to circulate around it.  No body knew it at the time what it was for.  I finally figured it out after a few times of getting stuck due to ice. It was an imported VW engine from South Africa made for their market and had no use for the anti - ice system, therefor the instructions ignored it and the barbs where plugged)
		darinh
				 Posted: Sat Dec 01, 2007 9:03 am    Post subject: Re: Carb Heat |
				John,
 I never had any problems with ice on my 912 but would never rule it out.  I have read many posts from 912 owners that think that ice is a non-issue as the air intakes are higher in the cowl and should have adequate heat to prevent icing, but I am not so sure.  With my 914, the setup is different, there is a single intake and it is located in the radiator scoop on the bottom of the cowl so I will be getting cold, moist air straight to my carbs.  As you know, here in Utah we have a pretty dry climate but there are a few days a year that are conducive to carb ice.  What are you using for carb heat?
  _________________ Darin Hawkes
Series 7
914 Turbo
Kaysville, Utah |
		occom
				 Posted: Sat Dec 01, 2007 9:19 am    Post subject: Carb Heat |
				I wouldn't be quick to dismiss you idea, on the other hand I doubt if it
 makes much difference. First the carb body is not aluminum as far as I know.
 I believe it's a zinc type pot metal alloy. The second issue is that in a
 very breezy environment I don't think that your wire would effectively
 transfer much heat unless there is a lot of surface contact. It might be
 worth getting a carb temp guage and seeing how effective your setup is.
 I live right where the US gov't comes to test their aircraft in icing
 conditions, and I know a couple of guys who are using 912's without carb
 heat. That might be a bad idea, I just don't know. I'd like the option of
 heat if it was me, but I think the carb heaters that bolt right into the
 body might be a better idea.
 Dave Goddard- Mod IV 1050/582
				 Posted: Sat Dec 01, 2007 9:29 am    Post subject: Carb Heat |
				Darin,
 I have the carb box that was a stock system on the model 4. I have had ice
 twice, both times in a bad place. I have several friends that fly rans and
 they have had ice also. On the 914 you get the air after the turbo if I
 remember right and it will take care of any problems.
 john
		Sbennett3(at)aol.com Guest
				 Posted: Sat Dec 01, 2007 10:03 am    Post subject: Carb Heat |
				I have a 1994 built kitfox 4 with a 912. No carb  heat, and it has almost 800 hrs on it.  I live in NC. Steve  Bennett
 Check out AOL Money & Finance's list of the hottest products and top money wasters of 2007.
		wingnut
				 Posted: Sat Dec 01, 2007 11:35 am    Post subject: Re: Carb Heat |
				Did you ever have a problem with icing on your 912 before adding the light bulb?
  	  | Quote: | 	 		  | I didn't want to go through the hassle of making a carb heat muff, box, control etc. This is A kind of do it and for get about it. I always leave it on as there is no performance loss. It's designed to keep the carb above freezing even when considering the evaporation due the venturi. After a few years, I have had no icing problems. The 15W light bulb taped to the side of the carb work real good too.  |
Model IV 1200
Rotax 912UL
Flying Weekly
Laurens, SC (34A) |
		av8rps(at)tznet.com Guest
				 Posted: Sat Dec 01, 2007 1:47 pm    Post subject: Carb Heat |
				Luis,
 I have a 912ul in a Model IV Kitfox that I've put about 300 hours on thus
 far and not ever have I experienced carb ice problems.  But a friend of mine
 with a very similar kitfox two hangars down from me has experienced it a few
 times already in less than 50 hours of flying.  (Wisconsin has great weather
 for carb ice fwiw)  So why would he have the problem when I don't?
 Here's my idea;
 If you installed the standard Kitfox carb heat kit you are forcing cold air
 from the front of the engine compartment down the scat tubing directly into
 the carburetor venturis.  So you have nothing but nice ice cold air coming
 into your carbs.  And being that it is speeded up as it goes through the
 venturi opening on the carb, if the conditions are right, you are going to
 get ice in your carbs.
 If you DIDN'T install the carb heat kit you will have air filters attached
 to the back of the carburetors resting nearly against the firewall, rather
 than scat tubing from the front of the cowl. And because the carbs sit
 directly above the exhaust pipes, plus the muffler is nearby along with all
 the other heat that gets blown back toward the firewall coming off the
 engine, the air going into the carbs is going to be relatively warm.  So
 that makes carb icing pretty unlikely.  However, I did say unlikely, not
 impossible.
 So long story short, Kitfoxes with the carb heat kits are the ones that will
 ice up (ironic isn't it?).  BUT, all the pilot needs to do when that happens
 is to pull the knob to engage manifold heat to the carbs and they will be
 able to fix the problem.  My friend has since adopted a carb heat on policy
 whenever flying in conditions that look good for carb icing.  He says he
 doesn't even notice a performance loss.  Thus far, that is working good for
 him.
 So if you have carb heat installed, you'll get ice.  But you can fix the
 problem by applying heat with the carb heat knob.
 If you don't have carb heat installed, and you get carb ice, you are
 probably going to be making an unplanned landing....
 Paul Seehafer
 Central Wisconsin
 Model IV 1200 912ul amphib
		Vic Baker
  Joined: 11 Jan 2006 Posts: 71 Location: Carson City, Nevada
				 Posted: Sat Dec 01, 2007 3:13 pm    Post subject: Carb Heat |
				Ok guys,
 I've got a Model 7 here about ready to go,  got the induction plenum
 installed behind the carbs with the feed being cold air from the lower cowl
 intake scoop which directs air across the radiator.  There is an alternate
 air intake on the plenum which the instructions call for safety wiring
 closed.  Seems like an ideal setup for carb icing.  Any suggestions out
 there?
 Vic
 Vic Baker
 S7 912S Warp 95%
 Carson City, Nv
  _________________ Vic Baker
Series 7
Carson City, Nevada |
		lcfitt(at)sbcglobal.net Guest
				 Posted: Sat Dec 01, 2007 3:19 pm    Post subject: Carb Heat |
				Paul's experience is what has been the mantra since I started building in
 1993.  With the exception of the first Alaska trip reporting hiccups of the
 912s that they attributed to carb ice, the only reports of carb ice in the
 nearly fifteen years I have been monitoring the list is in carb heat box
 equipped Kitfoxes.  Paul, regarding your friends no loss of power with carb
 heat on - the overall reports seem to indicate that the assembly with SCAT
 tubing will degrade performance a bit due to induction resistance whether
 the carb heat is on or off.  As I recall, this was the most compelling
 reason most opted to remove the system.  My now desceased Model IV did not
 have carb heat nor did any of the other six  guys I regularly flew with and
 the bunch all had hours approaching 1000 or more.  I had 909 when Kay and I
 went down.  None have reported anything approaching carb ice.
 Lowell
		LarryM
				 Posted: Sat Dec 01, 2007 4:04 pm    Post subject: Re: Carb Heat |
				Dave,
   When I was testing the unit before deciding how hot to make it, at 20F, with the carb left to cold soak overnight, within minutes of plugging it in - it was hot to touch.  It is estimated than 100f is hot to the touch.  The way I use it as an "anti ice" is having the carb body warm all the time, therefore the condensation can't freeze.
   I concur with the others who say carb ice is rare, but at our strip, I'm the only one without an unscheduled landing due to carb ice.  OH No, what did I just do to my self!!!!???
 larry
		dgolden(at)golden-consult Guest
				 Posted: Sat Dec 01, 2007 4:40 pm    Post subject: Carb Heat |
				Lowell Fitt wrote:
  in 1993.  With the exception of the first Alaska trip reporting hiccups
  of the 912s that they attributed to carb ice, the only reports of carb
  ice in the nearly fifteen years I have been monitoring the list is in
  carb heat box equipped Kitfoxes.  Paul, regarding your friends no loss
  of power with carb heat on - the overall reports seem to indicate that
  the assembly with SCAT tubing will degrade performance a bit due to
  induction resistance whether the carb heat is on or off.  As I recall,
  this was the most compelling reason most opted to remove the system.  My
  now desceased Model IV did not have carb heat nor did any of the other
  six  guys I regularly flew with and the bunch all had hours approaching
  1000 or more.  I had 909 when Kay and I went down.  None have reported
  Lowell
 I don't know if there is room to install carb heaters in the Kitfox
 installation, but if you're worried you might want to check this out:
 http://www.ultralightnews.ca/bing/carbheater.html
 Dennis
 Dennis Golden
 Golden Consulting Services, Inc.
		wingnut
				 Posted: Sat Dec 01, 2007 4:44 pm    Post subject: Re: Carb Heat |
				Paul,
 Didn't you answered your own question with the rest of your post? ie: Your friend has experienced carb ice because he has carb heat box. You've not experience carb ice but how do you know that it isn't just because you don't have the same setup? So is it true as Lowel suggested that no one on this list that does not have a carb heat box has ever experience carb ice? That would be kind of compelling.
  	  | Quote: | 	 		  | I have a 912ul in a Model IV Kitfox that I've put about 300 hours on thus far and not ever have I experienced carb ice problems. But a friend of mine with a very similar kitfox two hangars down from me has experienced it a few times already in less than 50 hours of flying. (Wisconsin has great weather for carb ice fwiw) So why would he have the problem when I don't? |
Model IV 1200
Rotax 912UL
Flying Weekly
Laurens, SC (34A) |
		darinh
				 Posted: Sat Dec 01, 2007 7:31 pm    Post subject: Re: Carb Heat |
				John,
 Yes, you are right.  I got looking at it and the air from the turbo will take care of any ice I may have.  In fact, I am going to install an intercooler in the induction line to cool the air a bit...don't know what I was thinking when I made the previous post.  According to the Europa flyers, the intercooler increases the power of the engine slightly and is better on the engine.
Series 7
914 Turbo
Kaysville, Utah |
				 Posted: Sat Dec 01, 2007 8:13 pm    Post subject: Carb Heat |
				Luis,
 Yes, I know I answered my own question.  Sorry for causing you some
 confusion.
 And Lowell is also right about losing some power with the carb heat on.  I
 agree you should lose power when turning on carb heat.  I'm guessing my
 friend is either too new to his airplane to really notice it, or he is so
 tickled pink with all the power his Kitfox has that he doesn't miss a few
 hundred rpms when flying.  Whatever the case, I know he has plenty of power
 with the carb heat on, so he's most likely going to keep flying it that way
 on days when carb ice is likely.
 Like Lowell also said, most that have removed their carb heat kit (or choose
 not to add one) do so because they want full power from the engine.  I was
 one of those that chose to remove mine in favor of more power/rpms.  Given
 my druthers I'd have carb heat I could turn if ever needed.  But I didn't
 like the setup that came with my airplane.  So in the meantime I will
 continue to fly without carb heat.   But I will definitely keep my eyes and
 ears open for a better solution should one come along.
 Paul Seehafer
 Model IV-1200 912ul amphib
				 Posted: Sat Dec 01, 2007 8:52 pm    Post subject: Carb Heat |
				Darin,
 Adding an intercooler would be a bunch of work but would increase the life
 of the 914. Another thing you can do for comfort is to install a radiator
 and oil cooler louver control system made by one of our listers. I am going
 to order one set this week for my fox. I am hoping he is still making them.
		Float Flyr
				 Posted: Sun Dec 02, 2007 5:48 am    Post subject: Carb Heat |
				Dave, exactly where are you?
 As you know, two things are required to make ice, cold temperatures and
 water.  If you remove either one then ice cannot form.  Venturi effect will
 automatically produce some refrigeration effect in the throat of the
 carburettor.  The throat temps can be surprisingly low, given the right
 conditions even at temperatures well above freezing.  All this is covered in
 everyone's flight training.
 What I'm getting at is if you are high up in the mountains than you probably
 also have a very dry climate and you may not get ice especially on the
 coldest days.  Where I live, a few hundred miles away from the world's
 biggest fog factory, The Grand Banks, ice is always a consideration.
 Temperatures may not be as low as yours but 90+% moisture can more than make
 up for that on days where the temperature is anything below 60F.
 Noel
 [quote] --
  _________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
		Float Flyr
				 Posted: Sun Dec 02, 2007 6:10 am    Post subject: Carb Heat |
				If you are using a turbo charger then the possibility of  ice is extremely
 low.  The turbo removes the low pressure area that normally ices up.
 However you should be aware of impact ice.  This is ice that can form on the
 air screen in the front of the cowling and cut off air to the engine.  That
 is of course an IMC.  If you are flying into IMC then an alternate intake
 port which is not filtered and only opens when the main air feed is blocked,
 would be a good idea.
 Noel
 [quote] --
Kitfox III-A
