kerrjohna(at)comcast.net Guest
Posted: Sun Dec 02, 2007 6:19 am Post subject: Carb Heat |
John Oakley raises a point that has been hashed over before. The carb heat box out in the cold brings in cold air. Operating without the carb heat box the carburetors are always in a "carb heat condition", high up in the motor compartment out of direct air flow, just like on the RV line, pulling heated air from the engine compartment. It has been suggested that the only 912 flyers that have experienced carb ice are sucking in cold air. Has anyone experienced carb ice on a 912 pulling air from the engine compartment?
John Kerr
[quote] --> Kitfox-List message posted by: "john oakley"
Darin,
I have the carb box that was a stock system on the model 4. I have had ice
twice, both times in a bad place. I have several friends that fly rans and
they have had ice also. On the 914 you get the air after the turbo if I
remember right and it will take care of any problems.
john
rdmac(at)swbell.net Guest
Posted: Sun Dec 02, 2007 6:38 am Post subject: Carb Heat |
Vic,
I have the same set up as you. The alternate intake is probable for
carb heat but in yours and my setup it is not needed and here's my take on
that. That induction plenum is located in an area of the engine compartment
where engine heat is going to be at its highest. It's my belief that plenum
chamber will warm the incoming air sufficiently to prevent any icing
problems. Heck the carbs them selves are right behind the cylinders where
air is blown across the cooling fins. I'm not saying it's impossible but it
would be highly unlikely for carb icing to form. Now that being said, if I
did a lot of flying in a climate at or below freezing I would tend toward
the cautious side and install some sort of carb heat and cabin heat sense I
don't have neither. For the most part I'm a fair weather flyer and won't
even roll my plane out of the hanger if it is colder than 50 degrees. I
think everyone has to decide for themselves if carb heat is needed based on
under what conditions they plan to fly in.
Roger McConnell, Duncan, OK
Model 7 Trigear, Rotax 912uls
Flying sense Jan. 06
MichaelGibbs(at)cox.net Guest
Posted: Sun Dec 02, 2007 9:16 am Post subject: Carb Heat |
Roger sez:
Quote: | For the most part I'm a fair weather flyer and won't even roll my
Keep in mind that carb ice can form in ambient temperatures as high
as 70 degrees Fahrenheit.
Mike G.
N728KF
Phoenix, AZ
Noel sez:
Quote: | Dave, exactly where are you?...What I'm getting at is if you are
high up in the mountains than you probably also have a very dry
climate and you may not get ice...
It seems to me that you build for where you plan to go, not where you are now.
Mike G.
N728KF
Phoenix, AZ
clemwehner(at)sbcglobal.n Guest
Posted: Sun Dec 02, 2007 10:00 am Post subject: Carb Heat |
I can confirm Mike's comment. I have a LOT of experience with carb
ice--in my old Dodge van. I had a 1986 Dodge Caravan that was plaqued
with carb ice every spring and fall, when temps were in the 50's and low
60's. The carb would ice up so bad that the van would slow down to 20
MPH max.
The solution was during those seasons, to remove the air ducting from
the carb to the front of the vehicle, and let the carb suck air through
the air filter from inside the engine compartment. This is just like
we've been talking about the 912 getting carb ice when a de-ice duct is
pulling air from the front and less (or no) carb ice when the air is
sucked through the air filters inside the engine compartment.
My old van never got carb ice when it was really cold outside like down
in the 30's or less.
Clem Wehner
Lawton, OK
KF-IV-912
Sbennett3(at)aol.com Guest
Posted: Sun Dec 02, 2007 3:27 pm Post subject: Carb Heat |
I flew 2 hrs today. Complete overcast. Rain and drizzle the entire flight. Ceiling at 2000 to 2500. Outside air temp at take off was 43f. I have breathers on the firewall, no carb heat. Good solid flight. Location NC, take off airport 351 msl. Destination airport 126 msl. Steve Bennett
hottest products and top money wasters of 2007.
Posted: Sun Dec 02, 2007 3:50 pm Post subject: Carb Heat |
MPH max.
Clem Wehner
Lawton, OK
KF-IV-912
kitfoxmike
Posted: Sun Dec 02, 2007 4:08 pm Post subject: Re: Carb Heat |
I flew yesterday for 30min. The weather was bad. Ceiling was about 4000 with field elevation at 2000. Temp was 24. 15 minutes later the ceiling was down to 3000 vis. was getting close to 7 miles. did a few more touches and then noticed that everything went to heck, with snow flurries hitting the window. Landed and looked around and felt the ceiling was down to about 900 off the ground. About 5 minutes later it was snowing big time. way below mins. I don't have carb heat.
Was I taking a change with vis. no way, that's why I was in close traffic and doing touch and go's. I also kept an eye on the weather.
I feel carb heat is a bigger issue if you let it idle too much, so keep the speed up. Plus with the Rotax you have higher rpm's with slower blade speed, that helps also.
occom
Posted: Sun Dec 02, 2007 4:13 pm Post subject: Carb Heat |
I live in Halifax Average humidity ~70-80% average temp for much of the year
10-20 deg C.
Here's a handy carb icing chart
http://ibis.experimentals.de/images/carbicingfromcaassl14.gif
The U.S. Navy tested their Osprey here quite a bit but I don't think carb
icing was what they were looking for. It's an impressive device in any case,
but I wonder how useful.
Dave Goddard- Mod IV 1050/582
Quote: | >>Dave, exactly where are you?...
Quote: | It seems to me that you build for where you plan to go, not where you are
now.
lcfitt(at)sbcglobal.net Guest
Posted: Sun Dec 02, 2007 6:59 pm Post subject: Carb Heat |
John, Never here. Last Summer's flight to the north country was to the
coastal area of Oregon mostly between Waldport and Tillamook with several
trips up and down the coast as we were trying to penetrate the marine layer
lying against the inland hills to get to McMinnville for the Antique fly in
and to see the Spruce Goose. Lots of fog (low ceilings) and rain but
nothing resembling carb ice. There were six of us on this flight. Also
lots of flying over the past nine years with no evidence of carb ice.
Lowell
kitfoxjunky(at)decisionla Guest
Posted: Mon Dec 03, 2007 5:44 am Post subject: Carb Heat |
I had a situation where I was taking the plane from my hanger to another hanger for an EAA event. It was cold, with light rain. The engine rpm was below 2500 most of the way and it started loading up after about 5 minutes. It was fine after sitting in the heated hanger overnight. I am pretty sure it was carb ice. Then again..the engine was not up to full operating temp yet.
Gary Walsh
KF IV Anphib 912S
C-GOOT
www.decisionlabs.com/kitfox
Float Flyr
Posted: Mon Dec 03, 2007 6:42 am Post subject: Carb Heat |
Alternate intake is for fuel injection in case of blockage of the normal
screened (filtered) air. Such a blockage can be caused by impact ice
forming on the front of the air intake. Alternate a9ir should only be used
as necessary because it is not filtered in any way.
Noel
[quote] --
_________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
dave
Posted: Mon Dec 03, 2007 6:38 pm Post subject: Re: Carb Heat |
Any carbeurated engine can get carb ice or carb icing.
In Canada for amatuer builts it is mandatory to have it installed.
I have experienced it before on many engines and latest today was a gasoline tractor I installd a snow blower on .
Just because it has not happened to some, i could be that they have never flown in conditions where carb ice "could " happen. If you have Carb heat then you have one less thing to worry about not having If you need it .
Hundreds of Kitfox Movies
Most viewed Kitfox on youtube
Most popular on youtube
Highest rated on youtube |
Posted: Mon Dec 03, 2007 6:47 pm Post subject: Carb Heat |
In a message dated 12/3/2007 9:41:12 PM Eastern Standard Time, dave(at)cfisher.com writes:
Quote: | Any carbeurated engine can get carb ice or carb icing |
True, but we dont all fly in Canada.
If you have carb heat, you better be prepared to use it cause you are always intaking colder air. Here we go again re hashing this... If I lived where I grew up near Chicago, i'd have it. Down where I live now... A different story. Steve Bennett NC
Posted: Mon Dec 03, 2007 7:10 pm Post subject: Carb Heat |
Steve sez:
Quote: | ...If I lived where I grew up near Chicago, i'd have it. Down where
As I mentioned before, Steve, if you live someplace it can get below
70 degrees F outside, you live where it is cold enough to get carb
ice. And don't forget that it gets 3-1/2 degrees cooler every
thousand feet you climb.
I don't want to get into the debate about whether or not carb heat is
needed on 912s, but don't kid yourself that living in the south makes
you safe.
Mike G.
N728KF
Phoenix, AZ
(where it seldom gets below 70...except at night...in the winter)
wingnut
Posted: Mon Dec 03, 2007 8:04 pm Post subject: Re: Carb Heat |
I agree that anecdotal evidence is useless. A few people saying that they've never had carb ice doesn't prove much at all no matter how many hours they have flown. However, if we can say that no one on this list who is running without carb heat has ever had carb ice; That's a whole different ball game.
Quote: | Just because it has not happened to some, i could be that they have never flown in conditions where carb ice "could " happen. If you have Carb heat then you have one less thing to worry about not having If you need it . |
_________________ Luis Rodriguez
Model IV 1200
Rotax 912UL
Flying Weekly
Laurens, SC (34A) |
Posted: Mon Dec 03, 2007 8:08 pm Post subject: Carb Heat |
Mike, I understand lapse rate. It's been mentioned here that the 912's that breath air from the back of the firewall are less prone to freezing. I'm not playing word games and neither are you. You could fly my plane here and feel confidant not having icing with my configuration. pick your region and configuration wisely. I know of many planes here running the 912 without carb heat. SBennett
Check out AOL Money & Finance's list of the hottest products and top money wasters of 2007.
Posted: Mon Dec 03, 2007 8:26 pm Post subject: Carb Heat |
Steve sez:
Quote: | ...You could fly my plane here and feel confidant not having icing
I don't think I worded my last message very well. There are those
that feel carb heat is mandatory and those that feel that removing
the hardware works best. I am not qualified to comment on the
issue--I really don't know which is better. As with most areas of
disagreement, there are probably elements of truth to both sides.
I was simply trying to say that you should satisfy yourself that your
airplane can operate safely in the expected ambient conditions.
Anyone in the mid-latitudes (continental U.S., Europe, central
Australia, etc.) can experience temperatures and humidity conducive
to carb icing. In fact, temperate climates are more susceptible than
arctic ones because in the arctic it gets too cold for ice to form in
the carb.
In other words, it has everything to do with the design and
construction of the engine installation and nothing to do with where
you live.
Mike G.
N728KF
Phoenix, AZ
nail13zg(at)centurytel.ne Guest
Posted: Mon Dec 03, 2007 8:27 pm Post subject: Carb Heat |
In a typical aircraft normally aspirated carburetor, the venturi effect can reduce the temperature inside the carburetor by as much as 60 degrees Fahrenheit. So even at 90 degrees outside air temperature, the inside of the carburetor can be below freezing. If the air is moist, as measured by the dew point spread, you have the recipe for carburetor ice. How much this applies to a Rotax 912 or other typical Kitfox engine, I have no idea, but I suspect it isn't far off.
One of the hardest charts to find is the Carburetor Icing Probability chart. I have attached it to this message.
Trey Moran
CFI, CFII, almost complete Model 5, Stratus EA-81
Polson, MT
Description: |
 Download |
Filename: |
Carburetor_Icing_Probability_Chart_C_(small)_pdf.pdf |
Filesize: |
173.47 KB |
Downloaded: |
1887 Time(s) |
john(at)leptron.com Guest
Posted: Mon Dec 03, 2007 8:54 pm Post subject: Carb Heat |
Trey,
Thanks for the chart, I will add it to my manual.
John Oakley
From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of Trey Moran
Sent: Monday, December 03, 2007 9:26 PM
Subject: Fw: Re: Carb Heat
Trey Moran
Polson, MT
