		ding(at)tbscc.com Guest
				 Posted: Mon Dec 03, 2007 2:38 pm    Post subject: Fuel Level Senders |
				Does  anyone know what the operating ohm range is on the Zenith supplied fuel level  senders?   I'm Trying to determine if the Westach WS2DA4 dual guage  will read them correctly.
        Lynn
        Corry,  PA     601XL / Corvair
  |  | - The Matronics Zenith-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
		swater6
  Joined: 16 Dec 2006 Posts: 52 Location: Minnesota-KMIC/KANE
				 Posted: Mon Dec 03, 2007 2:56 pm    Post subject: Re: Fuel Level Senders |
				My memory says 10-180.  I have Mitchel gauges from ACS that match.  Also, if memory serves, there aren't a lot of aircraft guages that are that range.  I'll confirm this evening...
 Scott
  _________________ 601 XL kit N596SW reserved
Tail, control surfaces and both wings complete. Now working on fuselage
www.scottwaters.com |
		lwinger
				 Posted: Mon Dec 03, 2007 3:44 pm    Post subject: Fuel Level Senders |
				70 to 10.
  Larry Winger
  601XL/Corvair
  Tustin, CA
  On Dec 3, 2007 2:37 PM, dingfelder <ding(at)tbscc.com (ding(at)tbscc.com)> wrote:
  [quote]          Does anyone know what the operating ohm range is on the Zenith supplied fuel level senders?   I'm Trying to determine if the Westach WS2DA4 dual guage will read them correctly.
        Lynn
  _________________ Larry Winger
Tustin, CA
Plans building 601XL/650 with Corvair
Installing fuel system
www.mykitlog.com/lwinger |
		swater6
				 Posted: Mon Dec 03, 2007 6:21 pm    Post subject: Re: Fuel Level Senders |
				It depends on the sender that you have.  Some are 10 to 70.
 The VDO sender that came with earlier kits is 10 to 180.  10 ohms when empty and 180 when full.  The part number is 226 002. This is the older sender that needed the top bolts filed down.  I'm not sure what the range is for the newer sender Zenith now uses.
 The fuel gauge that I have for 10-180 ohms is a Mitchell part number 10-25130 from Aircraft Spruce (D1-211-5074 Mitchell number)
 Hope this helps.
 Scott
