chris(at)southernskies.ne Guest
Posted: Sat Dec 01, 2007 4:03 pm Post subject: 8 inch wheels |
New to this list, please excuse if topic came up before.
I have the 6 inch Matco Wheels/Brakes on my model 3 and also have a set of new "Tundra" 8 inch ATV tires (slick, big and fat).
I would like to switch to these big fat tires since my field is very rough.
Obviously, 8 inch wheels won't fit on the 6 inch Matco wheels, so my question is: What wheels do I need to get and what else do I need to change, if any?
Will my existing brakes work?
I heard something about ATV wheels but I don't have a clue as to what exact model to look at and how to make it work with my existing landing gear/axle/brakes (have the Grove Aluminum Gear).
Thanks for any advice.
Chris
thesupe(at)hotmail.com Guest
Posted: Sat Dec 01, 2007 6:40 pm Post subject: 8 inch wheels |
I switched my 6" wheels on my Avid MK IV to 8" Kitfox wheels so I could use the 8" tundra tires also. I used a set of hubs from a Kitfox 3 and the 8" Mitchell wheels that came on the Kitfox 3s. I'm guessing that your Matco wheels have the bearings inside the wheel and don't have a seperate hub. I believe that is what was on my Avid to start with. The disc brake rotor fit both sets of wheels, I just swapped from one set to the other. The Kitfox hub needs more axle length than the Matcos. I have another set of hubs for a Kitfox that I don't really need, but no extra 8" wheels. Hope this info helps (and is correct) Jim Chuk
| Quote: | Date: Sat, 1 Dec 2007 16:55:46 -0500
Subject: Kitfox-List: 8 inch wheels
--> Kitfox-List message posted by: Southern Skies <chris(at)southernskies.net>
Chris
&g========================
Connect and share in new ways with Windows Live. Connect now!
kitfoxpilot(at)msn.com Guest
Posted: Sat Dec 01, 2007 6:46 pm Post subject: 8 inch wheels |
What you will need is the original DOUGLAS ATV wheel to fit those large tires! I have two sets of the original hubs and bearings, plus the axles if your interested. Douglas has a web site just google you will find it. Let me know if your interested in my hubs and axles.
Ray
Chris
Get the power of Windows + Web with the new Windows Live. Power up! [quote][b]
lcfitt(at)sbcglobal.net Guest
Posted: Sat Dec 01, 2007 10:17 pm Post subject: 8 inch wheels |
Chris,
I believe Matco now has 8" wheels. Contact them.
Lowell
jose_m_toro(at)yahoo.com Guest
Posted: Sun Dec 02, 2007 7:15 am Post subject: 8 inch wheels |
Chris:
An alternative is to keep the same wheels, and switch to higher diameter tires for the 6 inches wheel. You could use a 20 inches tall tire or even higher if desired.
José Toro
ex Kitfox II/582
LarryM
Posted: Sun Dec 02, 2007 3:39 pm Post subject: Re: 8 inch wheels |
Which tires and how high can you put on the 6"?
Posted: Tue Dec 04, 2007 6:15 am Post subject: 8 inch wheels |
Larry:
An alternative is 8.00-6. This tire is wider, and aproximately 20 inches tall as opposed to 16 inches on the regular 6.00-6 tire. On my ex-Kitfox, I had 8 inches wheels and used 6.50-8 aviation grade tires that were 21 inches tall (and very heavy). For sure, if you do a search in the internet you could find taller, non-aviation grade tires that could work. I don't remember what model is you Kitfox, but it is very common to use non-aviation grade tires on earlier/ligther models (I-IV). If you use bigger tires you would be trading off some speed. Hope this help.
Jose
ex-Kitfox II/582 (and happy I'm still allowed to fly it)
LarryM
Posted: Wed Dec 05, 2007 5:23 am Post subject: Re: 8 inch wheels |
Thanks Jose,
I found some 800 x 6 from Carlise. I'll try those. I haven't been able to find anything larger. The big boys - Super Cub guys consider 26" small and shoot for 31 or 35". Imagine the weight not to mention the cost on those!
larry
Posted: Wed Dec 05, 2007 7:55 am Post subject: 8 inch wheels |
Larry:
That alternative is cheaper than changing wheels, and provides additional cushion. Keep the list informed of the results!
Best Regards!
José
