Tadsargent(at)bellsouth.n Guest
Posted: Tue Dec 04, 2007 5:13 am Post subject: Wing root Fairing |
Hey guys I am in the final assembly stages of a 10. My questions has to do
with the gap between the fuse and the wing root fairing. My 7 has a rubber
seal to make up the gap, I cannot find this pictured or a gap specified for
the 10. Is the fairing trimmed to a 32nd and that it or did I miss the
rubber piece somewhter.
Tad Sargent
Ted French
Joined: 09 Jan 2006 Posts: 54 Location: Kelowna BC Canada
Posted: Tue Dec 04, 2007 6:44 am Post subject: Wing root Fairing |
Yup, the fairing is trimmed to a close fit to the fuselage. There is no
rubber filler.
Ted French C-FXCS
RV-10 Flying
_________________ Ted French
RV-10 fuselage |
Posted: Tue Dec 04, 2007 7:43 am Post subject: Wing root Fairing |
The -10 does not have the gap. There is an angle that rivets onto the
side of the fuse that the fairing screws onto, so it is a flush fit
with no gap for a seal.
Jesse Saint
Saint Aviation, Inc.
jesse(at)saintaviation.com
Cell: 352-427-0285
Fax: 815-377-3694
no
rubber filler.
Ted French C-FXCS
RV-10 Flying
wcurtis(at)nerv10.com Guest
Posted: Tue Dec 04, 2007 8:49 am Post subject: Wing root Fairing |
I was thinking of using the rubber F-1094C gap seal used under the horizontal stab to provide a tighter fit and add some flexibility. Should also provide a nice clean look and a ~small gap fairing benefit. F-1094C is not on "the list" however so will have to call Van's for pricing on required length.
William
http://wcurtis.nerv10.com/
Posted: Tue Dec 04, 2007 10:37 am Post subject: Wing root Fairing |
I think it's called "Rubber Channel" in Van's catalog.
do not archive.
Jesse Saint
Cell: 352-427-0285
Fax: 815-377-3694
William
coop85(at)cableone.net Guest
Posted: Tue Dec 04, 2007 4:55 pm Post subject: Wing root Fairing |
I suspect the gap seal used on the horizontal stab might force you to trim a
fairly large gap in the fairing. Not necessarily a big deal, but I just
used narrow U channel to help seal the gap and make up for any
irregularities.
Marcus
