				 Posted: Sun Dec 02, 2007 10:46 pm    Post subject: Elevator trim tab information needed |
				Hello Kolb guys and girls,
    I have a question regarding the elevator trim on a MkIII.  Is there anyone that actually built a trim tab INTO the elevator?  (Rather than adding it on!)
   What I'm getting at is, I am seriously considering building a "built-in" elevator trim tab, most likely with electric adjustment.  Has anyone done this already?  And, does anyone have an idea of the dimensions that a MkIII elevator trim tab would need to be?
   As I have recommended in the past, the motorcycle exhaust servo motor could make a perfect electric trim motor.
 Some come with cable assemblies, and mounting tabs.  These are very durable, high torque, 12volt, small servo motors.  I have one similar to this.  It would be very easy to attach the cables to a bellcrank.
 http://cgi.ebay.com/ebaymotors/06-GSX-R1000-GSX-R-exhaust-servo-motor-engine_W0QQitemZ310002541330QQihZ021QQcategoryZ35591QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
   Any thoughts on the subject would be much appreciated.       Mike Welch  MkIII
 BTW.  Many thanks to the people that offered lots of advice regarding cutting and drilling Lexan (especially Rick G.'s drill bit drawing)  I am happy to say, I am virtually finished with all the "glass" (Lexan).  OMG, THAT was a lot of work!!!   Cleco it on.  Uncleco, sand it some.  Cleco it back on, check for fit, again, uncleco it, etc, etc, etc, etc.
 You keep typing, we keep giving. Download Messenger and join the i’m Initiative now.
		ElleryWeld(at)aol.com Guest
				 Posted: Sun Dec 02, 2007 11:21 pm    Post subject: Elevator trim tab information needed |
				Mike
  I  Built a trim tab into one of the elevators on my Firestar like your talking about it worked great  it was 3"X 12" controllable in flight, I sold the Plane to a Guy in Minnesota but I think I have a pic somewhere of the modification I did on it.
  I think theirs PICS in the archives I did of this mod.
  I could us the trim alone to land the plane  of course in perfect conditions no gusting x winds
  Ellery In Maine Building MK3Xtra
 hottest products and top money wasters of 2007.
				 Posted: Mon Dec 03, 2007 7:02 am    Post subject: Elevator trim tab information needed |
				Hi Ellery,
    Thanks for the reply on the trim tab.  Was the one you built on the Firestar electrically operated?  Do you plan the same type of tab on the Xtra you're building?  Why was the trim tab on Crystal's MkII so huge?
   I will check the archives.  If you come across that photo of the tab you built, I'd sure appreciate it if you sent it to me.  Do you think 3" X 12" would be big enough for a MkIII, of should it be more like 4" X 14"?  Or whatever?
                                                  Thanks,   Mike Welch
 Date: Mon, 3 Dec 2007 02:20:52 -0500
 Subject: Re: Elevator trim tab information needed
 Mike
 Put your friends on the big screen with Windows Vista® + Windows Live™.
 http://www.microsoft.com/windows/shop/specialoffers.mspx?ocid=TXT_TAGLM_CPC_MediaCtr_bigscreen_102007
		cartejy(at)mtn-state.com Guest
				 Posted: Mon Dec 03, 2007 7:45 pm    Post subject: Elevator trim tab information needed |
				Mike,I have a Firestar,,,with built in Electric Trim....works real
 well,,very efective & easyto manage. I will put some info & pics out to you
 on the site. 503...KXP & located in East :Liverpool Ohio,I will get some
 photos & how done & what. get at it soon as can..hope it helps. Jay Carter
 N90485..Firestar Exp --
		olendorf
  Joined: 06 Jul 2006 Posts: 140 Location: Schenectady, NY USA
				 Posted: Tue Dec 04, 2007 6:02 am    Post subject: Re: Elevator trim tab information needed |
				Jay,  That's some Firestar you have there!  How does that RAMJET engine perform?  Must be a blast.
 Here is the aircraft info from airport-data.com
 Aircraft N90485 Profile
 Aircraft (FAA)
 Manufacturer: Washburn Ron
 Model: FIRESTAR KXP    Search all Washburn Ron FIRESTAR KXP
 Year built: 1991
 Serial Number (C/N): 297
 Mode S Code: 53100626
 Aircraft Type: Fixed wing single engine
 Amateur-Built: Yes
 Number of Seats: 1
 Number of Engines: 1
 Engine Type: Ramjet
 Engine Manufacturer and Model: Ama/expr UNKNOWN ENG
  _________________ Scott Olendorf
Original Firestar, Rotax 447, Powerfin prop
Schenectady, NY
http://sites.google.com/site/kolbfirestar/ |
				 Posted: Tue Dec 04, 2007 7:07 am    Post subject: Elevator trim tab information needed |
				Jay,
    Thanks for whatever info you can send.  Scott O. refers to "nice looking plane", but I didn't see any photos, or a link to photos.
    I'm also considering making the trim tab adjustable with possibly a cable like Ellery suggested.
    Thanks,   MIke Welch  MkIII   (I'll go look at the Kolb list photo site, to see if they're there)
 [quote] Mike,I have a Firestar,,,with built in Electric Trim....works real
 Connect and share in new ways with Windows Live. Connect now!
				 Posted: Tue Dec 04, 2007 7:39 am    Post subject: Elevator trim tab information needed |
				Mike W:
  Thought you may be interested in the following NTSB  fatal accident report:
  http://www.ntsb.gov/ntsb/brief.asp?ev_id=20001211X11253&key=1
  Standard forced pitch trim works well on the  MKIII.
  For what it is worth,
  hauck's holler, alabama
  _________________ John Hauck
Titus, Alabama |
				 Posted: Tue Dec 04, 2007 8:02 am    Post subject: Elevator trim tab information needed |
				Wow.  Thanks, John, for the article on the trim accident.  I guess that is basically my concern, which is: how effective and accurate is the adjustment on the present design?
   Maybe I should leave well enoungh alone.                             Mike
 Date: Tue, 4 Dec 2007 09:38:50 -0600
 Mike W:
 http://www.ntsb.gov/ntsb/brief.asp?ev_id 001211X11253&key=1
 Your smile counts. The more smiles you share, the more we donate.  Join in.
 www.windowslive.com/smile?ocid=TXT_TAGLM_Wave2_oprsmilewlhmtagline
		JetPilot
				 Posted: Tue Dec 04, 2007 8:46 am    Post subject: Re: Elevator trim tab information needed |
				I am also going to add electric trim to my Kolb MK-III Xtra.   As shown in the accident report you need to be careful, but there is no reason not to do it.  Many experimental / Ultralight airplanes have "Real" trim tabs, I like this a lot better than the spring adjustment, as almost all certified aircraft prove, this is the better way to trim an airplane.  On a kolb it also gives you the ability to trim down and it also gives a back up to broken elevator cables, attachments etc.
 Number one, I will be adding counterweights to my elevators when I add the trim tab, similar to the ones on the ailerons to eliminate the possibility of flutter.   Stock, the elevator cables act as the counterbalance for the elevator and keep it from fluttering, but this may not be enough with the added weight of a trim tab and actuator.
 Having a trim tab come free in flight can be disastrous, and induce flutter, it has happened on certified airplanes plenty of times.   There is a purpose built electric trim actuator for experimental aircraft made by Ray Allen company, I have flown with it on another experimental similar to the Kolb ( Skyboy ) with these electric trim on both the rudder and elevator and its WONDERFUL !!!   Its just so nice to do patterns, and just move the hat switch for trim in both axis and fly hands off whenever you like, like a real airplane !
 Given the critical nature of trim tabs, and the possibility of disastrous results, I would highly recommend using trim tabs that are designed for aircraft.   They are expensive, but not unreasonable.  You can look at them at the link below.
 http://www.rayallencompany.com/products/trimsystems.html
 Mike Bigelow
  _________________ "NO FEAR" -  If you have no fear you did not go as fast as you could have !!!
Kolb MK-III Xtra, 912-S |
		capedavis(at)yahoo.com Guest
				 Posted: Tue Dec 04, 2007 9:51 am    Post subject: Elevator trim tab information needed |
				Mike , I had a firestar KXP with a trim tab sold to me for around 100 dollars by Rans it was an alum formed tab which I cut down from 24x 4 inches to about b14x4inches  and it was adjusted by cable with a wheel about 6 inches in diameter mounted iin the cockpit , mine was on the cockpit frame just ahead of the throttle and was adjusted like the trim on my Dads 1959 Cessna 172 , Roll it forward the  nose went down , Roll it backward the nose comes up , and I was taking alot of Aeriel Photos and I could set the trim at any throttle setting to fly hands off , it worked for me for about 500 hrs . Hope this info is helpful , I don't know if  Rans still offers this but the installation and the use of it was an easy lesson in aircraft construction. Chris
		herbgh
				 Posted: Tue Dec 04, 2007 9:55 am    Post subject: Elevator trim tab information needed |
				near as I know,.,,horizontal trim tab does not have to be on the
 elevator... that would likely be the most effective spot however...
    Stick it on the vertical stab.. or on the horizontal stab..outboard
 end on the side that creates a bit of drag to assuage the p factor...??
 Herb
 On Tue,  4 Dec 2007 08:46:51 -0800 "JetPilot" <orcabonita(at)hotmail.com>
 writes:
		d-m-hague(at)comcast.net Guest
				 Posted: Tue Dec 04, 2007 11:19 am    Post subject: Elevator trim tab information needed |
				At 12:52 PM 12/4/2007, herbgh(at)juno.com wrote:
 A trim tab mounted to a fixed surface needs to be much larger.  When you
 put the tab on the elevator, the tab moves the elevator, and the elevator
 does the work of trimming the plane, so the tab is relatively small.  When
 the tab is mounted to a fixed surface (or separately mounted like the early
 Taylorcrafts and the Smith Miniplane), the tab has to do all the work
 directly and thus must be much larger.
 -Dana
   Why are there Interstate highways in Hawaii?
				 Posted: Tue Dec 04, 2007 12:03 pm    Post subject: Elevator trim tab information needed |
 Mike W:
 It would be interesting to know how many successful hours of flight have
 been put on the MKIII design since it was first produced in late 1991.  For
 that matter, it would also be interesting to know how many Kolbs have been
 built, how many were flown successfully, and how many are being flown
 successfully now, and for how long.
 My mkIII is serial number M3-011.  It was the first complete cage Brother
 Jim welded up when we were staying with Homer and Clara Kolb last of 1990
 and early part of 1991.  I personally inspected the first 40 or 50 MKIII
 fuselages that came off the line, was part of my daily chores during the
 time we spent building my MKIII during the evening hours.
 I can assure you the pitch trim system of the MKIII is more than adequate
 and safe.  If it wasn't, I would not be flying my MKIIII with it, and you
 would be hearing the screaming and moaning of those unhappy souls who were
 having problems with it.
 I am continually amazed at people who are redesigning their Kolb aircraft
 when they have little or no time flying it of any other Kolb.  I never
 changed a thing on any of the three Kolb airplanes I built before I had
 flown and gained good solid experience in them, enough experience to know
 what was needed and how to go about accomplishing the task that was
 required.
 One point on adding "stuff" to the trailing edge of the elevators.  The Kolb
 elevator is hinged on the leading edge and not at all balanced.  Why they do
 not have a tendency to flutter, I do not know.  However, in the case of the
 fatality I referenced, he had added more weight to the trailing edge which
 probably got him into trouble with flutter before the trim tab seperated.
 The original Twinstar used this elevator trim system.  It was changed to the
 present system used on the MKIII because it was proven to be a better
 design.
 Take care,
 mkIII 2,700+ hours
Titus, Alabama |
		planecrazzzy Guest
				 Posted: Tue Dec 04, 2007 2:47 pm    Post subject: Re: Elevator trim tab information needed |
				Jet Pilot is a big fat moron
  Last edited by planecrazzzy on Thu Jul 31, 2008 12:36 pm; edited 1 time in total |
				 Posted: Tue Dec 04, 2007 3:31 pm    Post subject: Elevator trim tab information needed |
				Hi Mike B:
 Interesting post on trim tabs.
  "Stock, the elevator cables act as the counterbalance for the elevator and
 keep it from fluttering,"
 You will have to explain the above to me a little bit better.  I do not
 understand how cables counter balance the elevators.
 "> I have flown with it on another experimental similar to the Kolb (
 real airplane !"
 I use a fixed rudder trim tab and have no requirement for an adjustable one.
 Same was true with my FS and US.  Far as I know my MKIII still flies like a
 "real" airplane without the luxury of Chinese Hat trim switch.
 Take care,
Titus, Alabama |
		planecrazzzy Guest
				 Posted: Tue Dec 04, 2007 4:25 pm    Post subject: Re: Elevator trim tab information needed |
				Jet pilot is a moron
  Last edited by planecrazzzy on Thu Jul 31, 2008 12:35 pm; edited 1 time in total |
		JetPilot
				 Posted: Tue Dec 04, 2007 7:08 pm    Post subject: Re: Elevator trim tab information needed |
				An electric trim does not cause flutter.   A failure that would drive an electric motor back and fourth is unheard of, they may run away to one stop or the other, but rapidly back and fourth no.  Even on the billion to one chance you could induce a back and fourth failure in electric trim, the mechanism is not capable of moving the trim tab anywhere near fast enough to cause flutter.  Bottom line is this is never going to happen. What does cause flutter in a trim tab is it coming loose from its actuator.   A free floating trim tab will induce flutter very quickly, and has happened many times in both certified and experimental.
 Mounting a trim tab on the end of the vertical or horizontal stab is a nothing short of a horrible idea.  First you add stress to the outboard of those surfaces, the worst place structurally that you possibly can.  The tabs would also be very inefficient, big, and heavy.  There is a very good reason that you never see come crazy setup like this on certified airplanes.
 Trim tabs on control surfaces work very well, and when you have an electric actuator on the stick, it makes a very ergonomic nice to fly airplane.   Before adding trim tabs though, you do need to do your homework and make sure you are not going to make a mistake that is going to kill you.   The electric trim tabs on the Skyboy that I flew were not in the design, but they were well worth the effort and made a very nice flying airplane out of it.   The work was done by some airline mechanics that knew what they were doing.  I will be copying their installation on my plane.  I have gotten every bit of information on trim tabs that I can, and am confident that my Kolb would be a much nicer airplane to fly with them.   John H is correct, modifying a known design is risky and not done correctly could be fatal, so I would recommend that no one try this type of modification unless they do proper research and have the ability to do it correctly.
 Mike Bigelow
				 Posted: Wed Dec 05, 2007 6:00 am    Post subject: Elevator trim tab information needed |
				The first time I laid eyes on the MkIII trim system I also thought it
 was a goofy looking contraption.
 But being much too busy rebuilding the plane, I was willing to give
 it a try.
 Works perfect. I think the reason for no flutter problems is that the
 entire horizontal assembly,
 including the elevator is under load.  If you used a tab you might
 actually reduce that load
 in the wrong place and end up with flutter.
 Looks better too without extra crap hanging outside.
 BB, plowed out from one foot of white stuff.
		planecrazzzy Guest
				 Posted: Wed Dec 05, 2007 4:01 pm    Post subject: Re: Elevator trim tab information needed |
				Oooooh,
              I see , you know everything....and "I'm" a liar
      Whatever...
  Gotta Fly...
  	  | JetPilot wrote: | 	 		  An electric trim does not cause flutter.   A failure that would drive an electric motor back and fourth is unheard of,
 Mike Bigelow |
		Michael Sharp
  Joined: 10 Jan 2006 Posts: 118 Location: Oak Grove, MO (Kansas City)
				 Posted: Wed Dec 05, 2007 6:41 pm    Post subject: Elevator trim tab information needed |
				No Mike, YOU ARE NOT!
   I've seen several of electric motors flutter back and forth...
   Seems to me that if someone wants a "real airplane" maybe they should have bought one...
   Mike
 planecrazzzy <planecrazzzy(at)yahoo.com> wrote:
 Oooooh,
 Whatever...
  _________________ The air up there in the clouds is very pure and fine...And why shouldn't it be?-
--It is the same the angels breathe.
                                     Mark Twain,
                                     Roughing it' 1886
Mike |
