Posted: Thu Dec 06, 2007 12:51 pm Post subject: closing up the bottom wing skin. |
Silly question-
What position have people placed the wing in to try to get interior access to all the rivets with the bucking bar. Seems with the wings in the craddle, my arms are not long enough to reach those rivets at the rear spar area, or did everyone get a helper with the rivets?
John G. 409
mritter509(at)msn.com Guest
Posted: Thu Dec 06, 2007 1:44 pm Post subject: closing up the bottom wing skin. |
Absolutely - get help and bandages. Make sure women and children are out of hearing range.
Mark
N410MR
<html><div></div></html>
| Quote: | From: indigoonlatigo(at)msn.com
Subject: RV10-List: closing up the bottom wing skin.
Date: Thu, 6 Dec 2007 11:47:17 -0800
.ExternalClass .EC_hmmessage P {padding:0px;} .ExternalClass EC_body.hmmessage {font-size:10pt;font-family:Tahoma;} Silly question-
John G. 409
blank>http://www.matronics.com/contribution
get=_blank>http://www.matronics.com/Navigator?RV10-List
p://forums.matronics.com
| Get the power of Windows + Web with the new Windows Live. Power up! [quote][b]
Tim Olson
Posted: Thu Dec 06, 2007 1:48 pm Post subject: closing up the bottom wing skin. |
With the bottom skins? Definitely a helper.
Laid them flat on the bench, but lots of ways would
work, with a helper.
John Gonzalez wrote:
| Quote: | Silly question-
John G. 409
orchidman
Joined: 10 Jul 2006 Posts: 277 Location: Oklahoma City - KRCE
jchang10
Posted: Thu Dec 06, 2007 2:09 pm Post subject: closing up the bottom wing skin. |
Do you have to remove the control tubes to rivet the bottom skins on?
Jae
40533
orchidman wrote:
I guess if you are a small framed person you might have problems reaching. I did mine while they were on the cradle by my self I found that holding both the bucking bar and the gun, I was able to get better control. But it does take some real contortions to get into position for some of them. [Shocked]
If you have a helper available great.
Gary Blankenbiller
RV10 - # 40674
Fuselage SB
(N410GB reserved)
_________________ #40533 RV-10
First flight 10/19/2011
Phase 1 Done 11/26/2011 |
ron.mcgann(at)baesystems. Guest
Posted: Thu Dec 06, 2007 2:12 pm Post subject: closing up the bottom wing skin. |
John,
I did mine solo with the wings in the cradle - some were a challenge but I'm very happy with the results. I'm 5'9" and my knuckles don't drag on the floor. I used safety wire to hold the skins up and out of the way to access the rear spar rivets. I borrowed the idea from Deems - see his web site.
cheers,
Ron
187 finishing
[quote] From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of John Gonzalez
Sent: Friday, 7 December 2007 6:17 AM
Subject: closing up the bottom wing skin.
Silly question-
John G. 409
"Warning:
The information contained in this email and any attached files is
confidential to BAE Systems Australia. If you are not the intended
recipient, any use, disclosure or copying of this email or any
attachments is expressly prohibited. If you have received this email
in error, please notify us immediately. VIRUS: Every care has been
taken to ensure this email and its attachments are virus free,
however, any loss or damage incurred in using this email is not the
sender's responsibility. It is your responsibility to ensure virus
checks are completed before installing any data sent in this email to
your computer."
thane
Posted: Thu Dec 06, 2007 2:26 pm Post subject: closing up the bottom wing skin. |
Did all botom skins by myself, but have long arms. But did end up with rivet rash on arms.
So it can be done, just do what it takes to have a nice result.
Thane
N321BY
_________________ Working on finish kit: I hate fiberglass!! |
Tim Olson
Posted: Thu Dec 06, 2007 2:48 pm Post subject: closing up the bottom wing skin. |
I sure would...makes it easier. Removing them is a snap.
Well, actually more of a twist of a nut.
Jae Chang wrote:
Jae
40533
> position for some of them. [Shocked] If you have a helper available
> great.
> Gary Blankenbiller
> RV10 - # 40674
> Fuselage SB
> (N410GB reserved)
rv10(at)sinkrate.com Guest
Posted: Thu Dec 06, 2007 2:50 pm Post subject: closing up the bottom wing skin. |
I did. You need to room to get your arm in there.
jeff(at)westcottpress.com Guest
Posted: Thu Dec 06, 2007 2:54 pm Post subject: closing up the bottom wing skin. |
I did it all myself John... and though my arms are quite long I don't think that came in to play much. The bottom skins are much easier to rivet than they look. I avoided it for a few days, but once I started I couldn't remember what all the fuss was about. I kept the wings in the cradle the whole time.
Jeff Carpenter
40304
John G. 409
| Quote: | http://www.matronics.com/contribution
Posted: Thu Dec 06, 2007 4:59 pm Post subject: closing up the bottom wing skin. |
Flat on the bench is what seems to work best, with a helper at least. Haven't seen them done or tried to do them solo, but it sounds like it can be done. What we have found is that taping some foam around the bucking bar except the face that hits the rivet is also helpful in case you drop it.
[img]cid:F3B9DE18-C99D-4564-AB42-2F56EE93B8A7(at)cpe.satnet.net[/img]
DSC_1725
Jesse Saint
Saint Aviation, Inc.
Cell: 352-427-0285
Fax: 815-377-3694
John G. 409
66.28 KB |
404 Time(s) |
dlm46007(at)cox.net Guest
Posted: Thu Dec 06, 2007 5:15 pm Post subject: closing up the bottom wing skin. |
Ditto on taping the bucking bar; we use small pieces of silicone baffling material to protect adjacent surfaces from the stray trajectories of the bucking bar. Also when two surfaces are not clamped tightly together before riveting, it is sometimes necessary to use a draw bead made of silicone rubber to set the rivet so that the first strike of the rivet gun sets them together. I believe I sent pictures of a draw bead and described its use in previous posts.
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Jesse Saint
Sent: Thursday, December 06, 2007 5:17 PM
Subject: Re: closing up the bottom wing skin.
[img]cid:098040901(at)07122007-21F4[/img]
DSC_1725
Jesse Saint
Cell: 352-427-0285
Fax: 815-377-3694
John G. 409
66.28 KB |
409 Time(s) |
