Aerosport Testimonial - long
Goto page 1, 2  Next
Tim Olson
PostPosted: Thu Dec 06, 2007 1:56 pm    Post subject: Aerosport Testimonial - long Reply with quote
Just had to post this after this week's experience...
About a year ago when I went to replace my spark plugs
and inspect them, I found clean oil in my #4 cylinder.
That of course got me worried at the time, but talking
to a few people they said that if the piston ring
gaps line up, the oil can bleed through and this may
be what happened as they felt it's something they've
heard of before. At ACI time, I did my compression
test and that was also my lowest cylinder, at 74, while
my others were at 77-79 in general. Considering
that this is still good compression and everything
was running great, I just kept my eyes and ears open
and went on. Considering how well it ran, and how low
the oil consumption was, it wasn't alarming. That
lower plug in that cylinder also had more deposits,
that I attributed to the oil fouling. I switched
to fine-wire plugs back then too.
One note I should add is that I probably also ran my
engine less hard during break-in than I should have,
so I've always wondered if I did a good job on the
break in or not. Seems to be ok.
On one of my last couple flights, I was run LOP and
noticed #4 had a blip of rise and fall in EGT,
and the a subsequent drop in CHT. Running LOP,
a rising EGT would mean a richening mixture. And,
a rising EGT can also be because of an ignition
issue where a plug isn't firing as well. I flew 5
or 6 more hours and monitored it. The CHT on that
cylinder stayed slightly lower than before, and
the graphs I downloaded from my Chelton showed a
difference in the curve I got when I leaned that
cylinder. Of course, with cylinder suspicions,
ignition suspicions, and even injector suspicions,
it was time for some troubleshooting. Adding to that,
my previously very good oil consumption was now
drastically up, to something like 1 qt in 2 hours,
as opposed to 1 qt in maybe 8-15.
I thought it best to troubleshoot the external things
first, and then the cylinder, since I knew them
a little better. The Lightspeed was super consistent
in run-up, and wasn't a problem because a coil failure
would affect 2 cylinders. The mag was a possibility,
but how does a mag just affect one cylinder...other than
the ignition lead. I pulled the harness and
checked the cap inside the mag and nothing was
odd. I also pulled the injector and cleaned it and
found nothing. I replaced my cheap top plugs, and
cleaned the bottom. No significant deposits except
for on #4 again. So, it was on to the cylinder.
I called Bart at Aerosport and he gave me a
troubleshooting tip to do in addition to a compression
test again. Run the engine and make sure it's fully
warmed up and operating fine in flight. Then land
and pull both the top and bottom plugs and look into
the cylinder. With dual plugs you can shine a light
in one and see into the other and see a LOT.
Look for consistency among cylinders in how the
piston looks in regards to dryness. There should be
a slightly damp ring around the outer edge of the piston,
but dry towards the center. Bingo! My #4 piston was
all oily damp, but the others were normal with that
faint ring. Compression was still 74 or so. So now
I knew where that oil was going.
Pulled the cylinder, which was very easy (total job
about 1.5 hours for that cylinder). Upon removal,
my local A&P who came to hang out and offer advice
noted an issue with the rings. Additionally, the
gap on the top ring was at the 6 o'clock position
and the bottom was at the 6:30 or 7 o'clock, so
indeed the rings had lined up quite a bit.
Prior to removing the cylinder, I had talked to
Bart and he assured me that he'd take care of it.
Not that he'd do it cheap, or he'd try to fit it
in, but that he'd take care of it for me, and turn
it around the same day. I decided that with Christmas
coming and my father coming who would want to go flying,
that I'd overnight it to Aerosport. Customs caused
me a delay, so it took 2 business days...oh well.
But, Bart got the cylinder, checked it out and found
that the top ring was bad. It sounded to me like
there was a gouge out of it or something. He said
that would cause more pressure differentials in the
engine and cause increased oil use, and affect the
job the other rings would do too. He also touched up
my valves, replaced the piston, and weighed the items,
and basically reworked the cylinder to be ready for
a new break-in period. He turned it around same-day,
as promised, and shipped it FedEx Priority overnight
right back to me, along with a 1-cylinder seal kit,
and LOTS more hardware than I asked for or needed,
including 6 new exhaust gaskets. Not only that,
but he REFUSED to take payment for it, or for the
upcharge for quick shipping. He just wanted to make
sure I was going to have it working good. I feel
so guilty that I'm going to try to figure out a
way to send them something they can't return.
I haven't flown with it yet, but heck, even if
something is still wrong, I know it ain't the cylinder.
So what did I learn? LOTS! #1, when it comes time to
overhaul my engine, it's going back to Bart. How could
I NOT do that....I've never heard them do anyone wrong,
and they certainly did more for me than I would have
asked for. #2, there's a beauty in the simplicity of a
Lycoming....when I had a cylinder issue, I just removed
that one cylinder. It was easy. And, there are places
that will be happy to overhaul things and get them
back the same week. In fact, in my case it went to
a different country and came back within a half week.
Try doing a single-cylinder job on an auto conversion,
and having the job be this small. #3, Don't skimp on
running your engine hard on break-in. I'm not sure if
I ever did a good job, so I'm glad to get a 2nd chance
this time. #4, I'm very glad that with what I have,
there's plenty of god advice out there on troubleshooting.
It's nice having a "standard" engine, because sometimes
it's that one simple tip that can save you lots of
time. #5, I ABSOLUTELY could not have noticed the
inconsistency, as it still ran well, without a full
6-cylinder engine monitor that feeds my Chelton and allows
me to download the data and graph it with "EGview".
I was able to take some flights, and crank up the scale
on my EGT's and stretch the graph out and track down
the exact instance in time when my EGT's rose, and KNOW
with CERTAINTY that it was something that was not right.
The engine still performed really good, but without
knowing my past temperature trend history (i.e. little
things, like num 3 was usually just a few degrees cooler
than num 4, but now 3 was 5 deg to 25 deg low) I would
have never flagged the engine and decided to dig in and
diagnose something that you couldn't really feel. The
engine logs and display were a HUGE benefit.
I just thought I'd share. It was a whole new experience
for me.
deej(at)deej.net
PostPosted: Thu Dec 06, 2007 3:52 pm    Post subject: Aerosport Testimonial - long Reply with quote
Hi Tim!
Since you couldn't resist mentioning the auto conversion, I can't
resist offering a good natured reply and offering some of my own
personal observations. Smile
In the 24 years or so that I've been driving, I've never once had to
have any cylinder, piston, or valve work done on any of the cars that
I've owned. In the 7 years that I have been flying, both airplanes that
I have owned have had to have engine work, one with the replacement of a
cylinder, piston and rings, and the other with valve problems.
From my perspective, it is rather dismaying that you have had to have
minor top end work done on your engine with just over 300 hours on it,
and in fact it was a year ago that it started to have issues, so you
actually had far less hours on it at the time.
On the positive side, Aerosport definitely gave you great customer
service! Hopefully you will be able to get everything back together and
running so you can take your Dad up flying. One of my fondest memories
was when I took my Mom up for her first flight with me.
-Dj
Dj Merrill
Sportsman 2+2 Builder #7118
http://deej.net/sportsman/
"Many things that are unexplainable happen during the construction of an
airplane." --Dave Prizio, 30 Aug 2005
scottmschmidt(at)yahoo.co
PostPosted: Thu Dec 06, 2007 5:13 pm    Post subject: Aerosport Testimonial - long Reply with quote
It is hard to compare airplanes and cars.
If we all drove our cars around at full throttle, it wouldn't make it a week, maybe not even a day.
Bart and Sue are two of the best in this industry.
He probably didn't want your money because the exchange rate has made the American dollar worth nothing to him.
-Scott Schmidt
deej(at)deej.net
PostPosted: Thu Dec 06, 2007 6:13 pm    Post subject: Aerosport Testimonial - long Reply with quote
Hi Scott,
Do you have any data on this? I keep hearing people say this but I
can't seem to find any actual data to back it up. I'd greatly
appreciate it if you would be willing to send any information that you
have to help me in my research. I'm trying to learn as much about this
stuff as I can.
Since the autoconversions are not flown at full throttle but rather in
the vicinity of 4000 RPM it doesn't really apply to the aircraft
application, but I'm still interested to see if one did want to run it
full throttle in a car just how long it might last.
I've found some useful information on this web page
http://www.sdsefi.com/air51.htm
but it would be great if someone had more information to share about it.
-Dj
Dj Merrill
rv10builder(at)verizon.ne
PostPosted: Thu Dec 06, 2007 6:22 pm    Post subject: Aerosport Testimonial - long Reply with quote
That and a 3 year warranty for parts and labour he stands by.
Pascal
Tim Olson
PostPosted: Thu Dec 06, 2007 6:55 pm    Post subject: Aerosport Testimonial - long Reply with quote
We could have a little competition...
How about we go out and gather firsthand reports from 20 Lycoming
owners that made it 2000 hours with no work, and we go out
and find 20 of ANY single auto conversion engine owners out there
that needed no work after 2000 hours. Wink
I don't know, I know what you're saying...the engines may be
tough, but today I wound out my 4.3L to 3500rpm and tried to keep
it there for a short time. It wasn't very comforting to hear that
thing winding away like that. I know, I know, they should be
able to handle it....but man, that's why they build transmissions
on cars.
I certainly wasn't happy to have any work done. But on the same
token, I can't blame the engine design, or the builder for it.
Perhaps it's from having looser tolerances to allow for the
expansion, but while talking about the subject with the A&P as
we pulled the jug, he told me he sees planes all the time that
have gone to TBO with no work. Starting an engine up is kind
of a crapshoot. I've had tough diesel engines that threw
rods, cracked pistons, and of course my least favorite stranding
I've ever had was when a timing belt blew, throwing my valves
into my pistons on a car I had. You just never know.
I'm just glad that it ended up being so easy to work on. I can
see now why they kept the design...it's really a piece of
maintenance simplicity from a standpoint of the jugs, which are
the part you'd have to work on more than the others anyway.
Hi Scott,
stuff as I can.
-Dj
jesse(at)saintaviation.co
PostPosted: Thu Dec 06, 2007 7:05 pm    Post subject: Aerosport Testimonial - long Reply with quote
I hate to get into this discussion, but just to throw in another point
of view.
How many GPH does the IO-540 burn at full throttle? About 26, give or
take a few, right? How many GPH does everybody burn in cruise? I
know Tim is usually in the 9-12 range, right? My dad keeps it under
10 almost always and very often it is below 8. This is not anywhere
near full throttle. I remember talking to Vic and I seem to remember
he said he was averaging about 13. What are the recommendations for
max continuous power for longest engine life? I am not by any means
an expert, and it could very well be that aircraft engines are built
to handle a higher percentage of continuous power. I know in turbo
models they often run a lot higher power, but I also seem to hear
stories of TIO's not getting the same life as IO's.
I am definitely in the club of going with a standard engine that the
plane was designed for from the start, but I also agree that those who
want to experiment have every right to do so (with the usual caveats
and disclaimers understood) in this experimental amateur-built
category. When someone talks to me about helping them with a plane
with an alternative engine installation, I usually say that I am not
interested in the R&D involved, but that's just me.
Jesse Saint
Saint Aviation, Inc.
jesse(at)saintaviation.com
Cell: 352-427-0285
Fax: 815-377-3694
> it a
Hi Scott,
this
stuff as I can.
in
it.
-Dj
Dj Merrill
of an
deej(at)deej.net
PostPosted: Thu Dec 06, 2007 8:43 pm    Post subject: Aerosport Testimonial - long Reply with quote
Okay, you do the Subaru conversions, and I'll do the Lycomings... Smile
Honestly I was not (and am still not) trying to stir the pot. It is
just that reports like yours is one of the main reasons why I started
looking at Subaru conversions. I had two bad experiences (at 800 hours
on one engine, and about 1050 or so on the other). My local shop often
had a Lycoming engine in for top end work. It really started bothering me.
You are right, there are some engines that will make it to TBO, but I
just feel like it is a crap shoot. You had to do work at 300 hours, but
Jesse might make it all the way to TBO. There just doesn't seem to be
any good reasoning why one engine might make it and one might need
work. I'm fairly certain you take good care of your airplane and
engine, and it is unlikely that it was something that you did that
caused the problem (or was it? *grin*).
The Subaru might have problems as well. When it comes down to it, most
of us make decisions based on our personal experiences. None of my cars
has ever had to have engine work, and both of my airplanes have. It
might be irrational reasoning, but the picture in my head is tending
towards Subaru engines being more reliable than a typical Lycoming.
That's why I've been asking around for actual data and test results, if
anyone has any to share or can point me in the right direction. My
science background is telling me that I need real data, not subjective
WAGs... Smile
-Dj
Dj Merrill
Phil.Perry(at)netapp.com
PostPosted: Thu Dec 06, 2007 9:08 pm    Post subject: Aerosport Testimonial - long Reply with quote
Comparing a car engine to an aircraft engine isn't a fair comparison.
If you want to compare flying auto-conversions to Lyco's, then that's
fine.
1) How many of us driving V6's or 8's have temp gauges in every
cylinder? - none
2) How many of us have temp gauges installed in every exhaust port? -
none
3) How many of us know every idiosyncrasy our car engines to recognize
when 1 cylinder is showing unusual signs of trouble? - none
My point is that we don't care about our care engines like we care about
our aircraft engines. As long as they run, we're happy. We really
don't give a damn if they're running absolutely perfectly. Who cares if
they have a weak or leaky cylinder that we don't know about? The truth
is, when it comes to cars, what you don't know doesn't hurt you.
It's a whole different ballgame when it's your life. Or your wife's
life. Or your kids life. We all want to know EVERYTHING about our
aircraft engines. We keep our eyes open for ANY trends that could tip
us off to a failing engine. We keep them tuned meticulously, we
maintain them meticulously, we install sensors in the heads, we install
sensors in the exhaust, we know what our temps should be when things are
right - we also know when something doesn't look right.
We don't have that level of detail in our cars, so we don't do that with
our cars. I'd bet that if we all could examine our car engines in
aircraft-level-of-detail, nearly all of us would be driving on engines
that are out of our airplane-worthy standards.
So when I hear someone try and use the 'my car hasn't broken down'
argument, I let it go in one ear an out the other.
That's a terrible data point simply because you have no data to tell me
exactly what the health of your car engine really is. As long as the
check engine light stays off, we're happy.
We don't watch our car engines like a hawk, but we do when they go into
the airplanes that will be carrying our family.
Phil
pitts_pilot(at)bellsouth.
PostPosted: Fri Dec 07, 2007 5:53 am    Post subject: Aerosport Testimonial - long Reply with quote
Good valid points Phil. Knowledge is power! However, we live in a statistical world, and having something happen/not happen to you personally doesn't make statistical sense. What makes more sense is knowing that something has happened to someone somewhere. There are those that haven't had engine failure in XXX,000 miles, but I'll bet they've seen one or know someone whose car has been in the shop. Yep, apples to oranges. I don't care for a Lycosaurs lack of modern improvements, but they seldom fail catastrophically fail ..... or we'd have something different up front. No, no hard data, which won't sway anyone one way or the other which isn't my intent anyway. Our car engines have become more sophisticated ...... they're more efficient, last longer, and DO have a lot of instrumentation ....... which the computer uses. All we get in our newer cars is an idiot light or a guage or two ..... but the computer is gathering data everywhere and making operating adjustments on the fly. However, a Lycosaur is rock simple and anyone with a socket set, mic and a hammer and a few wrenches can rebuild one to some level of specification, and while they're at it upgrade the few wires that control it. We wouldn't think of replacing the wiring harness or the vacuum system on a car engine 'till it's broke, and the ability (cost) of the 'mechanic' to find the fault and fix it the first time is rare. They do have the ability (sometimes) to download engine operating parameters to their shop analyzer which can make a better educated guess than most mechanics (not knocking them, just an observation) and lower the trips to the parts counter. I like my rock-simple, although ancient tecknology, Lycosaur and am not contemplating an alternative engine, but I surely won't denigrate those who want to follow that path. I applaud their ability to think outside of the box and come up with (in their mind) the rationale that justifies the time, expense, and yes, the trials and tribulations that go along with being a different drummer. Please remember that if it wasn't for those innovators out there, we wouldn't have the neat stuff in our panels or pre-punched kits or ..... well, you get the picture. For me, I wish them well (and longevity) and hope they share EVERYTHING that goes on in their search for an alternate power source. Best of luck to everyone out there ..... the ones that do and the ones that don't .... have something different under the hood.
Linn ..... sorry for the long rant .... I was on a roll!
do not archive ....
Perry, Phil wrote:
[quote] [quote]--> RV10-List message posted by: "Perry, Phil" <Phil.Perry(at)netapp.com> (Phil.Perry(at)netapp.com) Comparing a car engine to an aircraft engine isn't a fair comparison. If you want to compare flying auto-conversions to Lyco's, then that's fine. 1) How many of us driving V6's or 8's have temp gauges in every cylinder? - none 2) How many of us have temp gauges installed in every exhaust port? - none 3) How many of us know every idiosyncrasy our car engines to recognize when 1 cylinder is showing unusual signs of trouble? - none My point is that we don't care about our care engines like we care about our aircraft engines. As long as they run, we're happy. We really don't give a damn if they're running absolutely perfectly. Who cares if they have a weak or leaky cylinder that we don't know about? The truth is, when it comes to cars, what you don't know doesn't hurt you. It's a whole different ballgame when it's your life. Or your wife's life. Or your kids life. We all want to know EVERYTHING about our aircraft engines. We keep our eyes open for ANY trends that could tip us off to a failing engine. We keep them tuned meticulously, we maintain them meticulously, we install sensors in the heads, we install sensors in the exhaust, we know what our temps should be when things are right - we also know when something doesn't look right. We don't have that level of detail in our cars, so we don't do that with our cars. I'd bet that if we all could examine our car engines in aircraft-level-of-detail, nearly all of us would be driving on engines that are out of our airplane-worthy standards. So when I hear someone try and use the 'my car hasn't broken down' argument, I let it go in one ear an out the other. That's a terrible data point simply because you have no data to tell me exactly what the health of your car engine really is. As long as the check engine light stays off, we're happy. We don't watch our car engines like a hawk, but we do when they go into the airplanes that will be carrying our family. Phil --
bhughes(at)qnsi.net
PostPosted: Fri Dec 07, 2007 6:43 am    Post subject: Aerosport Testimonial - long Reply with quote
Not all auto conversions have cylinders Smile
Sorry I just could not resist.
Bobby
msausen
PostPosted: Fri Dec 07, 2007 7:22 am    Post subject: Aerosport Testimonial - long Reply with quote
Wait, you want real data and you went with an Egg?!? The man who refuses to do any dyno runs and estimates his power output while (re)engineering on the fly after he sold a package and then routinely delivers a year late?!? Sorry man, I still like the idea of auto conversions but I just had to point that out. One of Eggs chief reasons for not having any resemblance to a standardize configuration is that the engine changes every year. Yet he is usually 1-2 years behind a production run from the factory on delivery.
So something else to think about. Comparing a 500ish engine production run to 10's of thousands doesn't really give any real sense of reliability until you do some averaging for real maint vs operational hours. I don't believe anyone has actually done that.
I think Eggs engine has its place but it's not in heavy 4 seat aircraft. The Sportsman is probably as big as I would consider.
Michael
mritter509(at)msn.com
PostPosted: Fri Dec 07, 2007 9:13 am    Post subject: Aerosport Testimonial - long Reply with quote
Spoken like a true rotor head. When are you bringing your 10 to the airport for final assembly?
Mark
RV-10/N410MR
<html><div></div></html>
> Subject: RE: Aerosport Testimonial - long
[quote] Date: Fri, 7 Dec 2007 08:32:21 -0600
--> RV10-List message posted by: "Bobby J. Hughes" <bhughes(at)qnsi.net>
Bobby
GRANSCOTT(at)aol.com
PostPosted: Fri Dec 07, 2007 9:18 am    Post subject: Aerosport Testimonial - long Reply with quote
In a message dated 12/6/2007 7:15:22 PM Central Standard Time, scottmschmidt(at)yahoo.com writes:
DJ...
How often do you accelerate your auto, from ground level to 2-4 miles above the surface from where you started and how often does your car's engine experience rapid temperature and pressure changes to it's block, and once you start your car's engine do you immediately put the hammer down to max RPM to get out of your driveway and then reduce power to 65-80% of it's maximum power out put while giving the engine varying amounts of oxygen to react with?
There are many engines that will run for years and up to and beyond TBO's without overhauls, but there are some that need more attention than others. If you want to get maximum performance from your engine, fly it as often as possible, daily if possible; change the oil and filter frequently and enjoy the scenery below!
Check out AOL Money & Finance's list of the hottest products and top money wasters of 2007.
PostPosted: Fri Dec 07, 2007 9:19 am    Post subject: Aerosport Testimonial - long Reply with quote
In a message dated 12/6/2007 8:16:54 PM Central Standard Time, deej(at)deej.net writes:
I've flown for years behind a 235hp O-540, the engine made TBO at 2,000+ was rebuilt and is now about 650 hrs, it's a tough little engine...but if one looks at the record of the same block producing 300+hp the reliability of the engine is not quite as likely to make TBO without a top along the way. Talk to owners of Cherokee 235 and Cherokee 6's (300)...both have O-540's in them. I think we've yet to see many good auto engine conversions...the Mooney Porsche was probably the largest "experiment" in regular GA aircraft.
P
bhughes(at)qnsi.net
PostPosted: Fri Dec 07, 2007 9:36 am    Post subject: Aerosport Testimonial - long Reply with quote
Hopefully after Christmas and before New Years. It would help if I would stop finding ways to improve the radiator ducts Sad
Bobby
(Never, every, every build a custom cowl)
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Mark Ritter
Sent: Friday, December 07, 2007 10:00 AM
Mark
RV-10/N410MR
Bobby
-----Original Message-----
[mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Dj Merrill
Sent: Thursday, December 06, 2007 5:18 PM
Subject: Re: Aerosport Testimonial - long
--> RV10-List message posted by: Dj Merrill <deej(at)deej.net>
Tim Olson wrote:
> Try doing a single-cylinder job on an auto conversion, and having the
> job be this small.
Hi Tim!
can't resist offering a good natured reply and offering some of my own
had to have any cylinder, piston, or valve work done on any of the cars
that I've owned. In the 7 years that I have been flying, both airplanes
that I have owned have had to have engine work, one with the replacement
of a cylinder, piston and rings, and the other with valve problems.
have minor top end work done on your engine with just over 300 hours on
it, and in fact it was a year ago that it started to have issues, so you
customer service! Hopefully you will be able to get everything back
together and running so you can take your Dad up flying. One of my
fondest memories was when I took my Mom up for her first flight with me.
-Dj
Dj Merrill
&g==============
You keep typing, we keep giving. Download Messenger and join source=CRM_WL_joinnow' target='_new'>Join in! [quote]
href="http://www.matronics.com/contribution">http://www.matronics.com/chref="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com/Navigator?RV10-List
Tim Olson
PostPosted: Fri Dec 07, 2007 9:39 am    Post subject: Aerosport Testimonial - long Reply with quote
Dj,
I'm glad that you know me and I know you and we have no worries
that this stuff is intended to offend anyone. I have fun with
the discussion, and any kind hearted jabs, so it's all good.
Regarding service during the lifetime, actually, this is the first
time in my life that any aircraft engine has given me issues.
So, it's new to me, but certainly the track record of Lycoming
and Continentals isn't all good. Esp. recently, in the crank
department. But, given the fact that you can indeed run these
engines at 100% power, and run them extended at 75-85% power,
I certainly don't expect them to be like a car that you can
milk to 200,000 or more miles. It's not living the life that
my old Nissan did.
But, looking at car histories, I've owned many cars in my
life....more than the average Joe, in fact. But none of
them ever has been run to the power and RPM extent (for any
extended time) that the auto conversion aircraft engines have.
If you could buy a car engine and run the thing without a
PRSU...do a direct drive auto conversion, I'd think that
success would be much easier to achieve...and that's success
in both longevity, and fuel economy. There are people with
VW engines, and corvair engines and things that run in
planes fine.
Now is where I have to be careful to not insult though...
I think a better comparison for service life for a
subaru isn't to compare it to a lycoming, but look at
some of the more equivalent situations. For instance,
compare it to the Rotax 912, or compare it if you're
staying land-based to things like a Snowmobile. An
aircraft engine conversion in a plane will NOT run anything
like a car engine will. My car doesn't even hit 2000rpm
in cruise at under 65mph. Towing my boat, I get 13mpg
in OD (not recommended) but boost that RPM over 3000
and pour on the power and I'm well under 10. It's just
the operational characteristic. My snowmobile doesn't
spend much time running slow...it's constantly being
pushed. (yeah, call me reckless) But, when you look
at those kinds of heavier uses, the outlook isn't so
shiny. I monitor the ArcticCat forum because I have
an issue with my 580 EFI sled right now. You see many
people with pistion, head, cylinder issues, and things
like that. I have a problem where a simple failure of
the coolant sensor caused my sled to finish spring 2007
after only 5 miles being put on it for the winter, to
end up parked in the middle of a field...because the
COMPUTER won't let it run. This same kind of thing
happened to my Nissan...a stinkin' sensor just made
it quit firing. Look at the Rotax service life. I
was a bit surprised to hear that the 4-strokes typical
rebuild is under 1000 hours. Yeah, just like the
auto conversion, it should be much cheaper, but it
does show that higher stresses put on engines don't
make for better longevity. This doesn't mean that you
won't get good life, or even beat me on the cost of
service for a 2000 hour total runtime, but I'd think
that my engine may at least spend a lesser number of
total days out of the air due to maintenance...because
one problem and you're likely to be down a long time.
You may, or may not, be able to pick up some of those
custom parts, and PRSU's, overnight, but any engine work
is going to require pulling the whole engine or at
least much more of it. So the task itself will be
larger. The point is, look at 4-stroke Rotax engines,
Boat engines, snowmobile engines, and things where
power is used more fully and you'll get a MUCH more
fair comparison in longevity to what you might see.
My Mastercraft has a 351 in it, but I know for certain
that the engine isn't going to make 2000 TBO. It runs
way too hard. I'm just glad it doesn't have electronic
controls on my old '88 MC, because the simplicity is
less likely to leave me stranded.
Sorry to drag on, but one of my first thoughts got
lost. Cooling. Looking at the many cars I have driven,
and in fact, 2 out of the 3 of our current cars, I've had
a very poor track record of cooling issues. My current
van won't hold coolant well enough to keep my heater
core filled. It can be hard to track down. (it should
be easier on a plane) My wife's car occasionally spews
over coolant out a relief valve, but doesn't seem to have
any other leaks. But, looking at past cars I've had
numerous issues with cooling leaks and water pump
seals and things like that. I know it gives better
heat stability so it's a good thing to have liquid
cooling, but it isn't a total panacea either. That's
probably the reason Lyc's need more clearances, is because
of heating and cooling. But, snowmobiles and boats
are liquid cooled too and it doesn't add tons to
their service life.
Anyway, that's all just misc. ramblings from a crazy
person who just got older today. I hope that people
who may be offended are using their Delete key effectively. Wink
WAGs... Smile
-Dj
speckter(at)comcast.net
PostPosted: Fri Dec 07, 2007 9:44 am    Post subject: Aerosport Testimonial - long Reply with quote
Because of the lack of volume in auto engine conversions vs Lycoming good hard data is very hard to come by. Additionally the data is not all measured and reported in a consistant way as to allow a good thorough analysis.
I would advise anyone going down the auto conversion road to understand that we know a whole lot less about conversions than we know about Lycomings. So as they say you are on your own.
The other factor is that the conversion business seems to have quite a few folks of less than stellar integrety. So many claims have been made and so many people burned that it is not for the faint of heart to go this route.
Good luck as you sort all this out.
Gary
Frozen in MN
Tim Olson wrote:
> --> RV10-List message posted by: Tim Olson
& gt; lo oking at Subaru conversions. I had two bad experiences (at 800 hours
[quote] on one engine, and about 1050 or so on the other). My local shop often
has ever had to have engine work, and both of my airpla nes ha the Co .matro [quote][b]
deej(at)deej.net
PostPosted: Fri Dec 07, 2007 10:22 am    Post subject: Aerosport Testimonial - long Reply with quote
Tim Olson wrote:
Dj,
That's why I wasn't worried about posting. I'm just trying to learn
as much about this as I can, and I was confident you would not take
offense at my reply.
You should see the responses when I asked about using mogas with 10%
ethanol in it... *grin* Yes, believe it or not, you can design an
aircraft fuel system to use this fuel safely, but it took me several
months of research to find out how to do it (and part of that solution
involves the use of the Subaru engine), along with several e-mail
conversations with the very few people that are doing research and
experimenting with ethanol based fuels. Actual data on this topic is
very hard to find, but opinions are as common as water in the NorthWest
right now... Smile
My ultimate goal is to have my Sportsman on amphibious floats, and
have the option of refueling at a boat marina. I also wanted to be able
to use the same fuel as an automobile, thinking along the lines of long
term availability. At this point I am fairly confident that I can
accomplish this.
-Dj
Dj Merrill - N1JOV
Glastar Sportsman 2+2 Builder #7118 N421DJ
nyterminat(at)aol.com
PostPosted: Fri Dec 07, 2007 11:42 am    Post subject: Aerosport Testimonial - long Reply with quote
I had an IO-540 in my Saratoga and at 1140 hrs it wound up being time for an overhaul due to the spalling on the camshft.
Bob
In a message dated 12/6/2007 8:16:54 PM Central Standard Time, deej(at)deej.net (deej(at)deej.net) writes:
P
Goto page 1, 2  Next
Page 1 of 2
