poneill(at)irealms.com Guest
Posted: Wed Dec 12, 2007 4:07 am Post subject: Question regarding wing root nut plate |
While trying to finish up some of the odd ball QB items remaining to be
done, I ran into a question.
I'm doing the top side nut plates which receive the screws when attaching
the wing root fairing are attached. The forward nut plates all go through
the wing walk doubler and are countersunk. The aft most nut plate #19 hole
is dimpled. I do not see mention of the preparation of the rivet holes for
this nut plate. Should this nut plate be riveted at the same time as the
rest, or is it dealt with later in the plans? If now, are the rivet holes
dimpled and the nut plate dimpled as well or is this prepared differently?
My apologies if I've missed the step in the plans. I've gone through it a
few times already and decided to ask the list for guidance before reading it
again and reviewing the future steps.
Best Regards,
Patrick #40715/N690CT
DAVELEIKAM(at)wi.rr.com Guest
Posted: Wed Dec 12, 2007 5:32 am Post subject: Question regarding wing root nut plate |
If you are talking about the upper aft nut plate, I riveted it at the time
and dimpled all the holes.
Dave Leikam
40496
Posted: Wed Dec 12, 2007 1:47 pm Post subject: Question regarding wing root nut plate |
Yup. That's the one. Thanks Dave!
Best Regards,
