Jabiru 3300 Schematic
Terry Phillips
PostPosted: Tue Dec 11, 2007 10:51 am    Post subject: Jabiru 3300 Schematic Reply with quote
On another forum, I found a reference to schematic Z21A for A/C with the Jabiru 3300 engine. I found Z21A.pdf on aeroelectric.com, but I cannot find a Z21A.dwg. Can anyone help me find the .dwg file?
Thanks.
Terry Phillips
Corvallis, MT
ttp44<at>rkymtn.net
Zenith 601XL/Jab 3300 slow build kit - Tail feathers done; working on the wings.
nuckolls.bob(at)cox.net
PostPosted: Tue Dec 11, 2007 11:55 am    Post subject: Jabiru 3300 Schematic Reply with quote
http://www.aeroelectric.com/PPS/ACAD_Architecture_Dwgs/Z21A.dwg
( -Thomas Paine 1776- )
Terry Phillips
PostPosted: Tue Dec 11, 2007 12:50 pm    Post subject: Re: Jabiru 3300 Schematic Reply with quote
Thanks, Bob.
Terry Phillips
Corvallis, MT
ttp44<at>rkymtn.net
Terry Phillips
PostPosted: Fri Dec 14, 2007 2:57 pm    Post subject: Re: Jabiru 3300 Schematic Reply with quote
The standard alternator for the Jabiru 3300 is rated at 20-amps.
Would a solid state relay, such as the AEC3030 or the Perhellion PowerLink Jr. III 35A Solid-State Relay, perform satisfactorily as the main battery contactor in the Z21A design?
Has anyone tried using a solid state relay as a battery contactor?
Terry Phillips
Corvallis, MT
ttp44<at>rkymtn.net
rob(at)hyperion-ef.com
PostPosted: Fri Dec 14, 2007 5:31 pm    Post subject: Jabiru 3300 Schematic Reply with quote
When I raised exactly the same point a couple of months ago in re: the Rotax
20A alternator, I was quickly reminded that the starter current is a wee bit
more than the 20A that the SS relay can handle.
Best regards,
Rob Housman
Irvine, California
Europa XS Tri-Gear
S/N A070
Airframe complete
Terry Phillips
PostPosted: Fri Dec 14, 2007 8:52 pm    Post subject: Re: Jabiru 3300 Schematic Reply with quote
Fri Dec 14, 07 06:31 Post subject: Jabiru 3300 Schematic
Best regards,
Rob Housman
Thanks, Rob.
Somehow I had it in my mind that the battery contactor just handled the alternator charge current. Now it's clear why they call it a "battery contactor." Back to the drawing board.
Terry
Terry Phillips
Corvallis, MT
ttp44<at>rkymtn.net
