DAVELEIKAM(at)wi.rr.com Guest
Posted: Mon Dec 17, 2007 9:44 pm Post subject: OAT probe location |
Has anyone installed their OAT probe on a wing? If so, where and how? I want to make this decision before I close my wings.
Dave Leikam
40496
N89DA reserved
ron.mcgann(at)baesystems. Guest
Posted: Mon Dec 17, 2007 10:06 pm Post subject: OAT probe location |
Hi Dave,
I mounted mine in a rubber grommet in the right wing centre inspection plate.
cheers,
Ron
187 Moving to the hangar !!
dmaib@me.com
Posted: Tue Dec 18, 2007 5:10 am Post subject: OAT probe location |
I have not installed mine yet, but plan to install it in the next to most outboard panel on the left wing.
David Maib
40559
Dave Leikam
40496
N89DA reserved
| Quote: | http://www.matronics.com/contribution
_________________ David Maib
RV-10 #40559
New Smyrna Beach, FL |
billderou(at)yahoo.com Guest
Posted: Tue Dec 18, 2007 9:04 am Post subject: OAT probe location |
I installed mine on the wing 18" outside the tip of the propeller in an inspection plate. Drilled a small hole and sealed with Proseal, added a connector for servicing. No issues.
Bill DeRouchey
N939SB, flying
David Maib <dmaib(at)mac.com> wrote:
[quote]I have not installed mine yet, but plan to install it in the next to most outboard panel on the left wing.
David Maib
40559
Dave Leikam
40496
N89DA reserved
[quote]http://www.matronics.com/contribution href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com/Navigator?RV10-List href="http://forums.matronics.com">http://forums.matronics.com
mike(at)learningplanet.co Guest
Posted: Tue Dec 18, 2007 9:42 am Post subject: OAT probe location |
On my RV-9A I installed the OAT probe in the left inboard access panel. It works great and it is removable for inspections and whatever.
There are a few pictures here:
http://www.my9a.com/finish15.asp#090905
Mike Schipper
RV-10 #40576 - Fuse - www.rvten.com
| Quote: | 0559
Dave Leikam
40496
N89DA reserved
GenGrumpy(at)aol.com Guest
Posted: Tue Dec 18, 2007 6:03 pm Post subject: OAT probe location |
Mine is in the left NACA vent, and it works great!
grumpy
N184JM
DO NOT ARCHIVE
In a message dated 12/18/2007 11:07:25 A.M. Central Standard Time, billderou(at)yahoo.com writes:
| Quote: | I installed mine on the wing 18" outside the tip of the propeller in an inspection plate. Drilled a small hole and sealed with Proseal, added a connector for servicing. No issues.
Bill DeRouchey
N939SB, flying
| Quote: | I have not installed mine yet, but plan to install it in the next to most outboard panel on the left wing.
David Maib
40559
Dave Leikam
40496
N89DA reserved
| Quote: | http://www.matronics.com/contribution href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com/Navigator?RV10-List href="http://forums.matronics.com">http://forums.matronics.com
://www.matronics.com/contribution">http://www.matronics.com/contribution
.matronics.com/">http://forums.matronics.com
[/b] |
See AOL's top rated recipes and easy ways to stay in shape for winter.
Posted: Tue Dec 18, 2007 8:10 pm Post subject: OAT probe location |
If you install the OAT anywhere inside the propeller diameter from front to tail it will be 10-15 deg F high. This is not important for the EIS (or other) engine monitor but it is very important for an EFIS or air data computer to calculate true airspeed correctly.
Bill DeRouchey
N939SB, flying
GenGrumpy(at)aol.com wrote:
[quote] Mine is in the left NACA vent, and it works great!
grumpy
N184JM
DO NOT ARCHIVE
Bill DeRouchey
N939SB, flying
David Maib
40559
Dave Leikam
40496
N89DA reserved
href="http://forums.matronics.com">http://forums.matronics.com ://www.matronics.com/contribution">http://www.matronics.com/contribution ="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com/Navigator?RV10-List .matronics.com/">http://forums.matronics.com [/b] |
John Ackerman
Joined: 19 Jun 2006 Posts: 130 Location: Prescott, AZ
Posted: Tue Dec 18, 2007 10:07 pm Post subject: OAT probe location |
not to mention the "i" word.John Ackerman 40458 Plugging along
do not arcive
On Dec 18, 2007, at 9:08 PM, Bill DeRouchey wrote:
[quote]If you install the OAT anywhere inside the propeller diameter from front to tail it will be 10-15 deg F high. This is not important for the EIS (or other) engine monitor but it is very important for an EFIS or air data computer to calculate true airspeed correctly.
Bill DeRouchey
N939SB, flying
GenGrumpy(at)aol.com (GenGrumpy(at)aol.com) wrote:
| Quote: | Mine is in the left NACA vent, and it works great!
grumpy
N184JM
DO NOT ARCHIVE
In a message dated 12/18/2007 11:07:25 A.M. Central Standard Time, billderou(at)yahoo.com (billderou(at)yahoo.com) writes:
Bill DeRouchey
N939SB, flying
David Maib
40559
Dave Leikam
40496
N89DA reserved
href="http://forums.matronics.com">http://forums.matronics.com |
See AOL's top rated recipes and | Quote: |
face="courier new,courier">http://www.matronics.com/contribution
| [b]
