jswanson(at)jamadots.com Guest
Posted: Tue Dec 18, 2007 12:07 pm Post subject: Cesnna split switch |
Can someone help me find the information I need to wire a split switch batt/
alt into Z16 Rotax 912. I only have one buss.
John S
CH701 rotax
nuckolls.bob(at)cox.net Guest
Posted: Wed Dec 19, 2007 5:58 am Post subject: Cesnna split switch |
At 02:50 PM 12/18/2007 -0500, you wrote:
| Quote: | Can someone help me find the information I need to wire a split switch batt/
John S
CH701 rotax
John, did the answer to this not come though?
A few days ago this exchange was posted
to the List . . .
At 11:43 AM 12/14/2007 -0500, you wrote:
I need help in wiring a cessna style split Master Switch Batt/Alt
into Z16 Rotax system. I'm using a single buss.
Not sure how to answer this. The S700-2-10
switch shown in Z-16 emulates the functions
of a split-rocker switch. I.e. wiring diagrams
for both switches is identical.
You might check the panel of a Cessna but
the switch as-mounted uses the right side
rocker as the battery master and the left
side as the alternator. A check with your
ohmmeter would confirm that the battery side
can be ON without having the alternator
side ON too . . .
Are there additional questions about this
problem you're trying to solve?
Posted: Wed Dec 19, 2007 8:20 am Post subject: Cesnna split switch |
Posted: Wed Dec 19, 2007 11:36 am Post subject: Cesnna split switch |
At 11:18 AM 12/19/2007 -0500, you wrote:
<jswanson(at)jamadots.com>
Posted: Tue Dec 25, 2007 3:46 pm Post subject: Cesnna split switch |
John S
CH701 rotax
John sent me his split-rocker switch so that I could
confirm my suppositions as to how it functioned.
I've published a little 2-pager on interchangeability
of the various toggle and rocker switch versions
in the 'Connection's Z-figures.
See:
http://aeroelectric.com/articles/Progressive-Xfr_Split-Rocker_Switches.pdf
John, I'll be mailing your switch back in the
morning.
