kearney(at)shaw.ca Guest
Posted: Wed Dec 19, 2007 4:52 pm Post subject: Instrument Panel Dimensions |
Hi
Over the past couple of weeks I have been playing with panel layouts. What I don’t know is what the exact center of vision is offset from the center of the RV10 stock panel. I have a pretty good idea of where it is but was wondering if anyone has an exact measurement.
I would hate to have my EFIS off center as it would annoy me to no end every time I flew.
Inquiring minds need to know…
Cheers & Merry Christmas to all
Les Kearney
#40643
C-GCWZ (reserved)
toaster73(at)embarqmail.c Guest
Posted: Wed Dec 19, 2007 6:49 pm Post subject: Instrument Panel Dimensions |
I don't have a number but it seemed to me for the GRT if the left edge of the efis aligned with the first screw to the left of the left panel rib that would center up the Horizon one.
-Chris
#40072 finish/panel/top/interior paint
bcondrey
Posted: Wed Dec 19, 2007 7:08 pm Post subject: Re: Instrument Panel Dimensions |
Center of pilot's view is about 1.125" inboard of the left panel rib.
Bob #40105
Posted: Wed Dec 19, 2007 7:19 pm Post subject: Instrument Panel Dimensions |
Off center being an annoyance is an interesting idea... but I've been flying behind an asymmetrical, off center steam gauge panel for awhile. Don't even think about it. Not sure an EFIS changes that. Inquiring minds want to know.
Symmetry is a beautiful thing - but it occurs to me that it's not as simple as a perfectly centered screen or array of gauges. There's a functional symmetry and a perceived symmetry and not sure what else.
The best looking panels seem to have the panels stacked in front of the pilot or split between pilot and copilot. But having to dip my head to see the bottom panel will annoy me to no end when in the clouds.
I just spent the day pasting instrument pics to my panel. Very interesting.
Bill Watson
40605
Les Kearney wrote: [quote]
Hi
Les Kearney
#40643
C-GCWZ (reserved)
| [b]
Posted: Wed Dec 19, 2007 9:01 pm Post subject: Instrument Panel Dimensions |
Thanks Bob
I was using my handy dandy laser level and estimated it was around there. It
is good to know what the "book" answer is so I can plan accordingly.
Cheers
Les
#40643
Posted: Wed Dec 19, 2007 9:30 pm Post subject: Instrument Panel Dimensions |
Bill
I have been playing with layouts, online, for a couple of weeks. What you select as an EFIS setup seems to drive the placement everything else. With the smaller GRT screens, you could have two independent efis screens side by side with the primary display directly in front and the second to the right displaying a moving map. That drives everything else to the right. The beauty of this is that it would allow the second efis to be used as a backup if the primary screen had a brain fart.
With the larger AFS Efis screens, it seems that the only reasonable layout is to have one centered in front of the pilot and one in front of the co-pilot. That would be fine if both seats had pilots. Otherwise, in the event of a failure on the pilot’s side, it would seem that using the co-pilots’ screen as a backup would be problematic.
Decisions, decisions…..
I just pickup up a copy of the Panel Planner software to help my panel design process. Embedded in the software is an article from Kitplane Magazine from 1999. I found the same article online (unfortunately without the pictures) but it still has a few pearls. I especially took note of the issues around positioning of switches. The following link will get you to the article.
http://www.accessmylibrary.com/coms2/summary_0286-9339593_ITM
Cheers
Les
#40643
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of MauleDriver
Sent: December-19-07 8:19 PM
Subject: Re: Instrument Panel Dimensions
Bill Watson
40605
Les Kearney wrote:
Hi
Les Kearney
#40643
C-GCWZ (reserved)
| Quote: | | href="http://www.matronics.com/contribution">http://www.matronics.com/contribution href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com/Navigator?RV10-List href="http://forums.matronics.com">http://forums.matronics.com |
0123456789 | Quote: | | href="http://www.matronics.com/contribution">http://www.matronics.com/contribution | 0 | Quote: | | href="http://www.matronics.com/contribution">http://www.matronics.com/contribution | 1 | Quote: | | href="http://www.matronics.com/contribution">http://www.matronics.com/contribution | 2 | Quote: | | href="http://www.matronics.com/contribution">http://www.matronics.com/contribution | 3 | Quote: | | href="http://www.matronics.com/contribution">http://www.matronics.com/contribution | 4 | Quote: | | href="http://www.matronics.com/contribution">http://www.matronics.com/contribution | 5 | Quote: | | href="http://www.matronics.com/contribution">http://www.matronics.com/contribution | 6 | Quote: | | href="http://www.matronics.com/contribution">http://www.matronics.com/contribution | 7 | Quote: | | href="http://www.matronics.com/contribution">http://www.matronics.com/contribution | 8 | Quote: | | href="http://www.matronics.com/contribution">http://www.matronics.com/contribution | 9 | Quote: | | href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com/Navigator?RV10-List | 0
bcondrey
Posted: Thu Dec 20, 2007 5:38 am Post subject: Instrument Panel Dimensions |
Les,
I also decided that I wanted the EFIS centered in front of the pilot seat. Like was suggested earlier, I have a second screen just to the right of that and a third centered on the right side front seat. This makes the radio stack a natural fit immediately right of the center panel rib. This sort of layout will likely require that you trim & reinforce the outboard panel rib(s) for clearance of the screen(s).
I also started out with Panel Planner and it was helpful. I was however disappointed to find out that the dimensional info isn’t quite right for the RV-10 panel. I iterated a couple of times with the folks to try to get it right but in the end used that only as a visual guide and manually measured/cut my panel. They may have updated the panel definition by now – that was last spring.
Bob #40105
(getting close…)
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Les Kearney
Sent: Wednesday, December 19, 2007 11:28 PM
Subject: RE: Instrument Panel Dimensions
Bill
Cheers
Les
#40643
Bill Watson
40605
Les Kearney wrote:
Hi
Les Kearney
#40643
C-GCWZ (reserved)
| Quote: | | http://www.matronics.com/Navigator?RV10-List |
| Quote: | | http://forums.matronics.com | 0123456789 | Quote: | | href="http://www.matronics.com/contribution">http://www.matronics.com/contribution | 0 | Quote: | | href="http://www.matronics.com/contribution">http://www.matronics.com/contribution | 1 | Quote: | | href="http://www.matronics.com/contribution">http://www.matronics.com/contribution | 2 | Quote: | | href="http://www.matronics.com/contribution">http://www.matronics.com/contribution | 3 | Quote: | | href="http://www.matronics.com/contribution">http://www.matronics.com/contribution | 4 | Quote: | | href="http://www.matronics.com/contribution">http://www.matronics.com/contribution | 5
