dhyde01(at)earthlink.net Guest
Posted: Wed Dec 19, 2007 4:38 pm Post subject: Audio isolation amp questions |
I've ordered the audio amp PCB from AEC but have a few questions based on reading rev J of the writeup.
I'd like to use this board to sum 3-4 mono inouts and two stereo inputs. At the most basic level I understand
the function of the board but get a little confused looking at the schematic. On the stereo schematic, page 1.7,
both inputs to the left signal amp (LM316) are labelled pin 3. Is the upper pin #2 and the lower #3 or vice versa?
Which leads to......
On the diagram where additional inputs are shown (p 1.8.1), am I correct in assuming that an additional stereo input
could be added by adding appropriate resistor/capacitor networks (and dummy load as required) into pin 3 of both amps
(or pins 3 right and 2 left depending on the answer above)?
Or maybe the first question should be: Is rev J the most current version?
Thanks in advance,
Dave 'Nauga' Hyde
nuckolls.bob(at)cox.net Guest
Posted: Wed Dec 19, 2007 8:50 pm Post subject: Audio isolation amp questions |
At 04:37 PM 12/19/2007 -0800, you wrote:
<dhyde01(at)earthlink.net>
No, I've updated one page of the data package to correct
the issues you've cited . . . and added a parts layout
view for the ECB you purchased (I still need to find
them . . . they're around here somewhere!). See:
http://www.aeroelectric.com/DIY/Audio_Iso_P1p7_K.pdf
The whole data package needs some attention with
respect to obsolete parts on Digikey but don't
have time right now. Your interpretation of what's
needed to add more inputs is, I believe, correct.
( -Thomas Paine 1776- )
Posted: Thu Dec 20, 2007 2:26 pm Post subject: Audio isolation amp questions |
Thanks for the response, Bob. I did a little more thorough search of the archives and found answers to everything in there (don't know why I couldn't find them for the past few days), but thanks for taking the time anyway.
Dave Hyde
