sarg314(at)comcast.net Guest
Posted: Sat Dec 22, 2007 10:51 am Post subject: prop bolt length |
I have a Catto 3 blade prop with the recommended Saber prop extension
(same one van's sells). It is delivered with 6" bolts. I need a 1/4"
spacer to get the distance between the 2 spinner bulkheads to match the
spinner and of course there's the 3/8" crush plate, the washers and the
4 5/16" thick prop hub.
When I add up the thickness of *everything* in the stack-up and add to
that the 0.435" by which the threaded portion of the prop extension is
recessed into the prop extension, I compute that only the last 1/2" of
threads on the 6" prop bolts are going to engage the threads in the prop
extension. Seems kind of skinny to me.
On the other hand, I think this is a typical installation. Is this
normal? Is it adequate?
Tom Sargent, RV-6A
| - The Matronics RV-List Email Forum - | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
