poneill(at)irealms.com Guest
Posted: Wed Dec 26, 2007 4:42 pm Post subject: DMC Daniels AFM8 - Positioners |
I picked up a DMC Daniels AFM8 (M22520/2-01) crimper from E-bay for use in
crimping d-sub pins.
As I understand it, these are the positioners for the commonly found
avionics connectors:
K13-1 for standard D-sub pins (male and female).
K41 for HD D-sub female
K42 for HD D-sub male
The crimp tool I purchased came with a K1-S positioner. Does anyone happen
to know what this positioner is used for?
I have been through the Daniel's site and done quite a bit of searching and
have all the specs on the tool, but I'm just curious as to which application
the K1-S accessory is useful.
As for the positioners I still need, does anyone have a source to recommend?
I'll keep an eye on E-bay for a short while, but will probably end up buying
direct from Daniels unless someone has a better recommendation. All the
avionics shops I looked at sell the DMC tools for more than the DMC web
site.
Best Regards,
Patrick
rv(at)thelefflers.com Guest
Posted: Wed Dec 26, 2007 5:18 pm Post subject: DMC Daniels AFM8 - Positioners |
We've probably been bidding against each other. :^) It seem there was a
rash of folks bidding on these and the AMP crimper after the class in
Columbus a couple weeks ago.
I purchased one over Ebay a couple weeks ago. I have a K13-1, but am
looking for the K41 and K42.
I noticed that the DMC site was considerably less than Stein or ACS too.
That's seems really odd to me. Usually Stein will sell for at least the
same as the vendor. I suspect the channel suppliers for the tools are not
competitive otherwise Stein would have had a similar pricing. I can't see
Stein selling a whole bunch of these, so I suspect he isn't getting great
discounts from the distributors.
If you find another source, let us know.
rjquillin
Posted: Wed Dec 26, 2007 5:24 pm Post subject: DMC Daniels AFM8 - Positioners |
At 16:40 12/26/2007, you wrote:
| Quote: | The crimp tool I purchased came with a K1-S positioner. Does anyone happen
Patrick,
I've got a ~3M pdf file that lists DMC tooling and pins. It's
searchable and there were 27 hits for K1S.
Don't remember where I got it and due to size I'm hesitant to post
for those on dial-up.
If you and your ISP's email system can handle the size, I'll fire it
off to you.
Ron Q.
nuckolls.bob(at)cox.net Guest
Posted: Wed Dec 26, 2007 5:44 pm Post subject: DMC Daniels AFM8 - Positioners |
At 05:24 PM 12/26/2007 -0800, you wrote:
Patrick,
I've got a ~3M pdf file that lists DMC tooling and pins. It's searchable
Don't remember where I got it and due to size I'm hesitant to post for
those on dial-up.
If you and your ISP's email system can handle the size, I'll fire it off
to you.
Ron Q.
Ron,
If you'll send me one, I'll post it to the website.
Bruce(at)glasair.org Guest
Posted: Wed Dec 26, 2007 9:48 pm Post subject: DMC Daniels AFM8 - Positioners |
Please send me a copy also.
Bruce
www.Glasair.org
rjquillin
Posted: Thu Dec 27, 2007 7:47 am Post subject: DMC Daniels AFM8 - Positioners |
At 17:43 12/26/2007, you wrote:
| Quote: | Ron,
The number of requests prompted me to again search for the link.
I think I found it...
https://www.dmctools.com/_pdf/Catalogs/ConnectorToolingGuide.pdf
Also the DMC site has some new tricks to help identify connectors,
pins and tooling since the last time I visited.
Ron Q.
jquinn3(at)gmail.com Guest
Posted: Thu Dec 27, 2007 11:05 am Post subject: DMC Daniels AFM8 - Positioners |
Ron,
Would like to get a copy of your pdf file - jquinn3(at)gmail.com (jquinn3(at)gmail.com)
On Dec 26, 2007 7:24 PM, Ron Quillin <rjquillin(at)gmail.com (rjquillin(at)gmail.com)> wrote:
[quote] --> AeroElectric-List message posted by: Ron Quillin <rjquillin(at)gmail.com (rjquillin(at)gmail.com)>
Patrick,
