		alaskajim(at)cox.net Guest
				 Posted: Fri Dec 28, 2007 7:37 am    Post subject: Quick Question |
				Does anyone know if a regular (whiskey) compass is required equipment if
 your aircraft has an EFIS system like the Enigma?
 Also. Can anyone recommend a free site to post pictures of our projects
 besides "MySpace" (received 3 special solicitations in the first hour!).
 Thanks in advance,  Jim
  |  | - The Matronics Zenith-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
		davgray(at)sbcglobal.net Guest
				 Posted: Fri Dec 28, 2007 9:36 am    Post subject: Quick Question |
				James
 If you have an XP computer or later you can go to Google and download
 'Picassa' and use their web space to post your pics.  The Picassa program
 works well and updoads easily and it is a free service.
 Gary Ray
		lrm(at)skyhawg.com Guest
				 Posted: Fri Dec 28, 2007 11:08 am    Post subject: Quick Question |
				The answer to your question is yes.  However, be careful.  I never heard of
 it before, so I spent the last half hour researching it.  Most comments were
 positive, but several were negative.  Not about how the software functioned,
 it seems great, but what it did to your computer, like loading it up with
 .inf files, etc.  I don't know man, you do what you want, but I spent many
 years the computer business and I spent a lot of time getting and keeping my
 computers clean and running fast.  This computer stuff is a nasty game, even
 when you go buy name brand software, they load you up with useless junk,
 spyware, adware.  It all slows down your computer, runs little programs in
 background.  They change your home page, etc., it never stops.  None of this
 "free" downloads is really free.   Not really airplane stuff, is it?  But, I
 think it's important.  LRM www.skyhawg.com.
		Tim Juhl
  Joined: 21 Mar 2006 Posts: 488 Location: "Thumb" of Michigan
				 Posted: Fri Dec 28, 2007 12:23 pm    Post subject: Re: Quick Question |
				If you just want to post a few pix try http://photobucket.com/
 If you want to keep a builders log with hundreds of photos you may need to rent space on a server and set up a web page.
 I believe the EFIS meets the compass (magnetic direction indicating device requirements) but if you look back over the last couple of months I believe there was some discussion on the subject.  You might have a little trouble convincing a inspector who was not too up on things.  That said...one advantage of a whiskey compass is it doesn't fail when the electrical system goes down.  You want some kind of redundancy.  I like my battery powered garmin 296.
  _________________ ______________
CFII
Champ L16A flying
Zodiac XL - Jabiru 3300A
Almost done! It'll fly in spring! |
				 Posted: Fri Dec 28, 2007 3:23 pm    Post subject: Quick Question |
				Thats a good question.
 I asked the EAA Tech. guys and they said no, all I needed was the GPS or
 other device.  HOWEVER the FAA says " A Magnetic Direction Device".
 SW
		bryanmmartin
				 Posted: Fri Dec 28, 2007 8:27 pm    Post subject: Quick Question |
				I believe the requirement for a magnetic direction device applies only
 to aircraft with standard airworthiness certificates unless you intend
 to fly IFR. In that case your op-lims specify that you must meet the
 same minimum equipment list as specified for standard aircraft. However,
 the compass does not need to be a TSO'd aircraft compass. I have a $10
 compass from Walmart in my plane and it works just fine.
  SW
  _________________ --
Bryan Martin
do not archive. |
