LarryRosen
Posted: Sun Dec 30, 2007 1:29 pm Post subject: Static line and ADAHRS connection - where do you make it? |
The Cheltons have a MSU and a GADAHRS in addition to the screens. The
MSU only gets wires. The GADAHRS gets wires and Pitot and Static
connections. Tim has both units mounted in the rear. I am only
mounting the MSU in the back, the GADAHRS will be behind the panel.
Larry
MauleDriver wrote:
I'm putting the static line in from the rear ports forward to the
panel. Do I need a 3 way fitting or something back in the battery
area to feed the ADAHRS box for a Chelton or other EFIS?
Just looking for a quick yes or no before I close up the RH baggage
wall and the static line.
_________________ Larry Rosen
#40356
N205EN (reserved)
<http> |
Tim Olson
Posted: Sun Dec 30, 2007 4:01 pm Post subject: Static line and ADAHRS connection - where do you make it? |
Depends on the line that you're using as to what to do, but for me,
using tygon, it was easy to just splice in a push-on "T" when I
upgraded to the pinpoint. You'll want Pitot and Static to wherever
you mount the AHRS. I also "T'd" my pitot where it comes into
the fuse and ran one back.
MauleDriver wrote:
panel. Do I need a 3 way fitting or something back in the battery area
Just looking for a quick yes or no before I close up the RH baggage wall
