Posted: Sun Dec 30, 2007 11:26 am Post subject: Static line and ADAHRS connection - where do you make it? |
I'm putting the static line in from the rear ports forward to the
panel. Do I need a 3 way fitting or something back in the battery area
to feed the ADAHRS box for a Chelton or other EFIS?
Just looking for a quick yes or no before I close up the RH baggage wall
and the static line.
roadmaps
Posted: Sun Dec 30, 2007 1:40 pm Post subject: Static line and ADAHRS connection - where do you make it? |
Yes,
The Chelton GDHARS requires both pitot and static lines. The Quick Connect
fittings (from SafeAir) are really easy to work with.
John Testement
jwt(at)roadmapscoaching.com
40321
Richmond, VA
Paint prep, interior, and LOTS of little stuff
