josok-e(at)ukolo.fi Guest
Posted: Sun Dec 30, 2007 3:22 pm Post subject: mounting quick-connect bellcrank brackets into |
Hi Greg,
The brackets should be inside the outline of the cockpit module. Have a look at my efforts there, the link is http://www.europaowners.org/modules.php?set_albumName=album73&sid=a3309a4ca706651d65ddf4ee58137e4b&op=modload&name=gallery&file=index&include=view_album.php
There are a few pictures that clearly show the situation. Maybe the brackets are upside down, or port-starboard interchanged? Later, once the cockpit module is mounted in the fuselage you will lap up the brackets to the fuselage. If wrong, better to correct now.
Jos Okhuijsen
Visit - www.EuropaOwners.org
http://www.europaowners.org//zfiles/img_1737.sized_198.jpg
Posted: Sun Dec 30, 2007 4:29 pm Post subject: mounting quick-connect bellcrank brackets into |
Hi! Greg
I'm very late entering this one but be sure to alternate male/female
..female/male to make the reconnect fool proof. I remember assisting
connecting William Mills once for him only to hear he flew home without
an ASI because they were crossed.
Bob H G-PTAG
gregoryf.flyboy(at)comcas Guest
Posted: Sun Dec 30, 2007 5:25 pm Post subject: mounting quick-connect bellcrank brackets into |
Jos,
Thanks for the comment and picture link. I seem to have the orientation of
the brackets ok (the holes drilled into the bracket are in the same spot as
in your pictures), and have trial fitted the wing bellcranks to the cockpit
bellcranks by inserting the wings, and they mate very well. I hate to undo
that which mates so well, but will have to, if that's what it takes. I will
prob do a trial fit in the fuselage, and if the bracket leans inboard, I
won't have a choice, but to redo. Then give each bracket top an inboard
twist around the positioning bolt by about 3/8" (and consequently the
bracket bottom an outboard twist), and a new base of araldite.
I am going to think about it for a little while though, and am open to any
more ideas or enlightenments from anyone.
Part of the bellcrank is outside the fuselage shell as well, in the area of
the hole in the side of the fuselage. I assume this is normal, since the
dimensions are set by the hole spacing in the wing spars. Can you or someone
please confirm this?
Greg Fuchs
Thanks Bob, but I am just a tiny bit confused.
Were you talking about the pitot tube connectors?
I am talking about the bellcrank support brackets being possibly slightly
outboard of the airfram.
But I will be sure to work on your experience and take that advice when I
get there, and alternate the pitot connectors. I definately don't want to
lose my ASI, either.
If you meant something else, please set me straight.
Thanks again, and Best Regards,
Greg
Posted: Sun Dec 30, 2007 10:44 pm Post subject: mounting quick-connect bellcrank brackets into |
[quote:6192b041ef="gregf"]
Part of the bell crank is outside the fuselage shell as well, in the area of
-----[/quote:6192b041ef]
Yes, the bell cranks move outside, that's normal. From your reply i now understand that the brackets are rotated - top out bottom in - Yes, you should correct it. The inside of the brackets, after glassing in, should be about 90 degrees to the sides. The manual also calls for the brackets to be squared up, also that is quite important to make fitting the wings easier.
Thinking back, i see now what my problem was here. Later, when fitting the wings, the manual calls for a check of the line up of the bell crank. One of them was not in line anymore, while i am quite sure it was ok in the stage you are in now. The brackets, until glassed in, are flexible enough to be pushed around, out of square. That must have happened, not much, but just the 5 millimeters that were missing. Please check the squareness again before glassing
Jos Okhuijsen
Posted: Mon Dec 31, 2007 2:34 am Post subject: mounting quick-connect bellcrank brackets into |
Hi! Greg
Sorry if I confused the issue ....something told me you were talking
quick connects being the Pitot/Static pipes.
Bob H
Posted: Mon Dec 31, 2007 2:51 am Post subject: mounting quick-connect bellcrank brackets into |
Thanks Jos,
I will measure the squareness of the brackets, and will report my findings.
I tried to get them vertical with respect to the ground, but they may be out
by a small amount, or I might have to actually taper the top of the brackets
in towards each other slightly. More later...
I am sure that this has affected more than a few builders, the dimensions
are a bit tight near the sidewall.
It is only the very upper outboard back part (the back part with the
bellcrank mounted to it) of the bracket that wants to lean outward of the
fuselage by up to 1 quarter inch, and only the corner, so it would be very
easy to miss. However, I will check for my own assumed inaccuracies first...
Greg Fuchs (A050)
before glassing
Jos Okhuijsen
Posted: Wed Jan 02, 2008 5:18 am Post subject: mounting quick-connect bellcrank brackets into |
First of all, thanks for all the comments so far.
I just measured the distance between the two top outboard edges of the
cockpit bellcrank bracket, and compared that with the bottom two. If they
were parallel, I would expect the values to be close. (unless it was a
parallelogram, but then only one side would be affected this way, with
respect to the lower bracket, and this is not the case) The distances came
in at just over 42 1/4" for the top, and just shy of 42 3/8" for the bottom.
Thus they are off only by 1/8" tops. The bottom dimension is the longer
dimension, and the bottom side of the bracket(bellcrank end) is the side
that hits up against the fuselage, not the top side that I said earlier.
Since test fitting into the actual boat shell was SO close to working, I
ground 1/8" from just the corner of the 3mm plywood and metal. This needed
to be done on both sides, since they were both touching. This will have
negligible effect on the strength of the bracket, which will be
bond-strengthened later, and am satisfied that everything clears now, and
can move on without worry.
What this tells me:
At least with MY cockpit module, had I gotten both brackets perfectly
vertical and square with each other (the manual just says to visually align
them), I feel there could still be a slight push on one or both of the
brackets by the fuselage shell when bonding the cockpit module in, and it
may also depend on rivet location when bonding, or the squeezing applied by
the fuselage holder, etc. We are talking 1/8" or less here, so it is not
much. I am pretty convinced now that if the problem exists in other modules,
and not caught, many others may have had a small bellcrank alignment issue
after bonding due to this reason. It would have a tendency to separate the
bellcranks from mating, by only a small extra amount. If the distance
between the top brackets (with respect to the aircraft) was the longer
dimension by 1/8", this problem would probably go away. Any more than that,
might start to make the top part of the bracket touch.
Greg Fuchs (A050)
kevann(at)gotsky.com Guest
Posted: Wed Jan 02, 2008 6:41 am Post subject: mounting quick-connect bellcrank brackets into |
Sounds like you have it figured out. The brackets on mine came out very
similar to yours, as I recall. I called the factory and they said just
file off the corners so they do not touch the canoe.
Kevin
Greg Fuchs (FB) wrote:
What this tells me:
Greg Fuchs (A050)
Posted: Wed Jan 02, 2008 3:48 pm Post subject: mounting quick-connect bellcrank brackets into |
Thanks Kevin,
It is good to hear of a few others seeing this too.
It looks like I chose a familiar fix-it route, thanks for the confirmation.
Greg
