railridr(at)dejazzd.com Guest
Posted: Tue Jan 01, 2008 5:18 am Post subject: Engine performance for homebuilts |
Hello,
I read lots of comments about using all types of engines in homebuilt aircraft.
I realize that cost and size are very important considerations for most of us. However, I believe the two most important things are the complete engine package weight and the amount of thrust that the propellor can produce at 75% power. (ok this is a trade off with aircraft speed)
There are many "common" engines installed on homebuilt aircraft as well as older Pipers and Cessnas such as Continental, Lycoming, Rotax, Subaru, Suzuki, VW and Corvair.
Does anyone have a link to real weight/performance data for the various engines?
John Rizzo
126 Main Street
Oley, PA 19547
610-987-6674
 Download |
| Filename: |
railridr.vcf |
223 Bytes |
| Downloaded: |
509 Time(s) |
rsteele(at)rjsit.com Guest
Posted: Tue Jan 01, 2008 9:30 am Post subject: Engine performance for homebuilts |
Wouldn't it be nice to find such a list! I'd that like to add that
predictable reliability is probably even more important than weight
and power. I know there is a lot a variation of installations, but
it seems something like this ought to be possible. Even comparing
the Rotax 912s and the Jab 3300 is hard, apparently there is only
about 5 lbs difference in most installations be the time you add
fluids to the Rotax, but you wouldn't necessarily know this looking
at the spec sheets online.
Especially now with the US dollar tanking and the lightweight foreign
engines becoming even farther out of reach, a normalized list of auto
conversions would be a huge help.
Ron
On Jan 1, 2008, at 8:17 AM, railridr dejazzd.com wrote:
| Quote: | Hello,
homebuilt aircraft.
various engines?
John Rizzo
126 Main Street
Oley, PA 19547
610-987-6674
<railridr.vcf>
special4
Posted: Wed Jan 02, 2008 6:08 am Post subject: Re: Engine performance for homebuilts |
John & Ron,
check www.fortunecity.com/marina/anchor/270/weights.htm. The engine list is not complete....
Peter
601XL
_________________ Sportsflyer |
kmccune
Joined: 22 Sep 2007 Posts: 577 Location: Wisconsin, USA
Posted: Wed Jan 02, 2008 5:16 pm Post subject: Re: Engine performance for homebuilts |
Blank webpage at the link location
_________________ “Always do what you are afraid to do.”
R.W. Emerson (1803-1882)
Dorothy McCune |
special4
Posted: Thu Jan 03, 2008 6:24 am Post subject: Re: Engine performance for homebuilts |
Kevin,
I don't know why the link doesn't work... if you write it manually it works...
Peter
kmccune
Posted: Thu Jan 03, 2008 7:44 am Post subject: Re: Engine performance for homebuilts |
Try this one, same just that the period is left off the end
Dorothy McCune |
