qb kit-front floor panels removal and gear mount
Goto page 1, 2  Next
tomhanaway(at)comcast.net
PostPosted: Thu Oct 04, 2007 2:00 am    Post subject: qb kit-front floor panels removal and gear mount Reply with quote
Slightly different question re: removing floor panels in rv-10 quickbuilds. Yes, they are tight to get out.
I don’t see any way to remove the front floor panels without completely removing the gear mounts. Priming has given me peace of mind but I’m having a tough time figuring out how to get out the front floor panels without significant removal of installed parts. Am I missing something?
Thanks.
Tom Hanaway
Boynton Beach, FL
effectus(at)rogers.com
PostPosted: Thu Oct 04, 2007 6:40 am    Post subject: qb kit-front floor panels removal and gear mount Reply with quote
Tom,
I had the same issue with the front floor pans. After I removed the gear weldments and completed all of the things I needed to do under the floor pans I modified the floor pans to fit around the gear weldment. This will make it exponentially easier in the future to get under there should I need to.
I modified them by cutting a triangular portion of the floorpan away from the main section. This smaller portion is perminantly mounted in around the weldment. To it, I riveted a strip of aluminum that I could rivet the rest of the floor panel to. This way I can simply drill out the rivets along this line and be able to pull out the larger section.
I hope this makes sense. If you need more info or pictures just contact me off-line.
Dave Hertner
40164 Wing Tips
John Ackerman
PostPosted: Thu Oct 04, 2007 6:45 am    Post subject: qb kit-front floor panels removal and gear mount Reply with quote
No, I don't think you are. I found the jillion AN-3 bolts very hard to remove; I got them out by pulling on the heads with a vise-grip plier, and that damaged the heads. My solution was to cut off the heads and grind and polish the the thread end to a bullet shape. The resulting pins were lubed and used as guide pins for the installation of new bolts. The install was a great deal easier than the removal; the hard part was reaching some of the nuts. I remember wishing for a long set of wrenches.hope this helps
John Ackerman 40458
Thanks.
Tom Hanaway
Boynton Beach, FL
         - The RV10-List Email Forum - class="Apple-converted-space"> --> http://www.matronics.com/Navigator?RV10-List              - NEW MATRONICS WEB FORUMS - class="Apple-converted-space">   --> http://forums.matronics.com
poneill(at)irealms.com
PostPosted: Thu Oct 04, 2007 7:14 am    Post subject: qb kit-front floor panels removal and gear mount Reply with quote
I spent a few days trying to figure out a way around tearing down all that assembly before resigning myself to it.
I actually had more problems with the screws on the side panels than the bolts. Most were easy but a few became stripped despite my best efforts.
Though the nuts and bolts for the seat pedestal panels and gear weldements were definitely no fun at all. I just kept telling myself that it was still faster than building it all from scratch. Eventually that helped a little.
I just wish they did less of the things you need to undo and more of the things that are more difficult to do after all the QB assembly.
Best Regards,
Patrick #40715
dmaib@me.com
PostPosted: Mon Dec 31, 2007 3:10 am    Post subject: Re: qb kit-front floor panels removal and gear mount Reply with quote
Started the task of removing the gear weldments yesterday and found the first one to be as much "fun" as anticipated. Thinking ahead to the reinstall process, I am curious about the procedure to get bolts back in. They were so tight coming out, that I can't imagine they will go in easily. How does one apply the force necessary to install those bolts? John Ackerman, you mentioned grinding down the old bolts and using them as guide pins. Could you elaborate? Any pics?
David Maib
RV-10 #40559
New Smyrna Beach, FL
drfred(at)suddenlinkmail.
PostPosted: Mon Dec 31, 2007 6:21 am    Post subject: qb kit-front floor panels removal and gear mount Reply with quote
David;
You can put some LP 3 on the bolts to help them slide in. Just clean
off the threads before you put the washer and nut on.
Fred
40515.
Fun with fiberglass... Wheel pants almost done.
Had the pleasure of meeting Mark Ritter and seeing his 10 this weekend
at the cafe in Brenham, Texas.
David Maib
RV-10 #40559
http://forums.matronics.com/viewtopic.php?p=155133#155133
John Ackerman
PostPosted: Tue Jan 01, 2008 11:15 am    Post subject: qb kit-front floor panels removal and gear mount Reply with quote
Here's what I did:
Hacksawed off the bolt heads to make  pins out of the bolts.
Filed cut end more-or-less flat -just a few strokes were needed. You can chuck the pin in a drill press to do this, but it's not really necessary.
Ground off the threads, holding the pin in a drill, and rotating opposite to the wheel. Made the (previously) threaded end into a bullet-like shape. Not quite as blunt as a pistol bullet – say a .45 ACP round nose – but not sharp like a high velocity bullet,either. This is not terribly critical, but the idea is for the pin to work its way into two slightly misaligned holes, drawing them in alignment with a lot of motion (small mechanical advantage) at first, and a small amount of motion (large force) as the pin gets in farther. Eyeballing the shape gave a product that was good enough to work very well.
Polished on a fine Scotchbrite wheel.
Covered the pins with grease, wiping off excess.  I used Lubriplate, but I doubt it matters.
Placed weldment in position.
Pushed all the pins into the holes, pushing the pins  in a little at a time, going from pin to pin, tapping as required. Hardly any tapping was needed on mine. YMMV.
Used the new bolts to push pins on through, tapping as required - again not much.
This whole process did not take very long. You only need one set of pins – probably not even a full set because the first bolt is put in while the parts are free to move.
I was worried about clearing the rear spar structure as the pins were pushed on through, but they all fell out the other side without hitting anything.  You may want to check pin lengths before inserting them and shorten if/as required.
As I recall, I had to use a swivel socket to get on the nuts, and a long extension for reach.
Like you, I had a very  hard time removing the bolts. I recall it was difficult getting past the floor skin, as well.
Bolting the weldment back was a piece of cake. The pins moved it into alignment and kept that alignment while the bolts displaced them.
I'm quite sure the bolt threads did not damage the holes and vice versa.
Hope this is useful.
Happy new year!
John and Marlys   40458
On Dec 31, 2007, at 4:10 AM, dmaib(at)mac.com (dmaib(at)mac.com) wrote:
[quote]--> RV10-List message posted by: "dmaib(at)mac.com (dmaib(at)mac.com)" <dmaib(at)mac.com (dmaib(at)mac.com)>
David Maib
RV-10 #40559
AirMike
PostPosted: Tue Jan 01, 2008 8:01 pm    Post subject: qb kit-front floor panels removal and gear mount Reply with quote
Am I stupid or am I missing something
I know that it would be a good idea to check the QB work and have a placement for my MB and transponder antennas, but why take up the floorboards. I think that they are already primed. Carpet with some foam backing will provide front insulation..... splain me
See you OSH '18
Q/B - sold.
Tim Olson
PostPosted: Tue Jan 01, 2008 8:22 pm    Post subject: qb kit-front floor panels removal and gear mount Reply with quote
In my case it was nice to clean out the extra tools that they
left under there. They sent me an assortment of clecos
and drill bits unintentionally.
-------- OSH '08 or Bust Q/B Kit - Doors/windows/fiberglass stuff
http://forums.matronics.com/viewtopic.php?p=155468#155468
patrick.pulis(at)seagas.c
PostPosted: Tue Jan 01, 2008 8:39 pm    Post subject: qb kit-front floor panels removal and gear mount Reply with quote
Great to see you back Tim, happy new year.
How did the road trip to the snow go?
Patrick
South Australia
Tim Olson
PostPosted: Tue Jan 01, 2008 8:55 pm    Post subject: qb kit-front floor panels removal and gear mount Reply with quote
Just got in minutes ago so there's a lot of catching up to do.
I think I'll do a short trip write-up on the experience traveling.
It was a great time, but it's definitely nicer traveling by -10!
Still, we had a blast out there. Sorry so short. Hopefully I'll
start caching up tomorrow.
Patrick
South Australia
johngoodman
PostPosted: Wed Jan 02, 2008 7:31 am    Post subject: Re: qb kit-front floor panels removal and gear mount Reply with quote
AirMike,
I've wondered the same thing myself. If inspection is the only purpose, then why not cut an inspection port? Make it large enough to get your hand in and you have access to install antennas. To close the port up, get one of those plastic round caps the post office uses for tube mailers. If strength is degraded, then screw a top plate on it.
To me it's like the QB wings: the bottom skin was put on by the QB folks so that you can't easily rivet the flap fairings. Big deal, that's what CherryMax rivets are for.
Just my opinion,
John
coop85(at)cableone.net
PostPosted: Wed Jan 02, 2008 9:50 am    Post subject: qb kit-front floor panels removal and gear mount Reply with quote
I found the same thing, several old clecos and some junk. It's definitely
worth looking at the area under the floorboards and putting sound proofing
against the bottom skin makes a huge difference in my opinion.
Marcus
John Ackerman
PostPosted: Wed Jan 02, 2008 10:33 am    Post subject: qb kit-front floor panels removal and gear mount Reply with quote
I agree, but put the sound insulation on the bottom of the floorboard
rather than the bottom skin so that it can't trap water...
John Ackerman 40458 do not archive
definitely
proofing
Marcus
johngoodman
PostPosted: Wed Jan 02, 2008 4:13 pm    Post subject: Re: qb kit-front floor panels removal and gear mount Reply with quote
OK, I went and pulled the bedsheets off of my QB Fuselage and took a good look. A total of 12 pull rivets holding down each of the aft passenger floorboards. I can see where it would be tricky to pull it because of all the AN470 rivet heads, etc. I'll go through the plans tomorrow and figure out what's underneath. There must be something I'm missing because I don't see why it's such a problem.
I'll get back tomorrow.
John
johngoodman
PostPosted: Thu Jan 03, 2008 5:40 pm    Post subject: Re: qb kit-front floor panels removal and gear mount Reply with quote
Spent an hour today pouring over the plans and identifying the issues. Pulling any of the floorboards (front or back) pretty much defeats the purpose of "Quick Build" in my opinion. The front ones do have limited access as far as fishing out surprises, but I don't see any other need to get in there (please tell me if I'm wrong). The rear floorboards are very thin in depth, but an errant cleco could be in there. I suspect a strong magnet would answer that question.
As far as antenna placement, the baggage floor seems a far easier place for access.
I hope that nobody thinks I'm being forward or pushy, but I'm at a loss for a good reason to spend hours undoing what I just paid to have done.
Humbly and ready to take some shots,
John
dlm46007(at)cox.net
PostPosted: Thu Jan 03, 2008 6:04 pm    Post subject: qb kit-front floor panels removal and gear mount Reply with quote
I concur: my QB number for the fuselage was #8 and they did not at that time
install the forward weldment support nut plates; I reported this to Van's
and indicated that that was the only reason to remove it. I believe that
they have since installed the nut plates for the forward support. In my case
they also installed the mid fuselage floorboards with stemmed blinds and
thus the removal was complicated slightly; it require some finesse to get
the floors out. Underneath nothing was found.
PostPosted: Thu Jan 03, 2008 6:10 pm    Post subject: qb kit-front floor panels removal and gear mount Reply with quote
John,
Your's may be different, but my QB had temporary (soft) rivets holding
the floorboards in and didn't take long to remove. I needed to remove those
rivets anyway and there weren't that many of them so it made sense to pop
them out and have a look. Plus the opportunity to add noise insulation. If
your panels are completely riveted in then I can see your hesitancy.
Marcus
rv10builder(at)verizon.ne
PostPosted: Thu Jan 03, 2008 6:17 pm    Post subject: qb kit-front floor panels removal and gear mount Reply with quote
if you are tearing a QB apart to find a cleco.. just move the fuselage
around and see if you hear anything.. I gathered people were doing this for
the insulation install and putting conduit in that space, hence the effort
to remove the floorboards to get in there. If you don't see any need to do
anything under the floor, I'd agree focus your time and effort elsewhere.
as far as being forward or pushy..I commend you for not being a blind
follower and thinking this out for your individual case.
Pascal
#720
dmaib@me.com
PostPosted: Thu Jan 03, 2008 7:17 pm    Post subject: qb kit-front floor panels removal and gear mount Reply with quote
John,
I could not make up my mind. One day I was going to pull them out,
and the next day I wasn't going to. In the end, I decided to dig in
and do it. I am about halfway through the process and I must say, I
agree with you. I paid good money for the quick build and am now
spending lots of precious time taking it apart. I think the problems
with tools under the floor and quality control issues have probably
been laid to rest since the early days. It is not particularly hard,
just time consuming and the value is minimal. Since I am committed, I
plan to go ahead and put insulating/sound deadening material in
there. I will probably go ahead and put the transponder antenna and
perhaps a comm antenna under the front floor as well. But, if I had
it to do over again...........................probably not.
David Maib
40559
On Jan 3, 2008, at 7:40 PM, johngoodman wrote:
<johngoodman(at)earthlink.net>
place for access.
have done.
John
#40572 QB Wings, QB Fuse arrived
N711JG reserved
http://forums.matronics.com/viewtopic.php?p=155834#155834
David Maib
RV-10 #40559
Goto page 1, 2  Next
Page 1 of 2
