Posted: Thu Jan 03, 2008 10:14 pm Post subject: Oversized spar bolt holes in a quick-build kit |
After reading what Steve Weston found on the bolt holes in the spar of his
quick-built kit I decided to check mine. I face a different problem but it
is just as frustrating.
I have oversized holes in the center spar. The worst are the outer four (two
per side) that pass through the vertical angles which tie the spar to the
fuselage sides (6B13-1). Mine vary between 0.3205 and 0.3245. My guess is
that they were enlarged when they were drilling the matching holes through
the upright angles. The inner eight range between 0.3140 and 0.3175. I'm
still trying to decide if these are too far out. The twelve holes in the
wing spars appear to be within spec.
Accurately measuring these holes is difficult. After using the same tools to
measure a regular AN5 bolt and a home-made taper gauge I am confident in the
*relative* readings. And an AN5 bolts is very loose in the worst holes. I
cross-checked my readings with the shank of a letter "O" ("oh") drill
(0.3145 on my micrometer).
During the holidays I sent an e-mail to ZAC describing the situation and
Rodger called me the morning after the holidays ended. We both agree that
the four worst holes have to be fixed. He is working to come up with what
gap is acceptable so we can decide if the remaining 8 holes are usable. ZAC
is also getting a set of size gauges so we can accurately measure holes on a
sampling of planes. I've ordered a few close-tolerance AN175 bolts to see
how they fit.
For me I think the best way to work on the problem holes is to remove the
center spar from the fuselage, bolt it to each wing in turn and use a
portable drill press or guide to drill and ream. One trick will be
maintaining the position of the vertical angles on the spar. In the QBK each
is held to the center spar with a pair of blind rivets. So I'll probably
take the whole assembly out as a piece. This will allow me to ream the
outermost four holes as a piece.
I would urge anyone with a factory-built spar or QBK to check these holes -
both size and alignment.
-- Craig
Posted: Fri Jan 04, 2008 3:17 am Post subject: Oversized spar bolt holes in a quick-build kit |
Does this mean that all of you wonder if there really is a Dog?
Craig Payne <craig(at)craigandjean.com> wrote:[quote] --> Zenith-List message posted by: "Craig Payne"
how they fit.
center spar from Be a better friend, newshound, and [quote][b]
notsew_evets(at)frontiern Guest
Posted: Fri Jan 04, 2008 4:57 am Post subject: Oversized spar bolt holes in a quick-build kit |
Craig
Zenith is debating on how to "fix" my problem also.
I m waiting on their answer. I pulled the last rivet ( the golden rivet)
this past weekenf and dont really want to tear into my interior paint to do
the fix that you say. I guess it might need to be done, but by who ??
I paid Nine Thousand dollars more than the standard kit price just so the
critical parts would be completed by people who know what they are doing.
Of all the screwups that could have happened, it had to be on , what I say
is ithe most critical part, the main attach for the wing. Zenith has told me
that they want to and will take care of the problem.......
I expect Zenith to call soon. I will post the results here and let you know
what happened....
Steve W
psm(at)att.net Guest
Posted: Fri Jan 04, 2008 6:05 am Post subject: Oversized spar bolt holes in a quick-build kit |
Hi Steve,
I feel your pain.
My own reasons for building a Zodiac are more about building than
flying, so I understand your choices can and should be different from
my own. That said, I feel I can trust my own work better than that
of factory workers whose primary attractiveness is based on their low
wages. Most (all?) of the quick build kits for all the kit
manufacturers are assembled in far off developing countries. I'm
sure the kit companies make valiant efforts to insure high quality
work, but all the comments I have heard recently about the spar
attach holes being oversized don't surprise me a great deal.
I am not completely sure, but I think drilling out the holes to the
next bolt size and reaming them should be a relatively easy
task. The secret is choosing the correct drill size and type of
reamer. When I did a similar task on my replacement wing spar, I
used hard steel drill guides from McMaster-Carr and a hand reamer
with left spiral and right hand cut. The reaming was the easiest
part of the operation. In your case, the already aligned holes
should guide the drill bit and reamer so the biggest problem is to
get them properly positioned for their work while standing on your
head in the cockpit.
I don't have any idea what to expect from ZAC about fixing this
problem. Hopefully, they will do more quality control on the QBKs
received from their contractor. After the kits leave their factory
it seems a difficult task to get them to fix the problem. The travel
for a technician to get to your shop or the difficulty of returning
the fuselage to their factory both seem a lot more than for you to
drill and ream the holes. I might ask them to supply or pay for the
reamer which may cost as much as $50 or so, but that might prove
difficult to manage as well.
One last comment. When I ordered my replacement wing spar, I learned
these parts are not made by Zenith. All the complete spar and
carry-through sets were made by Zenair in Canada. That means the
folks at Zenith don't have much more experience than you do in match
drilling the spars.
Good luck,
Paul
XL fuselage
do not archive.
At 04:56 AM 1/4/2008, you wrote:
| Quote: | Zenith is debating on how to "fix" my problem also.
rivet) this past weekenf and dont really want to tear into my
interior paint to do the fix that you say. I guess it might need
so the critical parts would be completed by people who know what
they are doing.
I say is ithe most critical part, the main attach for the wing.
Zenith has told me that they want to and will take care of the problem.......
you know what happened....
Steve W
John Bolding
Posted: Fri Jan 04, 2008 6:51 am Post subject: Oversized spar bolt holes in a quick-build kit |
Paul,
Not ALL the offshore folks building kit aircraft can be lumped into your
generalization.
I'm doing the final assembly of an F1 Team Rocket for a client and it
started life as a QB kit from the Czech Republic. The workmanship is
Beechcraft quality or better, everything fits, no scratches,dents or dings,
rivets flush, bolt holes snug, edges perfectly straight etc. Whoever put
this one together it wasn't his/her first rodeo.
It will be interesting to see how Zenith fixes this serious situation with
the sloppy holes. On my RV 3 I used tapered pins which I could ream with a
hand held drill down to the last few turns which I did by hand with a guide.
Worked so far (2000+ hrs)
LO&SLO John
Hi Steve,>
| Quote: | of factory workers whose primary attractiveness is based on their low
wages. Most (all?) of the quick build kits for all the kit manufacturers
are assembled in far off developing countries. I'm sure the kit companies
make valiant efforts to insure high quality work, but all the comments I
have heard recently about the spar attach holes being oversized don't
Gig Giacona
Posted: Fri Jan 04, 2008 8:39 am Post subject: Re: Oversized spar bolt holes in a quick-build kit |
Mine isn't a QBK so all this may not effect me. But as I will be mounting my wings soon I have this question.
If the holes are to big why not just go up in size of bolt?
601XL Under Construction
Posted: Fri Jan 04, 2008 9:40 am Post subject: Oversized spar bolt holes in a quick-build kit |
In Steve's case all 12 holes are large. Since the spars are made and
match-reamed in the far off land of Canada these holes were never
"processed" in Columbia.
-- Craig
Posted: Fri Jan 04, 2008 11:07 am Post subject: Oversized spar bolt holes in a quick-build kit |
| Quote: | If the holes are to big why not just go up in size of bolt?
That is the likely solution being discussed. But the wing and center spars
are match reamed and enlarging the holes from AN5 to AN6 on a
nearly-complete plane is difficult. The first step is to establish just
exactly what tolerance the holes should meet. The second step is to acquire
the tools to accurately measure the existing holes. Something like this:
www.grizzly.com/products/g9794
-- Craig
cj.tremblay(at)videotron. Guest
Posted: Fri Jan 04, 2008 2:33 pm Post subject: Oversized spar bolt holes in a quick-build kit |
I Greg
If it can help you, you can visit my own web site at the followings page link below. I am not a specialist but I think my own experience can help you. Don’t hesitate to ask me questions.
I build my CH640 from plan and I had drilled all holes myself, my wing spars to my Center Web Spar. I did it with a modified drill press, because my specific need for it, and also my drill press dimension itself. ( I change the center steel tube for a short one)
I clamped all pieces with C clamp, and fixed tight all pieces that need to be fixed by the 3/8 an bolts, including uprights during the drilling job. I drilled the 12 holes without move any pieces in the drilling process. Your process will be a little bit more simple, your holes are already positioning, you will need to drill one regular hole and one reamer pass only, without any angle or length alignment spars measurement required. (Supposed to be done correctly – just verified that in case).
I suggest you to remove your center web spar and align all spars on a flat table. For the bolts dimension is a more tricky questions. Do we have something between AN5 and AN6 ? And I think you need a good stress advise (from specialist) to changes to next AN size, the problem is do you have end off material on side spars and between AN6 bolts?
Good luck my friend,
See my web site for more details and photos.
Christian Tremblay
A guy who build a CH640 aircraft from plan
[b]http://www.zodiac640.com/[/b]
http://www.zodiac640.com/Wing.htm
http://www.zodiac640.com/Photographies/wing_spar_assbl_4.JPG
-----Message d'origine-----
De : owner-zenith-list-server(at)matronics.com [mailto:owner-zenith-list-server(at)matronics.com] De la part de Craig Payne
Envoyé : Friday, January 04, 2008 1:13 AM
À : zenith-list(at)matronics.com
Objet : Oversized spar bolt holes in a quick-build kit
--> Zenith-List message posted by: "Craig Payne" <craig(at)craigandjean.com>
how they fit.
-- Craig
Posted: Fri Jan 04, 2008 3:13 pm Post subject: Oversized spar bolt holes in a quick-build kit |
Thanks for the advice and links. Park of the problem is that (this being a quick build kit) the wings are done too. So I can’t lay all three sections on a flat surface to do the work.
-- Craig
From: owner-zenith-list-server(at)matronics.com [mailto:owner-zenith-list-server(at)matronics.com] On Behalf Of Christian Tremblay
Sent: Friday, January 04, 2008 3:29 PM
Subject: RE: Oversized spar bolt holes in a quick-build kit
I Greg
Christian Tremblay
how they fit.
-- Craig
Martin Pohl
Joined: 30 Jan 2006 Posts: 118 Location: CH-8645 Jona SG, Switzerland
Posted: Sat Jan 05, 2008 5:44 am Post subject: Re: Oversized spar bolt holes in a quick-build kit |
Craig, how about installing the wings with the normal AN5-bolts, then check wing dihedral, then ream and install one by one of the bolts to the larger AN6?
What do others think about this procedure?
I have a CZAW-QBK, but did not check the bolt holes yet (although I am somewhat scared now to do that ).
Cheers Martin
_________________ Martin Pohl
Zodiac XL QBK
8645 Jona, Switzerland
http://www.pohltec.ch/ZodiacXL/Main.html |
amyvega2005(at)earthlink. Guest
Posted: Sat Jan 05, 2008 5:57 am Post subject: Oversized spar bolt holes in a quick-build kit |
i think it is a great idea.
Juan
Posted: Sat Jan 05, 2008 7:37 am Post subject: Oversized spar bolt holes in a quick-build kit |
I also "think" this is the way out of my problem. I bet Zenith suggests
this very method for a cure. But,,, getting a drill motor along the two
bolts that are next to the fuselage skin will be a pain....
I could just do it! However I think Zenith needs to tell me EXACTLY what
they want me to do... "They" drilled the holes. They didnt find the
error......
SW
Posted: Sat Jan 05, 2008 11:34 am Post subject: Oversized spar bolt holes in a quick-build kit |
My take is that drilling out the many rivets and removing the center spar
from the fuselage is a low-risk operation. And I feel it will greatly
increase my chances of doing the best job I can at drilling and reaming the
offending holes. But before I touch anything I'm going to use precision hole
gauges to measure all the holes and measure a sampling of close tolerance
bolts. All the needed items should be in my hands by next Wednesday.
Stay tuned.
-- Craig
Posted: Sat Jan 05, 2008 2:54 pm Post subject: Oversized spar bolt holes in a quick-build kit |
Hi Craig.
I agree with you. I will also receive the hole gauges from Zenith next
week.
But, we spent a great amount of money to buy the QBK and I think Zenith owes
us a partial refund.
SW
