bertrv6(at)gmail.com Guest
Posted: Fri Jan 04, 2008 7:16 am Post subject: One antena two radios how |
Hi:
I posted a message asking what is the best to have two radios, one
antena..
I got one reply, with good info. I would like to hear some other
comments. Any one out there has two radios, and one antena, what is the
best way to do this. If so,
Pros and cons...
thanks
bertrv6a
shempdowling(at)gmail.com Guest
Posted: Fri Jan 04, 2008 7:49 am Post subject: One antena two radios how |
There was an article on this in Kitplanes a few years ago where they made a push and twist setup to disable one radio at a time. I remember them saying you cant share an antenna.
Shemp
in dire need of a paint job
On 1/4/08, Bert Murillo <bertrv6(at)gmail.com (bertrv6(at)gmail.com)> wrote: [quote]--> RV-List message posted by: "Bert Murillo" <bertrv6(at)gmail.com (bertrv6(at)gmail.com)>
Hi:
antena..
Gary.A.Sobek
Posted: Fri Jan 04, 2008 8:57 am Post subject: One antena two radios how |
http://www.romeolima.com/RV8/IdeasProducts.htm#PRODUCT:%20%20King%20Antenna%20Adapter
Not sure which one but something like:
http://www.sinctech.com/catalog/family.aspx?id=104
Very few people go this route as it is not cost effective. A 2nd antenna is less money.
My suggestion would be to to your LOCAL avionics shop and HIRE them for help.
Gary A. Sobek
"My Sanity" RV-6 N157GS O-320 Hartzell,
2,073 + Flying Hours So. CA, USA
Watch “Cause Effect,” a show about real people making a real difference
Gary.A.Sobek
Posted: Fri Jan 04, 2008 9:14 am Post subject: One antena two radios how |
http://www.repeater-builder.com/antenna/w1gan-duplexer.pdf
The HAM 2 Meter band is FM just above the aviation AM band. Stuff that works with their 2 meter band should work on our aviation frequencies. Be careful as some ham equipment call diplexers a duplexer when splitting 2 M and 70 cm signals. Diplexers that are used with repeaters SHOULD work.
Gary A. Sobek
dale1rv6(at)comcast.net Guest
Posted: Fri Jan 04, 2008 9:16 am Post subject: One antena two radios how |
I agree with Gary. Plus: Using one antenna for 2 radios negates the full redundancy benefit. If antenna, switch or final lead fails, both radios are useless. Why pay for a 2nd radio and not get full redundancy??? Please answer this question.
Dale
From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of RV6 Flyer
Sent: Friday, January 04, 2008 11:50 AM
To: rv-list(at)matronics.com
Subject: RE: One antena two radios how
Gary A. Sobek
Watch “Cause Effect,” a show about real people making a real difference. [url=hw]Learn more[/url] | Quote: | | http://www.matronics.com/Navigator?RV-List | 0123456789
n5lp(at)warpdriveonline.c Guest
Posted: Fri Jan 04, 2008 10:47 am Post subject: One antena two radios how |
In amateur radio the term diplexer refers to a device that allows one
antenna to be used on two different bands, not a very difficult
task. For repeater use with one antenna and one band a duplexer is
used. A duplexer is tuned to use only one transmit frequency and one
receive frequency. It has to do that because it uses filters to
eliminate almost all of the transmit frequency from the receiver and
to eliminate almost all other frequencies from the transmitter. It is
critically tuned for those two frequencies only and will not work on
any other frequencies.
Oh, and duplexers for VHF are huge, think around the size of a
kitchen trash can, and they are also very heavy, typically using
several large metal cylinders.
Larry Pardue
On Jan 4, 2008, at 10:07 AM, RV6 Flyer wrote:
| Quote: | http://www.repeater-builder.com/antenna/w1gan-duplexer.pdf
Gary A. Sobek
difference.
Tailgummer(at)aol.com Guest
Posted: Fri Jan 04, 2008 4:33 pm Post subject: One antena two radios how |
In a message dated 1/4/2008 9:00:44 A.M. Pacific Standard Time, rv6_flyer(at)hotmail.com writes:
| Quote: | http://www.romeolima.com/RV8/IdeasProducts.htm#PRODUCT:%20%20King%20Antenna%20Adapter
Gary A. Sobek
Watch “Cause Effect,” a show about real people making a real difference. Learn more | Quote: |
="http://www.matronics.com/Navigator?RV-List">http://www.matronics.com/Navigator?RV-List
.matronics.com/">http://forums.matronics.com
://www.matronics.com/contribution">http://www.matronics.com/contribution
I use the Icom equivalent for my HANDHELD (3rd radio...back-up com). This required no special skills to install, and serves its purpose quite elegantly.
I found it VERY cost effective and serves me well.
John D'Onofrio (Tailgummer(at)aol.com (Tailgummer(at)aol.com))
Start the year off right. Easy ways to stay in shape in the new year.
Doug Gray
Joined: 10 Jan 2006 Posts: 112 Location: Sydney, Australia
Posted: Fri Jan 04, 2008 5:34 pm Post subject: One antena two radios how |
Mark Sletton previously posted a link to a very good solution, here it
is again.
http://www.aerocraftparts.com/ItemForm.aspx?item=SA-010&Category=0e9a8a4d-66d7-4057-a46d-e9f3baaa4e5a
BTW isn't adding a second antenna only slightly better (less risky to
the radio) than wiring the two antenna feedlines together? Coupling
from one antenna transmitting into the second is very likely to torch
the receiver in the second.
Doug Gray
(another HAM...)
Posted: Fri Jan 04, 2008 6:00 pm Post subject: One antena two radios how |
On Jan 4, 2008, at 6:27 PM, Doug Gray wrote:
The two antenna solution has been used very successfully for many
decades. Good to get the best separation possible.
Larry Pardue
carl.froehlich(at)cox.net Guest
Posted: Fri Jan 04, 2008 7:05 pm Post subject: One antena two radios how |
Close antennas (within reason), one transmitting while the other is
receiving, will degrade the receiving system while the other is
transmitting, but there is not sufficient energy transfer to do damage.
With sufficient spacing you can have the pilot talking on one radio while
the copilot is talking to someone else on the second radio. Some audio
panels on the market support this set up (Garmin GMA 340 for example).
There is a Lancair at the airpark with both husband and wife retired airline
pilots. They frequently operate this way to split up the communication load
during IFR. This capability is not possible with the single antenna shared
between two radios system.
If you only plan on talking and receiving on one radio at a time, wide
spacing is not a critical factor.
Carl Froehlich
RV-8A (375 hrs)
RV-10 (wings)
KV4U
dav1111(at)erfwireless.ne Guest
Posted: Sat Jan 05, 2008 3:50 am Post subject: One antena two radios how |
I installed a Bob Archer splitter and during the first 150+ hours it worked great on a two radio one antenna install. However apparently the splitter went bad and to degraded the transmit on both radios to the point that the tower could not understand my request of "ready to depart 35L"
This was after getting clearance to taxi from ground to the runway. After doing a 180 to return to the ramp, the tower said "N710RV (I have 12 inch letters) if you are departing Centennial and NOT returning you are cleared to depart 35L"
After returning to home base I removed the inline splitter and either radio worked just fine on the single antenna. I now have a second antenna.
Russ Daves
N710RV - RV-10
N65RV - RV-6A Sold
N742PZ - RV-Co-Builder
N____RV - RV-7 Waiting on Fuselage
gmcjetpilot
Posted: Sat Jan 05, 2008 3:05 pm Post subject: One antena two radios how |
From Tailgummer's link this ITEM is what you need,
and its $690.00
http://www.aerocraftparts.com/ItemForm.aspx?item=CI601
There is no advantage of duplex off one antenna IMHO
except the 0.30 mph drag you save at top speed.
My situation is I have a #1 panel com. I can access the
BNC connector on the floor and connect a coax jumper to
my handheld if needed. Other wise my handheld uses its
rubber duckie antenna & the audio is routed to the
intercom. Its great for getting ATIS while #1 is on ATC. The
handheld is temp mounted off the side of the panel, just
for reciving. If I want to transmit with it I have to connect
the external antenna to get max range and than connect
the head set direct to the radio. This would be an emergency
if #1 failed.
A second antenna like a FOIL TAPE antenna in the wind
screen, to improve the handhelds reception could be done
with no drag penalty or long wing tip coax runs (cost and
weight).
I don't recommend a foil tape as a primary antenna for
transmission & reception. ANY THING SHORT of a WHIP
externally mounted 1/2 wave ground plane antenna is NOT
going to be as good, ever compared to an internal antenna.
The rubber duckie does good job, especially for ATIS 20
out. Hanging off the side of the panel, the antenna is just
above the side rail.
For two panel mounted VHF radios PUT in two antennas.
I fly Boeing aircraft and we have TWO HF radios into one
antenna. However you have to select one radio to transmit on.
Also when you switch radios you have to KEY the mic and
wait for it to switch & tune the antenna. You hear a tone
for a few seconds. When the tone stops the switch and
tuning has taken place. If you don't switch radios the
switch/tune tone does not come back. If it detects a new
radio or freq it will go through the switch tune process again.
I'm going to guess the HF radio, duplex switcher & antenna
cost more than our whole airplanes do.
Go with a second antenna and be done with it.
G
Posted: Sat Jan 05, 2008 7:38 pm Post subject: One antena two radios how |
In a message dated 1/5/2008 3:07:09 P.M. Pacific Standard Time, gmcjetpilot(at)yahoo.com writes:
| Quote: | >From: Tailgummer(at)aol.com (Tailgummer(at)aol.com)
| Quote: | Subject: Re: One antenna two radios how
and its $690.00
if #1 failed.
weight).
G
Please allow me to clarify, Mr gmcjetpilot, but http://www.aerocraftparts.com/ItemForm.aspx?item=CI601
was not my link. My post was with regard to using a HANDHELD as a 3rd (read: emergency backup) transceiver. An example is the ICOM "ANTSB" which sells for $69.95 from Chief aircraft (among other sources):. http://www.chiefaircraft.com/cgi-bin/air/hazel.cgi/hzpi/u/HzSt02068SnM1JBhoe/hazel.cgi?action=serve&item=/Aircraft/Radios/Icom2.html not the $690.00 as you quoted.
This particular external antenna adapter was reviewed by Avionics West and recommended by them as an alternate method to extend the range of the ICOM handheld: http://www.avionicswest.com/portablevhfadapter.html#1115.
MY particular radio setup includes a belly mounted bent whip (COM 1) and a Bob Archer experimental antenna (COM 2)... which, by the way, works just fine. MY setup utilizes the external antenna adapter for my HANDHELD, rather than installing yet one more bent whip (or other type) antenna. I can't imagine that for the kind of flying RV's do that any more redundancy is really needed.
My post was not to infer that using this type of external antenna adapter was meant to be used instead of a dedicated second antenna.
