Exploding Capacitors?
darinh
PostPosted: Sat Jan 05, 2008 6:24 pm    Post subject: Exploding Capacitors? Reply with quote
I am building a Kitfox Series 7 and the wiring diagrams show the alternator lines being tied to a 22,000 microfarad, 25 V capacitor. This is installed on the output side of the regulator so I assume it is mainly for audio noise reduction in the system. My Rotax manual also recommends that I install a capacitor on each of the fuel pumps for the same reason. I am not an electronics guru but I do remember blowing up capacitors as a younger kid for fun. I remember we had to wire the capacitor with reversed polarity to get them to explode but even the small ones were pretty impressive to say the least! The one I have in my plane is huge in comparison to the small one I blew up as a kid and looks as if it could do some serious damage if it went.
for you guys that know more than I do, do I need to be worried about this setup? And is there another alternative to the capacitor approach to minimize radio noise?
Darin Hawkes
Series 7
914 Turbo
Kaysville, Utah
nuckolls.bob(at)cox.net
PostPosted: Sun Jan 06, 2008 8:02 am    Post subject: Exploding Capacitors? Reply with quote
Capacitors of the style under discussion
have been used by the hundreds of millions
without serious danger to their users or
the equipment in which they are installed.
Capacitors . . . like batteries, propellers,
fuel lines, etc all offer some degree of hazard
when their operational characteristics and limits
are not dutifully observed.
The capacitors are not useful on your fuel
pumps. The capacitor is useful on your alternator
system. If installed with due diligence
to proper technique offers no extraordinary
risks to you or your airplane.
( -Thomas Paine 1776- )
darinh
PostPosted: Sun Jan 06, 2008 1:09 pm    Post subject: Re: Exploding Capacitors? Reply with quote
Thanks Bob for the reply. I figured the capacitors on the pumps were not necessary and therefore wired them up last night without them. I do that the capacitor on the alternator wired per your instructions in the Aeroelectric book. Thanks again for the response.
Darin Hawkes
Series 7
914 Turbo
Kaysville, Utah
Eric M. Jones
PostPosted: Mon Jan 07, 2008 6:43 am    Post subject: Re: Exploding Capacitors? Reply with quote
KABOOOM!!!!
Come on Bob.
. . . a long habit of not thinking a thing wrong, gives it a superficial
-Thomas Paine 1776-
The question was about using a 22,000 microfarad, 25 V capacitor. The point has been raised that there is every reason to move this up to a 22,000 microfarad 100V or more and avoid early failures caused by load dump transients, and various insults.
25V does not provide enough headroom in this application. There's zero reason to skimp.
Eric M. Jones
www.PerihelionDesign.com
113 Brentwood Drive
Southbridge, MA 01550
(508) 764-2072
emjones(at)charter.net
PostPosted: Mon Jan 07, 2008 9:40 am    Post subject: Exploding Capacitors? Reply with quote
At 06:43 AM 1/7/2008 -0800, you wrote:
KABOOOM!!!!
Come on Bob.
-Thomas Paine 1776-
reason to skimp.
Really? Isn't that the reason we put ov
protection in place that trips out at 16+
volts? The capacitor is no more vulnerable
than say a radio.
In 20 years of writing for the OBAM aircraft
community, I've had one guy suffer a capacitor
failure on a Rotax powered Kitfox. He wired it
in backwards. The capacitor didn't blow up, it
opened the pressure relief valve in the top
and oozed ugly gooey stuff.
Are you telling us that the makers of these
devices are failing to tell us about the
hazards of misapplication or mistreatment
of their product? The battery guys put pressure
relief valves in their products too. It is
reasonable to suppose there's a well considered
reason for that?
Yes, I've blown up an aluminum electrolytic
but it too was in backwards and that was in 1956.
Let us take care lest we elevate an exceedingly
remote hazard to levels unworthy of learned
discussion.
Eric M. Jones
PostPosted: Mon Jan 07, 2008 11:20 am    Post subject: Re: Exploding Capacitors? Reply with quote
-Thomas Paine 1776-
Really? Isn't that the reason we put ov protection in place that trips out at 16+ volts?
Any decent overvoltage module does not trip out in time to prevent OV damage to the capacitor during load dump. Let's not depend on the OV protection to save out poorly specified capacitor. Really Bob....!
The capacitor is no more vulnerable than say a radio.
A radio has some sophisticated voltage clamping on its input. So you are wrong.
In 20 years of writing for the OBAM aircraft community, I've had one guy suffer a capacitor failure on a Rotax powered Kitfox. He wired it
in backwards. The capacitor didn't blow up, it opened the pressure relief valve in the top and oozed ugly gooey stuff.
In my 40 years of writing about and studying electronics, I've seen hundreds of capacitor failures. Most of the big electrolytics failed internally by having greatly reduced capacitance or excessive resistive loads or a variety of other problems that did not involve explosions. Really Bob....!
Are you telling us that the makers of these devices are failing to tell us about the hazards of misapplication or mistreatment of their product? The battery guys put pressure relief valves in their products too. It is reasonable to suppose there's a well considered reason for that?
What are you ranting about? I have no clue.
Yes, I've blown up an aluminum electrolytic but it too was in backwards and that was in 1956. Let us take care lest we elevate an exceedingly remote hazard to levels unworthy of learned discussion.
What is you problem, Bob? Why not just say..."Yes, that is probably right." Your version of a "learned discussion" eludes me. Backing up and taking another think at an issue would not decrease my respect for you.
Eric M. Jones
113 Brentwood Drive
(508) 764-2072
darinh
PostPosted: Mon Jan 07, 2008 3:50 pm    Post subject: Re: Exploding Capacitors? Reply with quote
Eric,
I appreciate you comments but they seem to be a bit condescending toward Bob. Is there a reason for that? If I indeed need to upsize my capacitor then I would like to hear constructive debate on the matter. Everything I have read (which granted is not much) on capacitors has stated that you want to size a capacitor to twice the system voltage to be safe. In my case, I am at 13.8 +/- so 25 V is just under twice. Is 100 Volts overkill? My 25 V capacitor was supplied by Kitfox and that is what all Kitfox aircraft are flying on as far as I know.
I just want a reliable system and rely on you guys that know more about electronics than I do to provide comments and assistance. If all we do is attack one another, it makes it hard for us less electronically educated to make a good decision.
For now, I am going to stick with the capacitor I have unless someone has a constructive and good reason not to.
Darin Hawkes
Series 7
914 Turbo
Kaysville, Utah
Eric M. Jones
PostPosted: Mon Jan 07, 2008 4:56 pm    Post subject: Re: Exploding Capacitors? Reply with quote
Eric, I appreciate you comments but they seem to be a bit condescending toward Bob. Is there a reason for that?
I am not sure condescending is the word. And YES.
100V is not overkill, because load dumps are specified by most standards as 40V (DO160)--the automotive load dump standard voltages are much higher. Any component you use that attempts to filter the alternator needs "load-dump capability". You could use a 18V Transorb (etc.) to prevent the overvoltage at the cap. Then you could get away with a 25V cap, but this would be my second choice.
See: http://en.wikipedia.org/wiki/Load_dump
I don't deny that it would work. But electrolytic caps have a finite lifetime, and they don't always give and indication that they failed. So why not do it right?
There are major philosophical differences at play here--
Eric's Game: "Latest and Greatest...Hell this is EXPERIMENTAL after all!"
Bob's Game: "Safe and reliable...we've been doing it this way since 1956!"
There is probably some comfortable place between these two viewpoints.
Eric M. Jones
113 Brentwood Drive
(508) 764-2072
Gilles.Thesee(at)ac-greno
PostPosted: Mon Jan 07, 2008 5:30 pm    Post subject: Exploding Capacitors? Reply with quote
Darin,
I believe the rationale for the 100 volts is that in case of a runaway
regulator, the alternatror is capable of throwing up to 100 V at the
ship's circuit.
I have been considering this issue from the beginning, after the bench
tests we performed with a Rotax alternator and regulator.
Another way would be to adopt the latest Z16 architecture, when the OV
modules ensures total disconnection of the alternator from the aircraft.
I recently wired a Rotax 912 aircraft with this "newer" Z16, while our
own project still retains the "older" design, with the possibility that
the 25 V capacitor burt or something in case of overvoltage. I still
have to decide whether I change the capacitor to 100 V or change the
architecture.
Nevertheless, the aircraft has been flying for 3 years to date.
Best regards,
Gilles
http://contrails.free.fr
darinh
PostPosted: Mon Jan 07, 2008 6:07 pm    Post subject: Re: Exploding Capacitors? Reply with quote
Eric,
Thanks for the info. Your explanation makes sense and I would much prefer to do it "right" or better from the get go.
Giles,
I am want to install OV protection on my airplane but don't know exactly how. I have looked at Bob's OV modules and Eric has some on his site as well. Is this something I can simply install anywhere in the power distribution system or does it need to be strategically placed like on the alt. field line? I am thinking that I would like to put it on my main buss to monitor voltage there unless this won't work. The question is...how does it "disconnect" the alternator power supply. Forgive me if this is a novice question, but I am a novice when it comes to electronics.
Darin Hawkes
Series 7
914 Turbo
Kaysville, Utah
PostPosted: Mon Jan 07, 2008 6:11 pm    Post subject: Exploding Capacitors? Reply with quote
wrong.
Hmmm . . . if you check the archives, you'll find places
where I was chastised for not acknowledging a not-to-exceed
value of 16.0 volts for some popular radios. While radios
qualified to DO-160 are not at risk when paired with
contemporary OV protection techniques, the OBAM community
is buying a hardware that is not. A DO-160 qualified, 14v
radio is tested to stand off 20 volts for 1 second.
How about 20 volts for 3 seconds . . . 5 seconds? I'll
suggest that there may be fully qualified radios that passed
the 20v-for-one-second-test that are still at risk for failure
when subjected to voltages well under the limits for a 25-volt
rated capacitor.
guy suffer a capacitor failure on a Rotax powered Kitfox. He wired it in
Really Bob....!
Yes. Capacitors fail. Capacitors have a service life.
I recommend that the computer grade electrolytics featured
in my designs be replaced every 5 years or so just a
a preventative maintenance effort. But please recall
that the topic of this thread is "exploding capacitors".
My response was a simple assertion that the risks for
hazardous failure (explosion) are exceedingly low.
I'll further assert that contemporary OV protection
philosophies and techniques are adequate to protect both
a 20-volts-for-1-second-radio and a 25-volts-for-hours-
capacitor.
I'm not ranting. It's a question built upon an
observation:
Why have a pressure relief valve? Do they
make things run longer, cooler, faster . . . or
do you suppose they are intended to mitigate
risk of explosion?
I do not sift my responses through the filter
of seeking anyone's approval or respect. Thus far, your
arguments are weak on supporting simple-ideas.
From the time an OV event begins in a contemporary
TC aircraft system until the time the runaway
alternator is brought under control is on the
order of 10-30 milliseconds with a maximum excursion
that is far less than the 25-volt rating of the
recommended capacitor. Yes, there are combinations
of failures that can trash the capacitor . . . but
the same failure will take fists full of radios with it.
If you have no argument with this statement,
then upon what alternative simple-idea do you
suggest that a capacitor be greatly more robust
than the radios which get power from the same
system?
PostPosted: Mon Jan 07, 2008 6:56 pm    Post subject: Exploding Capacitors? Reply with quote
The load dump characterized by the folks
who design DC power generation systems is
generated by (1) sudden removal all loads
from the alternator including the battery and
(2) the use of a wound-field alternator-regulator
combination common to those systems.
We're discussing PM alternators and their
regulator which are an entirely different
breed of critter.
My study of some common rectifier/regulator
products combined with my experience for having
designed a couple leads be to assert that sudden
removal of all loads, including battery from a
hard-working PM alternator will not produce
the load dump event discussed.
This isn't about philosophy, it's about the simple
ideas and the repeatable experiment. Others have
joined discussions on this List predicting all manner
of dire consequences for a host of un-demonstrated
concerns that argued with things we already knew and
understood.
If you believe my deductions to be incorrect, nobody
would be more pleased to know the truth than I.
This isn't about Eric's "philosophy" pitted against
Bob's "philosophy", it's about the numbers. You're
just as capable of doing the science as anyone else
here. Make my day, show me where I'm wrong.
dilandl
PostPosted: Mon Jan 07, 2008 7:07 pm    Post subject: Re: Exploding Capacitors? Reply with quote
All of this discussion about capacitor sizing brings up a question in my mind about the Z-25 (self exciting) arrangement for the SD-8. In this case, the alternator is not really being "shut down" by the OV module but merely disconnected from the buss. The capacitor is still being subjected to whatever the now unloaded SD-8 can muster. The Z-25 figure shows a 15-50V capacitor so does this imply that the SD-8 won't muster more than 50V?
Dan Langhout
Madison, AL
RV-7 in progress
ceengland(at)bellsouth.ne
PostPosted: Mon Jan 07, 2008 8:12 pm    Post subject: Exploding Capacitors? Reply with quote
Eric M. Jones wrote:
<emjones(at)charter.net>
all!" Bob's Game: "Safe and reliable...we've been doing it this way
since 1956!"
viewpoints.
-------- Eric M. Jones www.PerihelionDesign.com 113 Brentwood Drive
Southbridge, MA 01550 (508) 764-2072 emjones(at)charter.net
Eric, you do some cool stuff & you've got some useful ideas, but your
assessment of 'Bob's game' is absurd on its face. Anyone with brain
activity much above the plant level who's followed this list for more
than a week knows that's just a lie.
Any time I see someone try to prop up their reputation by running
down someone else personally, I've got to question their confidence in
their own position.
Charlie
dilandl
PostPosted: Mon Jan 07, 2008 8:20 pm    Post subject: Exploding Capacitors? Reply with quote
more than 50V?
Dan Langhout
<nuckolls.bob(at)cox.net>
> are wrong.
rated capacitor.
> wired it in backwards. The capacitor didn't blow up, it opened the
capacitor.
> reason for that?
observation:
risk of explosion?
> for you.
system?
Dan Langhout
Madison, AL
RV-7 in progress
PostPosted: Mon Jan 07, 2008 9:25 pm    Post subject: Exploding Capacitors? Reply with quote
At 06:07 PM 1/7/2008 -0800, you wrote:
Eric,
Giles,
The Z-figures were crafted to offer the most strategic
locations for inserting OV protection. I'll suggest that
you pick a Z-figure that most closely meets your design
goals for cost and performance and then see what
might be fixed to match your design goals completely.
In an un-restrained (failed regulator) all of the
14v PM alternators are capable of output voltages
in excess of 25 volts. That's why we consider
adding ov protection that keeps the event low in
magnitude and short lived.
But as long as there's a battery on line,
alternators of any size are incapable of boosting
voltage at a rate faster than what the ov protection
systems are designed to mitigate.
At Revision 12, all of the PM alternator drawings
will be updated to place OV disconnect in the AC
output lines of the alternator as depicted in Z-16.
dilandl
PostPosted: Tue Jan 08, 2008 6:10 pm    Post subject: Exploding Capacitors? Reply with quote
<snip>
</snip>
So what will happen to the "self exciting" feature ah la Z-25? Is this
an either/or situation?
Dan Langhout
Dan Langhout
Madison, AL
RV-7 in progress
PostPosted: Wed Jan 09, 2008 1:57 am    Post subject: Exploding Capacitors? Reply with quote
At 04:22 PM 1/8/2008 -0600, you wrote:
><snip>
> Bob . . .
></snip>
So what will happen to the "self exciting" feature ah la Z-25? Is this an
No, ALL configurations using the SD-8 will include
self-excitation. I can't recommend or even deduce the
need for adding self-excitation to other products.
I don't know enough about them. But you can certainly
use the SD-8 without this feature. There are probably
1000 or so flying with out it. The chances of really
NEEDING it are small.
