				|  | Matronics Email Lists Web Forum Interface to the Matronics Email Lists
		| Author | Message |
		| europa(at)pstewart.f2s.co Guest
				|  Posted: Mon Jan 07, 2008 6:49 pm    Post subject: copper dipole |   |
				| Anyone answer me this one.  Having spent ages soldering co-ax onto
the copper tape supplied by the factory, I've just broked the tape in
 half!  Would a piece of copper wire be of similar efficacy as t he
 copper tape - it would certainly be easier to solder to.  I'm
 guessing its the length of the dipole that's important rather that
 width or section - true or false.
 Paul
 G-GIDY (running out of jobs to do)
 | |  |  | - The Matronics Europa-List Email Forum - |  |  |  | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:http://www.matronics.com/Navigator?Europa-List
		| Back to top |  |
		| davedeford(at)comcast.net Guest
				|  Posted: Mon Jan 07, 2008 10:51 pm    Post subject: copper dipole |   |
				|  	  | Quote: |  	  | --> <europa(at)pstewart.f2s.com>
 tape in
 Paul,
 The length is the main factor determining the operating frequency of the
 antenna, while the width of the conductors determines the range of
 frequencies over which the antenna works.  Since the aviation band is rather
 wide (as a percentage of the frequency), it is desirable to use wider
 conductors.  It is no problem to repair a break in the copper tape with a
 piece of wire soldered across the break, however.  It is definitely
 mandatory to fix the coax securely to the airframe prior to soldering to the
 copper tape, so any movement of the coax will not transmit stress to the
 solder joints and the fragile copper tape.
 Dave DeFord
 N135TD
		| Back to top |  |
				|  Posted: Tue Jan 08, 2008 1:58 pm    Post subject: copper dipole |   |
				| Ferg / David
Thanks for the responses - I'll try my soldering iron first
 Paul
		| Back to top |  |
		| jimpuglise(at)comcast.net Guest
				|  Posted: Tue Jan 08, 2008 8:49 pm    Post subject: copper dipole |   |
				| Paul-
 FYI Aircraft Spruce has a reel of copper strapping material for $ 19.90.  For the work you may need to go through, it may be easier to buy it.  Also, as was mentioned, the advantage of strapping is that it is a bit more broad band than wire would be.  I assume that the manufacturers do it that way to provide more error in the event that you do not tune the antenna.  If you have a good Standing Wave bridge and can tune it, as long as you are below 2.5 - 3 to 1 at the extreme ends of the spectrum and close to flat at the most commonly used frequencies you will be transmitting on, wire would work just as well as strapping.
 Jim Puglise A-283, Punta Gorda, FL
 at con  [quote][b]
		| Back to top |  |
		| craigb(at)onthenet.com.au Guest
				|  Posted: Wed Jan 09, 2008 2:45 am    Post subject: copper dipole |   |
				| Jim  just on the note of Standing wave bridges, I have one for AM CB radios as  commonly used truckers etc, used it every time
I  replaced an aerial on my car and mates cars to correctly "tune" the aerial.I had  been thinking of using it to tune my aerial but
 wasnt sure if it was the correct one or not, any  thoughts
 craig
 [quote]   --
		| Back to top |  |
				|  Posted: Wed Jan 09, 2008 5:43 am    Post subject: copper dipole |   |
				| Craig-
 Hard to tell.  Some of them will work from HF to VHF, some will not.  Obviously, the best bet would be to use a VHF specific bridge if you can get ahold of one.  I would Google your bridge and see what the manufacturer's specifications are.
 Jim
 [quote]-------------- Original message --------------
 craig
 [quote] --
		| Back to top |  |
		| rampil
				|  Posted: Wed Jan 09, 2008 7:02 am    Post subject: Re: copper dipole |   |
				| Most consumer-type (Ha!) SWR bridges work from 1-30 MHz.
Airband VHF carrier will not excite the bridge to a full scale forward
 reading, making the reverse direction reading uncalibratible.
 Look for a ham vhf meter - a bridge that works at 144 MHz will do fine
 at 120.
 I am not sure what "copper strapping" is.  Strapping implies mechanical
 strength for binding something. Sounds heavy.  RST antennas and what
 the factory supplies is very thin copper foil.  This raises an other issue
 learned by many people the hard way:  Copper foil has a very different
 thermal contraction rate than fiberglass.  Therefore if you glue the foil
 directly to the glass and pass through a summer and a winter season,
 you will most likely find that the foil has torn.  What I did was to encase
 the foil antenna in wax paper and then glass the wax paper envelope
 to the fuselage.
 Good Luck
 Ira N224XS
		| Back to top |  |
 | You cannot post new topics in this forum You cannot reply to topics in this forum
