Tom Jones
Posted: Wed Jan 09, 2008 12:39 pm Post subject: Re: Wing Tank Fuel Finger Strainers |
| Quote: | Thank you, Tom. From your ruler, I make it about 1 mm mesh. Somewhat
oarser than my gascolator. |
Michel, I just measured the mesh best I could. A straight pin from a sewing kit will not fit. The point of the pin will go through but stops before the taper is full diameter of the pin. With calipers and feeler gage I measured this spot on the pin to be .010 (one ten-thousandths) of an inch or .254 mm.
The purpose of the finger strainers is to prevent larger debris from stopping fuel flow from the tank. A much finer filter is required in the fuel line before the carb to catch fine debris.
_________________ Tom Jones
Classic IV
Ellensburg, WA |
msm_9949(at)yahoo.com Guest
Posted: Wed Jan 09, 2008 2:18 pm Post subject: Wing Tank Fuel Finger Strainers |
I could swear the ones on my model 2 are coarser than that and don't look quite like the one in Tom's picture. I'll have to yank one to be sure. Could they possibly have supplied finer strainers with later models?
Tom Jones <nahsikhs(at)elltel.net> wrote: [quote]--> Kitfox-List message posted by: "Tom Jones"
The purpose of the finger strainers is to prevent larger debris from [quote][b]
Lynn Matteson
Posted: Wed Jan 09, 2008 2:33 pm Post subject: Wing Tank Fuel Finger Strainers |
Oops, better go sit in the corner, Tom... .010" is read "ten
thousandths" of an inch....one ten-thousandths would be .0001"
Lynn Matteson
flying w/450+ hrs
On Jan 9, 2008, at 3:39 PM, Tom Jones wrote:
Tom Jones
Classic IV, Phase one
Ellensburg, WA
http://forums.matronics.com/viewtopic.php?p=157052#157052
_________________ Lynn
Kitfox IV-Jabiru 2200
N369LM |
Tom Jones
Posted: Wed Jan 09, 2008 2:57 pm Post subject: Re: Wing Tank Fuel Finger Strainers |
| Quote: | Oops, better go sit in the corner, Tom... .010" is read "ten
Lynn Matteson |
Lynn, I guess .0001" would be pretty small mesh. Thanks for catching that.
Classic IV
Ellensburg, WA |
Lynn Matteson
Posted: Wed Jan 09, 2008 4:20 pm Post subject: Wing Tank Fuel Finger Strainers |
Now somebody can catch me....is .0001" a micron?
Lynn
On Jan 9, 2008, at 5:57 PM, Tom Jones wrote:
> Lynn Matteson
catching that.
Tom Jones
Ellensburg, WA
http://forums.matronics.com/viewtopic.php?p=157078#157078
N369LM |
rzeppin(at)cox.net Guest
Posted: Wed Jan 09, 2008 4:36 pm Post subject: Wing Tank Fuel Finger Strainers |
A Micron is One Millionth of a Millimeter, or Thirty Nine Millionths of
an inch (.000039")
Ron
Lynn Matteson wrote:
Lynn
>> Lynn Matteson
> that.
> Tom Jones
> 503 Rotax, 72 inch Two blade Warp
> Ellensburg, WA
Michel
Posted: Wed Jan 09, 2008 11:33 pm Post subject: Wing Tank Fuel Finger Strainers |
On Jan 9, 2008, at 9:39 PM, Tom Jones wrote:
| Quote: | I measured this spot on the pin to be .010 (one ten-thousandths) of
an inch or .254 mm.
Thanks, Tom. That's finer that I thought.
Regarding the 'ten thousandth vs. one ten thousandth' it is easy to
mistake. Ask a friend what is greater, zero point twelve or zero point
six. Many will answer; the former.
Michel Verheughe
Norway
Kitfox 3 - Jabiru 2200
N81JG(at)aol.com Guest
Posted: Thu Jan 10, 2008 8:32 pm Post subject: Wing Tank Fuel Finger Strainers |
A micron (short for micrometer) is 1 millionth of a meter (one micrometer) . A millimeter is 1 thousandth of a meter. Milli means 1 thousand and micro means 1 million. As a clinical pathologist for 30 years I dealt with those units regularly.
John Greaves
Redding, CA
Start the year off right. Easy ways to stay in shape in the new year.
