		dvanlanen
				 Posted: Thu Jan 10, 2008 5:55 pm    Post subject: Best Tool For Doing Cutouts |
				What are other builders finding as the best tool for doing cutouts, such as access holes, trim tab cutouts, etc.?   I do not use the Wiss snips because they tend to stretch the metal.  I have an OLFA knife, which works great when cutting out flat stock, where the material can be backed up, but I can’t figure out how to safely use it on a structure where the material cannot easily be backed up.  I am currently using a Dremel tool with a cutting disk.  It works well but it is risky, as the cutting wheel can “catch” on the material.  This happened to me today, and put a slight abrasion on the skin – luckily it was not serious.
 Any advice would be appreciated, even if it means I gotta buy another tool.
 Dave Van Lanen
 601XL - Elevator     [quote][b]
  |  | - The Matronics Zenith-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
		rjscep(at)yahoo.com Guest
				 Posted: Thu Jan 10, 2008 7:32 pm    Post subject: Best Tool For Doing Cutouts |
				 	  | Quote: | 	 		   I'm using a stepdrill to start the hole, then use
  aviation snips. If thats too tough, then use a
  series of small holes with a drill bit close to the
  edge, then use a file to finish it....Do not archive
 --- Dave VanLanen <davevanlanen(at)sbcglobal.net> wrote:
  	  | Quote: | 	 		   What are other builders finding as the best tool for
  be backed up, but I
  can't figure out how to safely use it on a structure
  where the material
  Dremel tool with a
  cutting wheel can
  "catch" on the material.  This happened to me today,
  and put a slight
  abrasion on the skin - luckily it was not serious.
  Dave Van Lanen
  601XL - Elevator
 Never miss a thing.  Make Yahoo your home page.
 http://www.yahoo.com/r/hs
		sky_ranger161
				 Posted: Fri Jan 11, 2008 4:08 am    Post subject: Best Tool For Doing Cutouts |
				Hey!
 Go to your favorite airplane parts store online and search for "hand nibblers." I got one for $20 from Avery Tools and wished Id discovered it two years ago. Great tool.
 Debo Cox
 Nags Head, NC
 XL/Corvair
 Wings 85% done
 www.mykitlog.com/debo
 ROBERT SCEPPA <rjscep(at)yahoo.com> wrote:[quote] --> Zenith-List message posted by: ROBERT SCEPPA
 --- Dave VanLanen  wrote:
 [quote] What are other builders finding as the best tool for
  access holes, trim tab cutouts, etc.?   I [quote][b]
		dj45
				 Posted: Fri Jan 11, 2008 6:31 am    Post subject: Re: Best Tool For Doing Cutouts |
				Dave, I would suggest that you take a few pieces of scrap and practice some. I have used wiss snips for over 40 years and if done right, they don't stretch the metal. Use GOOD snips, not the cheap ones.
  _________________ Do not archive
Dan Stanton
N801S CH 801
N226BS CH701
N24DS CH750 |
		jmcburney(at)pobox.com Guest
				 Posted: Fri Jan 11, 2008 7:47 am    Post subject: Best Tool For Doing Cutouts |
				I found a Dremel attachment at Lowe's that made it a kind of junior Rotozip.
 It works well, but BE CAREFUL!  Hold it tight when using, as it will want to
 pull to one side.  You've got to show it who's master.  Cut slightly inside
 the line, then use a Jilson cutter to trim, then finish with a file. I cut
 my rear windows this way, on the plane, vertically, and had no (well, not
 many) problems.
 Jim
 CH-801
 DeltaHawk diesel
 90% done 95% left
		darrellhaas(at)gmail.com Guest
				 Posted: Fri Jan 11, 2008 8:18 am    Post subject: Best Tool For Doing Cutouts |
				OK, I also use a Dremel Tool but what is a Jilson Cutter?
 Darrell
 On 1/11/08, Jim McBurney <jmcburney(at)pobox.com> wrote:
  many) problems.
  Jim
  CH-801
  DeltaHawk diesel
  90% done 95% left
		cgbrt(at)mondenet.com Guest
				 Posted: Fri Jan 11, 2008 8:35 am    Post subject: Best Tool For Doing Cutouts |
				Dave
  I use a step drill to to punch starter holes close  to the edges (3/4" to 1") . If it's a square panel four holes near the corners  then good right and left hand snips  with vertically offset handles to make  a rough cut to remove most of the panel. Folow with a final cut just short of  the line then finish with appropriate file and polish to finish the  edges.
  Carl
  [quote]   ---
		dredmoody(at)cox.net Guest
				 Posted: Fri Jan 11, 2008 8:51 am    Post subject: Best Tool For Doing Cutouts |
				That's what you use to cut your Jilsons,
 Dred
 ---- Darrell Haas <darrellhaas(at)gmail.com> wrote:
  Darrell
  > many) problems.
  > Jim
  > CH-801
  > DeltaHawk diesel
  > 90% done 95% left
		Tim Juhl
  Joined: 21 Mar 2006 Posts: 488 Location: "Thumb" of Michigan
				 Posted: Fri Jan 11, 2008 1:05 pm    Post subject: Re: Best Tool For Doing Cutouts |
				I would avoid power cutters unless you are using them just for rough cuts. You really don't want to screw up those 12 foot wing skins and the like.  I bought a power nibbler that you insert in a drill but found it too hard to control when making fine cuts.  I use it for rough cuts and then finish with a hand tool.
 For inspection holes I use a fly cutter (turned by hand) for the round holes and an olfa knife to score the lines between them.  Drill a large hole in the waste with a step drill and then use shears, nibblers or whatever to cut the part you're removing into sections that can be wiggled to break along the scored lines.  A good selection of files will be helpful in any case.
 Regarding backing up the material being scored - I have at times cut some specific backup pieces out of scrap wood.   For example, a wedge to go inside a control surface where I am cutting out a section for a trim tab.  I also have a couple of flat pieces with holes drilled to match the shaft of the flycutter which have been very useful in doing inspection holes.
  _________________ ______________
CFII
Champ L16A flying
Zodiac XL - Jabiru 3300A
Almost done! It'll fly in spring! |
		mhilderbrand
				 Posted: Fri Jan 11, 2008 1:58 pm    Post subject: Best Tool For Doing Cutouts |
				Got my hand nibbler from Radio Shack for around $6
 Michael Hilderbrand
 Derby, Kansas
 Http://www.kansasflying.com
		gary(at)liming.org Guest
				 Posted: Fri Jan 11, 2008 2:33 pm    Post subject: Best Tool For Doing Cutouts |
				At 10:17 AM 1/11/2008, you wrote:
 Darrell
 If you go to www.liming.org/ch801/tools,html
 there is a picture of a Jilson tool about halfway down.  (actually it
 is a picture of a Harbor Freight cheap clone of a Jilson tool.)
 Gary L.
