JimmieBlackwell(at)austin Guest
Posted: Sat Jan 12, 2008 7:55 am Post subject: Wing Tank Finger Fuel Strainers |
Since I was the one that started the discussion on fuel strainers I wanted to report the outcome on mine. I removed and reinstalled mine yesterday without any difficulty. After 13 years and 440 hours on the 912UL engine the strainers were completely clear. I guess that says a lot for using, "Mr. Funnel", to filter fuel.
Jimmie
dave
Posted: Sat Jan 12, 2008 8:09 am Post subject: Re: Wing Tank Finger Fuel Strainers |
| Quote: | | I guess that says a lot for using, "Mr. Funnel", to filter fuel. |
I filter most gas in my planes. Only exception is at marinas when they busy or windy and cannot get it done as quick. I have a gascolator very rarely see anything but gas in it.
Hundreds of Kitfox Movies
Most viewed Kitfox on youtube
Most popular on youtube
Highest rated on youtube |
Lynn Matteson
Posted: Sat Jan 12, 2008 12:19 pm Post subject: Wing Tank Finger Fuel Strainers |
I'll second the use of Mr. Funnel, Jimmie...when I fuel up at home
hangar. When on the road, and getting my 100LL from the airports, I
pump straight in. No issues yet. Neither of my "just-below-the-tanks"
Purolator filters have had to be changed yet, nor do they show any
indication of any accumulated crap in 460 hrs.
Lynn Matteson
flying w/460+ hrs
On Jan 12, 2008, at 10:53 AM, Jimmie Blackwell wrote:
| Quote: | Since I was the one that started the discussion on fuel strainers I
Jimmie
http://www.matronics.com/Navigator?Kitfox-List_-
forums.matronics.com_-
contribution_-
_________________ Lynn
Kitfox IV-Jabiru 2200
N369LM |
Float Flyr
Posted: Sat Jan 12, 2008 5:18 pm Post subject: Wing Tank Finger Fuel Strainers |
Lynn: I had a look at the Mr.Funnel at the local Crappy Tire store. Canada's answer to a have it all hardware, come auto parts, come marina, come garden center, come... You get the idea.
They were very expensive but the ones in stock must have been a low end model because they only had a cone shaped screen in the centre instead of the normal flat screen. There was nothing different about that funnel. The label did mention a different model that is supposed to remove water from fuel (as long as there is no ethanol in it)but so far I haven't been able to actually get to see one of those funnels.
When I was a kid I used to use an old felt hat to filter the gas for my outboard motor. I think they call that felt a chamois now days. The good thing about using the hat is I always had it handy and when the gas was fresh it would keep the flies, and me, away for a couple of hours. J All the planes I serviced had a big funnel and a big felt in the storage compartment. None of them ever had water in the fuel.
Speaking of water in the fuel I had an acquaintance once who gassed up his Lake, LA-4 at Stephenville (CYJT). He back fired and missed all the way down the 12000’ runway, got airborne and at around 150’agl had the engine, after much sputtering, quit. His gear was already up when he tried to turn back and, well, we all know what happens in that situation. High attitude, low speed, no power and a steep turn are the main points of the recipe.
Hindsight is always 20 20. Things he should have done. 1. After fuelling the plane he should have taken 20 minutes for a coffee to let the fuel and any water in it settle. 2. He should have dripped all his sumps 3. He should have cut the power at the first backfire an found out what caused it 4. He should have landed straight ahead in the salt water... LA-4s are pretty good at landing in water. I intentionally left out using a filter because the airport nozzles had Purolator filters installed. Of course pressure from the fuel pumps could/did push water through the filters.
I must be getting tired... I think I’m rambling
Noel Loveys
AME Intern, RPP
Kitfox III-A, 582,B box
Ivo IFA, Aerocet 1100 floats
_________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
Lynn Matteson
Posted: Sat Jan 12, 2008 7:15 pm Post subject: Wing Tank Finger Fuel Strainers |
Noel-
Go to www.mrfunnel.com/Models.html for a look at the different
models. There is even a demo, but I couldn't get it to play. My eMac
computer is powered by a Jabiru, so it is extremely slow, I guess. : )
Anyway, the models are shown there, and I'm pretty sure I have the
F3, which flows 3.9 gpm. think they all have the cone...actually it
is a cylinder...sticking straight up in the centr of the funnel. I
see this as allowing more screen surface than a flat screen. The
largest one flows 15 gpm, and has two screen cylinders sticking up in
the middle of the funnel. The plastic is supposed to be conductive,
which helps prevent static electricity from ruining your day. I
recall getting the F3 because it contains a nice number, (ha, ha) and
because of its size, which I could store in my baggage compartment if
I so chose.
Lynn Matteson
flying w/460+ hrs
On Jan 12, 2008, at 8:17 PM, Noel Loveys wrote:
[quote] Lynn: I had a look at the Mr.Funnel at the local Crappy Tire
those funnels.
Noel Loveys
AME Intern, RPP
N369LM |
dave
Posted: Sun Jan 13, 2008 3:30 am Post subject: Re: Wing Tank Finger Fuel Strainers |
Mr funnel is available very easy just click on link and you all set
http://www.cfisher.com/mrfunnel.html
Posted: Thu Jan 17, 2008 7:36 pm Post subject: Wing Tank Finger Fuel Strainers |
Never did see this one on the list, so am sending it again. Thanks again to all for your assistance.
Jimmie
