darinh
Posted: Sat Jan 12, 2008 10:37 pm Post subject: Mandatory Gearbox SB on 912/914's - Check yours |
For those of you who aren't registered on the rotax owners site:
Rotax has issued a mandatory service bulletin (SB) on all 900 series engines. The SB is mandatory and involves defective gears that can loose teeth and cause major problems. Rotax has put a date for compliance of April 30, 2008. Here is a link to the SB
http://www.rotax-owner.com/si_tb_info/serviceb/SB-912-056UL.pdf
I got lucky and my gearbox S/N is not one of the affected ones. I suspect with the number of 912's on this list, some will be affected. Remember, the S/N on the gearbox is the important one, not the engine.
_________________ Darin Hawkes
Series 7
914 Turbo
Kaysville, Utah |
dave
Posted: Sun Jan 13, 2008 3:49 am Post subject: Re: Mandatory Gearbox SB on 912/914's - Check yours |
This is what Bob had to say about it ...
It only effects the 912-S series.... unless you had your gear box
rebuilt, then you need to check the serial no.'s on the gear set. Very few
engines/gear boxes in Canada are effected.
If you did have your gear drive serviced and the gears replaced, check your
work order.
regards
Bob Robertson
Light Engine Services Ltd.
Rotax Service Center
Aero Control Enterprises, Inc.
St. Albert, Ab. T8N 1M8
Ph: (Tech Support) 1-780-418-4164
Ph: (Order Line) 1-866-418-4164 (TOLL FREE)
www.rtx-av-engines.ca
www.aerocontrols.net
Hundreds of Kitfox Movies
Most viewed Kitfox on youtube
Most popular on youtube
Highest rated on youtube |
