engine selection
Goto page Previous  1, 2, 3  Next
av8rps
PostPosted: Sat Jan 12, 2008 8:31 pm    Post subject: Re: engine selection Reply with quote
[quote="Lynn Matteson"Be cautious of any engine that flipped, Steve. It might have suffered a prop strike, and might have a bent crank..)
Steve,
That 912 gearbox (you know, the one the Jab flyers leave at home Smile ) will save a crankshaft from damage. But of course the gearbox could have suffered damage if it was a hard hit. So you probably need to learn more about the details of the crash if you want to make a better assessment of the engines condition. Zero timing it might be a good idea, but unless it really took a hard hit, or has tons of hours on it, you probably will just need a reputable shop to check it over and give it a blessing. There are some 912s out there now that have been torn down with 2500+ hours on them and needed almost nothing.
For anyone concerned about all the 912 bulletins; I know some of the non-912 owners like to make note about all of Rotaxes service bulletins/AD's on the 912s, as if the engines have countless problems. But that's not the case. After 29 years in the auto industry, I learned a long time ago its the companies that never produce service bulletins or recalls that have the products you should be suspect of. No one builds a perfect, problem free product. Big companies tend to have systems and procedures (or whole divisions) in place to make sure as they learn about problems, they work to solve them and then inform their customers, in the case it may affect them. Small companies are usually too small to be quite so organized, or have the number of products in service to provide a good database of problems, so the customer doesn't usually hear anything unless they have catastrophic failures that can't be ignored. Rotax/bombardier certainly qualifies as a large aircraft engine mfr, not to mention also has certified aircraft engines in service around the world. Therefore they have a good system in place to alert their customers of any issues that might concern them. Besides my 912, I also have a Lycoming 0-360 in an airplane. While the 0-360 Lyc is pretty much proven to be one of the most bulletproof aircraft engines in history, over the years I have received piles of bulletins and AD's for it. Fortunately, just like the Rotax info, most is not anything I have to do anything about. But it's nice stuff to know about my engine(s). It's worked to keep my 44 year old Lycoming running safely and reliably all these years, so I believe having that knowledge on my 912 is likely to provide a similar level of service from my Rotax engine.
Oh yeah, I agree with Clint. So if you decide not to buy it let me know, I will Smile
Paul Seehafer
Model IV-1200 912ul Amphib
Avid Flyer Sn#1 and Sn#26
Highlander 912s taildragger
Lake Amphibian
Central Wisconsin
paul676@tds.net
shinco(at)bright.net
PostPosted: Sat Jan 12, 2008 11:12 pm    Post subject: engine selection Reply with quote
a prop strike, and might have a bent crank...a couple of MIGHT's here
is all.
Lynn Matteson
Grass Lake, Michigan
flying w/460+ hrs
On Jan 12, 2008, at 8:42 PM, av8rps wrote:
> (Steve Shinabery wrote; been looking at the Jab 2200..BUT now I found
> a 100 hp.,rotax that is out of a KF in texas. I can buy the engine
> with every thing with it..for $4000.00..)
> Steve,
> Don't waste any time making up your mind on that one. That will not
> be easy to find again...
> I believe the first Kitfox to have a 912 was a model 2. So I can't
> see any reason yours wouldn't accept the engine. Only thing I have
> to tell you is, you had better HANG ON the first time you crack that
> throttle! A 100 hp 912 on a model 2 is going to be a real
> rocketship!!! If you work at it, you could end up with a 575 lb
> airplane. That'll give you a 5.75 lbs per hp power loading (e.w.).
> That's almost 30% better than a new kitfox with a 914. So as I said,
> you'll have a real rocketship! Oh yeah, having the undercambered,
> high lift wing, you should have one awesome short field, climbing
> monster as well! But you will have to learn to keep a close eye on
> your VNE and maneuvering speeds, as you'll most likely blow by them
> so quickly it will scare you...
> But oh, what great fun all that sounds like!!!!!
> Paul Seehafer
> Avid Flyer
> Lake Amphibian
> Central Wisconsin
> paul676(at)tds.net
> http://forums.matronics.com/viewtopic.php?p=157733#157733
Thanks for your input Lynn,,Steve Shinabery N554KF KF2
PostPosted: Sat Jan 12, 2008 11:32 pm    Post subject: engine selection Reply with quote
Steve,
For anyone concerned about all the 912 bulletins; I know some of the non-912 owners like to make note about all of Rotaxes service bulletins/AD's on the 912s, as if the engines have countless problems. But that's not the case. After 29 years in the auto industry, I learned a long time ago its the companies that never produce service bulletins or recalls that have the products you should be suspect of. No one builds a perfect, problem free product. Big companies tend to have systems and procedures (or whole divisions) in place to make sure as they learn about problems, they work to solve them and then inform their customers, in the case it may affect them. Small companies are usually too small to be quite so organized, or have the number of products in service to provide a good database of problems, so the customer doesn't usually hear anything unless they have catastrophic failures that can't be ignored. Rotax/bombardier certainly qualifies as a large aircraft engine!
Paul Seehafer
Avid Flyer
Lake Amphibian
Central Wisconsin
paul676(at)tds.net
http://forums.matronics.com/viewtopic.php?p=157761#157761
Thank You again Paul.every one has been a good help and support here for
me..and Thanks to all...Steve Shinabery N554KF KF2 + the little 582
that could
Michel
PostPosted: Sun Jan 13, 2008 1:21 am    Post subject: engine selection Reply with quote
On Jan 13, 2008, at 2:21 AM, Noel Loveys wrote:
Did you install a pressure cowl to direct cold air down through the
cooling
fins?
I did as much as I can what is done on the Jabiru aircraft, Noel. I use
the Jabiru ram-air ducts with the in-built deflectors. I measured the
openings for the two ducts and the oil cooler from a Jabiru aircraft
then moulded from my own cowling, something that matches exactly that.
I made the opening under the firewall with a 'lip' so that it would
create a low pressure and suck the air through the cowling. As a
result, I never have cylinder temperature problem.
But one must also remember that a propeller is a part of the propulsion
unit. For example, I read that some propeller are good, but not good
for an air-cooled engine because there is not enough pitch at the root
of the blade.
My Scandinavian Jabiru dealer buys both engines and aircraft that he
ships from Australia in containers. He has built many Jabiru aircraft
and I did the right thing: Follow his instructions by the letter. Then,
when the engine was installed, I flew my Kitfox to the other side of
Norway, where he lives, and showed it the engine. Apart from a couple
of small details, he said: "Good job, lad!"
Cheers,
Michel Verheughe
Norway
Kitfox 3 - Jabiru 2200
Lynn Matteson
PostPosted: Sun Jan 13, 2008 5:29 am    Post subject: engine selection Reply with quote
And just to keep the truth available to the public, Jabiru is NOT the
best company in the world to alert the buyer about potential
problems. They don't have an alert system in place to do that, but us
buyers are hoping they will someday. The info is out there, but the
owner has to go looking for it. You'd think that every buyer of one
of their engines would be on a mailing list, or at least a list in
the dealer's possession, but apparently they don't work that way...yet.
Lynn Matteson
flying w/460+ hrs
Paul Seehafer
Avid Flyer
Lake Amphibian
Central Wisconsin
paul676(at)tds.net
Lynn
Kitfox IV-Jabiru 2200
N369LM
occom
PostPosted: Sun Jan 13, 2008 6:55 am    Post subject: engine selection Reply with quote
Hi Lynn, it could be worse. The Jabiru dealers here in Canada are so
unresponsive, I wondered if they had gone out of business on the Jabiru
list. All I wanted was a little information. They awoke from their coma long
enough to call me a liar on the Jabiru list and promply went back to sleep.
I cannot get any response from them at all. I've resolved to not worry about
the engine for now but I won't spend money with these guys at all. There are
a lot of enines out there, Rotax is the safest bet at this time.
Dave Goddard- Mod IV 1050/582
Lynn Matteson
PostPosted: Sun Jan 13, 2008 9:38 am    Post subject: engine selection Reply with quote
I've only had two issues with my engine, and resolved both by myself.
I mentioned both issues to all three dealers in the United States,
and none had heard of the problems I had. At the time I had gone over
the 200 hr warranty/guarantee so I wasn't even looking for their
help. I did however, have a muffler fail, (within the 200) that was
my own fault for modifying it and not physically supporting the
modification, and they backed that mistake. So other than not having
a direct pipeline from the company to the owner, my dealer has stood
by my engine. I subscribed to the Rotax Service Bulletin...or
whatever it's called...just to see how they handle their customer
notification system, and I've got to say, it's pretty impressive.
Given the length of time they've been cranking out the motors, Rotax
should be the leader in customer satisfaction. Now if J can copy R's
information pipeline, a whole lot of J owners will be a lot happier
Of course I can't let this opportunity pass:
Maybe J doesn't feel like they need to work on their customer
satisfaction problem, because the customers are already satisfied
just owning a J...not buying that? I didn't think so, but in these
current times of political BS, I thought I might try to fly that
one. : )
Lynn Matteson
Kitfox IV Speedster w/Jabiru 2200 (pretty well satisfied owner)
flying w/460+ hrs
so unresponsive, I wondered if they had gone out of business on the
Jabiru list. All I wanted was a little information. They awoke from
their coma long enough to call me a liar on the Jabiru list and
promply went back to sleep. I cannot get any response from them at
all. I've resolved to not worry about the engine for now but I
won't spend money with these guys at all. There are a lot of enines
Lynn
N369LM
Michel
PostPosted: Sun Jan 13, 2008 11:38 am    Post subject: engine selection Reply with quote
On Jan 13, 2008, at 6:36 PM, Lynn Matteson wrote:
Now if J can copy R's information pipeline, a whole lot of J owners
I agree that Jabiru has a lot to learn from Rotax when it comes to
customer support. This being said, I could be because - as opposed to
Rotax - Jabiru makes engines to primarily power their aircraft. Maybe
they provide better customer support to those who buy Jabiru aircraft,
I don't know.
I can also add that while I was pleased with the engine, I think they
could improve their user manual. It looks like a PDF document where
different engineers have individually added different notes ... which
is probably how it went.
I think that Jabiru leaves entirely customer support to the national
dealers. Then it's a matter of meeting the 'nice and friendly dealer.'
I met mine. He even calls me by phone now and then, to enquire how
things are going. When somebody writes something on the Jabiru list, he
writes to me, in Norwegian, giving me his version of the problem. So, I
am quite please with my dealer but I understand that not everyone has
the same experience. Ah well, I am the lucky guy, I know! Smile
Cheers,
Michel Verheughe
Norway
av8rps
PostPosted: Sun Jan 13, 2008 1:48 pm    Post subject: Re: engine selection Reply with quote
("Lynn Matteson says "Of course I can't let this opportunity pass:
just owning a J...not buying that? I didn't think so....)
Lynn,
Yeah, you're right. I dont' buy that Smile But I want to say thanks for giving all of us a heads-up on the realities of owning and operating a Jabiru. Personally I hope they can continue to improve their support, as there is definitely a place for their engines in the light sport aircraft world. And frankly, I think it is a nice engine. There aren't a lot of jabiru owners yet, but of the ones I've heard from (like yourself) they are quite happy with their engines. That says a lot for a relatively new product. And as Iv'e said before, I like the simplicity of the Jab much more than all those hoses and such the 912 has.
One thing that has somewhat surprised me however about the Jab, is while the engine is advertised to be much lighter than the 912, empty weights aren't necessarily in agreement with that. As an example, my Model IV-1200 long wing was originally 627 pounds empty (currently closer to 650 due to add ons) with my 912ul, IVO inflight prop, electric engine heater, all plexiglass windshield, turtledeck and bubble doors, full panel, carpet, heater core type cabin heat with an electric fan, heavy 4 ply 8:00 X 6 aircraft tires, heavy paint, heavy plastic strut fairings for wings and horizontal stab, electric trim, wingtip strobes, landing and nav lights, dual brakes, 2 built in Gps's, solid baggage floor, electronic dual tank senders with sender covers glassed into top of wing tanks, etc, etc.
As I recall, your Jabiru 2200 model IV is a very similar weight? So how does it compare option wise? Comparing our similar model IV Kitfoxes is the best way to compare apples to apples for the group.
Paul Seehafer
Ps - here's a shot of my panel so you can compare it to yours for equipment
 Filesize:  332.68 KB
 Viewed:  1378 Time(s)
Lake Amphibian
Central Wisconsin
paul676@tds.net
Lynn Matteson
PostPosted: Sun Jan 13, 2008 3:16 pm    Post subject: engine selection Reply with quote
Paul-
Mine weighed 650 lbs at the weigh-in, and I've probably added another
20 with x-ponder, different radio, heat muffs, scat hose, etc. I'll
compare what my plane has and try to list what might be different. If
I skip an item, it means I have about the same thing.
Short wing, fixed-pitch prop, (no on-board engine heater), semi-full
panel, but mostly VFR, (no "weighty" heater other than heat muffs and
scat hose) wheel pants, same plastic strut fairings w/fabric and
paint, (no fairings on hort. stab), (no landing lights), one GPS,
baggage sack, (no electronic senders for fuel, just sight gauges). I
do have an airfoiled vertical stab and rudder, my own rib design and
rudder fairing...possibly heavy, and I have the 3-leaf tailwheel
spring, but with a Homebuilders Special (ACS) wheel. I just compared
my panel with yours, and they are nearly comparable. I have an EIS,
and you have more gauges, etc. I have the Grove gear.
As I write this, I can't help but think that the best way to compare
weights of these engines is to put the engines on the same scales and
get the apples and oranges out of the equation. After all, were your
aircraft scales and the ones that were used to weigh my plane the
same calibration?(mine were digital, rented from a local FBO repair
station) Hard to say, and as long as there is this competition among
engine suppliers, there will always be that little bit of commercial
"cheating" going on among the merchants.
I recall a Norman Rockwell painting that showed a butcher pushing
down on the scales, while the customer was pushing up? I'd like to
see a modern day drawing/picture of a Jabiru and a Rotax on the
balance scales, and see all the shenanigans that would go on behind
the scenes. : )
Seriously, I would like to see an honest weighing using all the stuff
that is needed to get the respective engines installed, i.e.,
mufflers, airducts, air boxes, starters, radiators, coolant, etc.
EVERYTHING that is required to make the engine run in the plane.
Why doesn't some enterprising magazine such as we subscribe to, do
this? Loss of advertising dollars from the losers is the probable
answer, but then, I'm a skeptic by nature. : )
Lynn Matteson
flying w/460+ hrs
Lynn,
Paul Seehafer
equipment
Avid Flyer
Lake Amphibian
Central Wisconsin
paul676(at)tds.net
http://forums.matronics.com/viewtopic.php?p=157858#157858
http://forums.matronics.com//files/pict0375_2_661.jpg
Lynn
N369LM
av8rps
PostPosted: Sun Jan 13, 2008 4:26 pm    Post subject: Re: engine selection Reply with quote
(Lynn Matteson wrote "]Paul- Mine weighed 650 lbs at the weigh-in, and I've probably added another 20 with x-ponder, different radio, heat muffs, scat hose, etc....)
Lynn,
This is interesting information. Looks like our Model IV kitfoxes are a lot the same, even though they vary by options. We each have things that are heavier than the others plane, but also have things that are lighter. So all in all it seems to pretty well balance out. Not scientific, but generally it goes to prove there isn't a substantial difference between the Jab and the Rotax by the time the airplane is done
I weighed my plane three times, twice on wheels, and once when when putting it on the floats. I only used electronic scales when doing the float W&B, but the numbers jived pretty well with what the other scales told us. So I believe my numbers are relatively accurate. My empty weight numbers also are pretty average when comparing to other 912 Model IV's, which run between 625 and 675 lbs typically.
I agree weighing engines as you described would be best. But really, average numbers for the various models will give the group here a good feel for what they can expect for average weights.
I've learned a long time ago that even though the specs say one thing, by the time you get the airplane done, it can be all different. A good example of that is my buddy that built an Avid Mark IV with a 618 rotax a few years back. After flying it a couple of years he replaced the 618 with a 912 ul, and his net empty weight gain was only 12 pounds. We all tried to figure out how that could be, but in the end gave up trying to figure out how that was possible. He's too busy flying the airplane now to worry about it. But it still mystifies all of us, including him.
I hope the group can further this study of various models with various engine weights. That could be really useful information for any of us.
Paul Seehafer
Lake Amphibian
Central Wisconsin
paul676@tds.net
KITFOXZ(at)aol.com
PostPosted: Sun Jan 13, 2008 5:57 pm    Post subject: engine selection Reply with quote
In keeping my final engine decision open until I absolutely need to make it, I found this spreadsheet very interesting to see all values on a single page. I took the liberty of massaging it a bit into a format I am liking. All of you guys who have info for the blanks yet to be filled, please spit your numbers out.
John P. Marzluf (John Z.)
Columbus, Ohio
Series V Outback (Out Back In The Garage)
20% Complete, Not Currently Building
In a message dated 1/13/2008 6:17:20 P.M. Eastern Standard Time, lynnmatt(at)jps.net writes:
--> Kitfox-List message posted by: Lynn Matteson <lynnmatt(at)jps.net>
Paul-
the scenes. : )
Lynn Matteson
flying w/460+ hrs
--> Kitfox-List message posted by: "av8rps" <paul676(at)tds.net>i.e.
Lynn,
for giving all of us a heads-up on the realities of owning and�
how does it compare option wise? Comparing our similar model IV�
Paul Seehafer
equipment
Avid Flyer
Lake Amphibian
Central Wisconsin
paul676(at)tds.net
&he es y --> - MATRONICS WEB FORUMS nbsp; - List Contribution Web Site ; � =========================
Start the year off right. Easy ways to stay in shape in the new year.
Enginechoices_rev2.xls
Download
 Filename:  Enginechoices_rev2.xls
 Filesize:  27 KB
 Downloaded:  379 Time(s)
Lynn Matteson
PostPosted: Sun Jan 13, 2008 6:22 pm    Post subject: engine selection Reply with quote
This sounds like the groundwork for an interesting magazine
article...one that would help a lot of folks make the decision as to
engine selection. The only true and honest way to do it would be to
actually have access to the engines in question. Why this hasn't been
done is beyond me...or has it? There must have, by now, been done a
survey of all the available engines that are appropriate for the
homebuilders needs? If not, why not? Sounds like an article that
should be written by Kitplanes to me....maybe a joint venture between
Kitplanes, Sport Pilot, Sport Aviation...others? Maybe that's not a
good idea either. But there could be an impartial weighing at a
central site....hey....how about Oshkosh this year? It's supposed to
be about "experimental aviation" isn't it? Well, here's a perfect
format for something that is really in the homebuilders' minds.
Oshkosh has long been going to "showtime" and forgetting the little
guy who was the reason behind it all. Why not a forum at Oshkosh
where the engine suppliers bring their engines in and get them
weighed. Wait a minute, I'm way ahead of you...AFTER the
weighing....the engine would have to be started and run for a to-be-
determined length of time...maybe even flown in a plane by the guy
who is standing behind that engine. That would eliminate the empty
blocks, the featherweight crankshafts, etc. And make it a claiming
competition, where the engine would have to be sold at the going
price, so no super-light mods would be made that would be
prohibitively costly to the supplier.
This may be a radical thought, or series of thoughts, but I believe
along these lines there is some merit. There is an engine-builders
competition that has been shown on Speed Channel, where NASCAR engine
builders assemble an engine, racing against the clock and another
team, to see who can get an engine together the fastest, make it run
for a couple of minutes, and then have all the torques checked to be
sure somebody didn't just spin a nut on and call it "done."
Maybe we could have a forum where individuals could bring in their
planes, pull the engine, and weigh it. Impartial judges could be on
hand, and certified scales, and the results made available by the
weeks end. Hell, I'd be willing to pull my engine right then and
there for a weighing, then reinstall it and go fly it. Participants
could be given some sort of "badge of courage" for their efforts,
like the mug they give for participation in the Homebuilder's Review.
By Jove, I do believe I'm on to something here!
The previous writing is copywrited by Lynn C. Matteson, author, and
in no way shall the ideas contained herein be stolen, used, copied or
otherwise "ripped off" without due compensation. : )
Lynn Matteson
flying w/460+ hrs
Lynn,
lbs typically.
for any of us.
Paul Seehafer
Avid Flyer
Lake Amphibian
Central Wisconsin
paul676(at)tds.net
http://forums.matronics.com/viewtopic.php?p=157880#157880
Lynn
N369LM
msm_9949(at)yahoo.com
PostPosted: Sun Jan 13, 2008 9:08 pm    Post subject: engine selection Reply with quote
Thank you John. (Whew)
Columbus, Ohio
Paul-
the scenes. : )
Lynn Matteson
flying w/460+ hrs
Lynn,
Paul Seehafer
equipment
Avid Flyer
Lake Amphibian
Central Wisconsin
paul676(at)tds.net
&he es y --> - MATRONICS WEB FORUMS nbsp; - List Contribution Web Site ; =========================
Marco Menezes
Model 2 582 N99KX
PostPosted: Sun Jan 13, 2008 9:09 pm    Post subject: engine selection Reply with quote
Great idea Lynn. I know just the guy to write the article. Verrry experienced. Wink
Lynn Matteson <lynnmatt(at)jps.net> wrote:
[quote]--> Kitfox-List message posted by: Lynn Matteson
Lynn Matteson
flying w/460+ hrs
[quote] --> Kitfox-List message posted by: "av8rps"
Lynn,
lbs typically.
for any of us.
Paul Seehafer
Avid Flyer
Lake Amphibian
Fox5flyer
PostPosted: Mon Jan 14, 2008 4:43 am    Post subject: engine selection Reply with quote
Interesting post Lynn. I also agree that all this talk about engine weights
and airplane weights means nothing because no two setups are alike and
people don't weigh things the same way, nor are they all weighed on the same
set of scales. This engine weight debate has been a common thread here on
this list for as long as I can remember and other than a whole bunch of
opinions, nothing has been accomplished and the issue usually just fades
away until someone else brings it up and brags about how much their airplane
weighs. Then it starts back up again with the same result.
Your proposal is a bit radical, but definitely has some merit and it may
lead to something useful, but it takes a central and credible overseer,
possibly the EAA. As we all know, advertising engine weights is especially
critical when comparing air cooled vs liquid cooled engines because the
liquid cooled engine requires many more components to be operable and those
components need to be weighed also.
What I haven't seen is a simple standard developed for engine weighing. It
could be a very simple and so long as it's followed, fairly accurate weights
could be advertised. It's interesting to watch this whole thing unfold
because instead of objective analysis what I'm seeing is people defending
their choice of engines. Perhaps an ego thing or perhaps some people don't
like to think or admit that someone else may have made a better choice than
they did.
Throwing rocks at those who use other than Rotax is counter productive to
the experimental movement because it steers people away from supporting the
grass roots movements in the experimental engines. There was a time when
the 582 was laughed at as being a "whiny snowmobile engine" and too
unreliable to use in an airplane. Bombardier (owner of Rotax) is a huge
world-wide company with unlimited resources for advertising, research,
development, etc, just as Lycoming and Continental once were. Jabiru is by
comparison a tiny company that is trying to supply a good engine alternative
to the Rotax, but it's an uphill battle because they don't have the
resources compared to Rotax. Then there are the Subarus, Corvairs, Geos,
etc. Until there is a clear and objective standard developed and enforced,
these debates are not very effective for the novice who is looking for the
best package for his airplane.
Check the links below for lots of information on alternative engines.
Again, this information is only worth the paper it's printed on.
http://home.adelphia.net/~aeroengine/Contents.html
http://www.aviationlinks.net/activelinks/engines/
http://www.aerofiles.com/motors.html
http://www.aviator.cc/engines2.html
Deke Morisse
Mikado Michigan
S5/Subaru/CAP 355+ TT
"Nothing will ever be attempted, if all possible objections must first be
overcome".- Samuel Johnson
Lynn Matteson
PostPosted: Mon Jan 14, 2008 5:25 am    Post subject: engine selection Reply with quote
Hmmmmm....don't most of these authors, once they do an article like
this, get to keep the stuff they write about? : )
Lynn
experienced. Wink
Lynn Matteson
flying w/460+ hrs
> Lynn,
> lbs typically.
> for any of us.
> Paul Seehafer
> Avid Flyer
> Lake Amphibian
www.matronics.com/Navigator?Kitfox-List _-
www.matronics.com/contribution _-
Lynn
N369LM
Lynn Matteson
PostPosted: Mon Jan 14, 2008 6:19 am    Post subject: engine selection Reply with quote
It would be a perfect exercise for the EAA to do. It would have to be
somebody with deep pockets in order to buy the engines in question,
because no supplier is going to send out an engine for free, knowing
that it is going to be weighed for a published comparison against
other engines, knowing that finally the truth will be known.
I purposely went off a "bit radical" because I've heard that most
radical thinkers usually calm down a bit later on and somewhere in
between a good idea is found.
Actually, when I began thinking about engine choices, weight didn't
enter my mind at first. The first was simplicity. I worked under the
hoods of cars for over 20 years, professionally, and longer than that
as a hobby. I saw the influx of crap added to engines, making them
harder and harder to service. Granted some of the additions were smog-
related stuff, but it all added to the complexity of the under-hood
experience. So I knew I wanted a simple engine without a lot of extra
stuff needed to make it work. I like to keep an eye on my engine, and
having it "accessible" is one way to do that.
There were a few other points that helped me make an engine decision
(Sport Pilot Nov.2007...omigod, a shameless plug!), but the LAST was
weight. I'm not one of these guys that concerns himself with saving
each and every last ounce of weight. If I want item such-and-such,
I'll get it, and figure on leaving something out of the baggage sack
when I go on a trip...although you probably wouldn't believe that if
you saw me packing the plane up at Oshkosh last summer. : )
Good call on the ego thing, Deke. There is no doubt a lot of energy
wasted on supporting one's choice, while deep down, some amount of
coveting is churning. This goes for all of us I think, be it engine
choice, airplane, automobile, etc....human nature.
Lynn Matteson
flying w/460+ hrs
On Jan 14, 2008, at 7:41 AM, fox5flyer wrote:
<fox5flyer(at)idealwifi.net>
engine weights and airplane weights means nothing because no two
setups are alike and people don't weigh things the same way, nor
are they all weighed on the same set of scales. This engine weight
debate has been a common thread here on this list for as long as I
can remember and other than a whole bunch of opinions, nothing has
been accomplished and the issue usually just fades away until
it may lead to something useful, but it takes a central and
credible overseer, possibly the EAA. As we all know, advertising
engine weights is especially critical when comparing air cooled vs
liquid cooled engines because the liquid cooled engine requires
many more components to be operable and those components need to be
weighed also.
weighing. It could be a very simple and so long as it's followed,
fairly accurate weights could be advertised. It's interesting to
watch this whole thing unfold because instead of objective analysis
what I'm seeing is people defending their choice of engines.
Perhaps an ego thing or perhaps some people don't like to think or
admit that someone else may have made a better choice than they did.
productive to the experimental movement because it steers people
away from supporting the grass roots movements in the experimental
engines. There was a time when the 582 was laughed at as being a
"whiny snowmobile engine" and too unreliable to use in an
airplane. Bombardier (owner of Rotax) is a huge world-wide company
with unlimited resources for advertising, research, development,
alternative to the Rotax, but it's an uphill battle because they
don't have the resources compared to Rotax. Then there are the
Subarus, Corvairs, Geos, etc. Until there is a clear and objective
standard developed and enforced, these debates are not very
effective for the novice who is looking for the best package for
his airplane.
engines. Again, this information is only worth the paper it's
printed on.
Deke Morisse
Mikado Michigan
first be overcome".- Samuel Johnson
Lynn
N369LM
Float Flyr
PostPosted: Mon Jan 14, 2008 12:20 pm    Post subject: engine selection Reply with quote
If it is shorter, the dinner will be Moose... the first time you get here! I’ll even provide the first round of Screech!
From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of Clint Bazzill
Sent: Saturday, January 12, 2008 10:11 PM
Subject: RE: engine selection
A dinner says your take off will be a lot shorter. Clint
My friend told me once, only fools and crooks bet. Which one am I?
Date: Sat, 12 Jan 2008 20:12:00 -0330
I don’t know whether to say thank you or not.... I expect that when I install my 912 I won’t get as short a take off as I can with the 582. I do however expect climb rate once airborne to increase. Cruise speed? Well the Kitfox, Mod III-A, a modified Mod II with the under cambered wing, isn’t designed to break any speed barriers.
Noel
Sent: Saturday, January 12, 2008 3:02 PM
The O-200 is going to come in at least 100 Lbs more then the 912ULS. The 2200 is a joke (I think) many reports out that says that the 2 stroke 582 out climbs the Jabiru 2200. You cannot drive a Kitfox with that little chunk of wood out front. Before you get involved with hundreds and hundreds of hours building. Do some research and fly with these different airplanes. My take is can't get better then a 912ULS. Ivoprop.
When you have to put a 25 lb battery in the tail to balance and sweep wings. Figure
Locate the Kitfox Pilot's Guide. Part #60000.100 Look at all the aircraft weights, specifications, add 50 lbs to all their empty weights, that works out about right. Check with these pilots and fly with them.
Clint
> From: alexandj(at)preachain.org
> To: kitfox-list(at)matronics.com
> Subject: Re: engine selection
> Date: Sat, 12 Jan 2008 09:43:42 -0800
> --> Kitfox-List message posted by: "John Alexander" <alexandj(at)preachain.org>
> I'm putting a C-85 into my when I get it. The choice is driven by the fact
> that I have a C-85 on hand - newly overhauled with the O-200 STC (crank and
> pistons) installed.
> I'll be putting a lighter starter and an alternator on it, so that will free
> up a few pounds.
> I've been curious about the Jabiru engines though. They turn up quite a bit
> faster than the O-200 or C-85 necessitating a smaller prop. How does this
> affect efficiency/performance?
> John Alexander
> Currently at sea - SBX-1
> On Sat, 12 Jan 2008 05:56:37 -0800 (PST), great bear wrote
> > --> Kitfox-List message posted by: great bear <av8r2488(at)yahoo.com>
> > I have been following the talk on engine choices...just another
> > thought to add....I have a series 5 outback and will have to make an
> > engine choice soon because of wing sweep (or lack of) and would like
> > to know your thoughts on a Jabiru 2200 vs a 0-200 cont. Heres my
> > thinking....the jabiru weighs in at 138 and the 0-200 at
> > 187....ready to go...how much of an even trade is this...50 pounds
> > for 20 hp? Now I guess we can close the weight gap by going light
> > weight starter and alternator by about 12-15 pounds..I am still
> > researching that...I like the simplicity of a direct drive air-
> > cooled engine..how much does the 912 series really weigh when you
> > factor the radiator, hoses, coolant,expansion tank...ect? Does it
> > fall somewhere in this weight range? I had a Cessna 140 for 22 years
> > and changed the 85 hp to an 0-200 and doubled the rate of climb but
> > only gained 2mph in cruise. Since excess hp power is merely the
> > ability to climb faster and cruise is a function of aerodynamics
> > will the weight savings be traded off for horse power? Also can the
> > wings be set at zero sweep and the battery moved to adjust the CG?
> > Just getting started in this as I just bought the Outback and got it
> > home a week ago....still looking it over and wondering what I have
> > gotten myself into here.....If there are any builders who would
> > rather respond off list feel free to contact me direct at
> > av8r2488(at)yahoo.com Thanks for your advice and help this is a great
> > forum.
> > Never miss a thing. Make Yahoo your home page.
> > http://www.yahoo.com/r/hs
> Beer is proof that god loves us and wants us to be happy. - Ben Frank=======================
&g==
http://www.matronics.com/Navigator?Kitfox-Listhttp://forums.matronics.comhttp://www.matronics.com/contribution arget=_blank>http://www.matronics.com/Navigator?Kitfox-Listp://forums.matronics.com
5
6
7
8
9
Noel Loveys
Kitfox III-A
Aerocet 1100 Floats
Float Flyr
PostPosted: Mon Jan 14, 2008 1:55 pm    Post subject: engine selection Reply with quote
Michel:
One other point on the cooling. With an air cooled engine, even an engine
which has only air cooled barrels the size and shape of the spinner can make
a considerable difference to your air cooling efficiency. When i was in
school I was instructed to check design manuals before sending a plane out
without a spinner. Some planes have no problems with not having a spinner
others it is considered very important not only to have a spinner but the
right shape too.
Noel Loveys
AME Intern, RPP
Kitfox III-A, 582,B box
Ivo IFA, Aerocet 1100 floats
Noel Loveys
Kitfox III-A
Aerocet 1100 Floats
Page 2 of 3
