Dave Nixon
Posted: Mon Jan 14, 2008 1:51 pm Post subject: Inspection Check-List |
I went on both the FAA site and the Zenith site for help in this area. The FAA (apparently) doesn't want you downloading Form 8000-38 because I couldn't get to it. And I thought I was good at back dooring things. Guess not. And a review of the Builder's area on the Zenith site does not yield a builder checklist for the 601 XL. What am I missing here? Dave Nixon
CH 601 and Jabiru 3300
92% Done with 85% To Go
bearup(at)ida.net Guest
planecrazydld(at)Yahoo.co Guest
Posted: Mon Jan 14, 2008 2:45 pm Post subject: Inspection Check-List |
I posted it as an attachment a couple of days ago
Dave Nixon <adnasap(at)bellsouth.net> wrote: [quote] v\:* {behavior:url (#default#vml);} v\:* { BEHAVIOR: url (#default#vml) } FLAVOR00-NONE-0000-0000-000000000000 4.0 ; I went on both the FAA site and the Zenith site for help in this area. The FAA (apparently) doesn't want you downloading Form 8000-38 because I couldn't get to it. And I thought I was good at back dooring things. Guess not. And Be a better friend, newshound, and [quote][b]
planecrazydld(at)yahoo.co Guest
Posted: Mon Jan 14, 2008 3:09 pm Post subject: Inspection Check-List |
Thanks for the posting to the original document Stan. The attachment that I made is a Word file that has exactly the same contents as the form in the PDF but is not as fuzzy (and can be filled in as a text document).
Stan Bearup <bearup(at)ida.net> wrote: [quote] v\:* { BEHAVIOR: url (#default#vml) } v\:* { BEHAVIOR: url (#default#vml) } FLAVOR00-NONE-0000-0000-000000000000 4.0 ; Click on the link below to download FAA Form 8000-38 - FABRICATION ASSEMBLY OPERATION CHECKLIST
Stan
Posted: Mon Jan 14, 2008 3:26 pm Post subject: Inspection Check-List |
Dave,
I just opened your Word doc up and found I like it much more than the pdf file version on the FAA site, and is now permanently saved on my computer. Thanks for sharing it with us.
Stan
Posted: Mon Jan 14, 2008 4:55 pm Post subject: Inspection Check-List |
I did not generate it Stan. I found it a while back and saved it for exactly the same reason!
Stan Bearup <bearup(at)ida.net> wrote:[quote] Dave,
Stan
Tim Juhl
Joined: 21 Mar 2006 Posts: 488 Location: "Thumb" of Michigan
Posted: Tue Jan 15, 2008 10:01 am Post subject: Re: Inspection Check-List |
Guys,
Would a copy of the FAA form 8000-38 that Zenith filled out to establish that the kit meets the 51% rule be something that would be good to show the DAR or FAA when getting our planes inspected for an airworthiness certificate?
Comments appreciated.
_________________ ______________
CFII
Champ L16A flying
Zodiac XL - Jabiru 3300A
Almost done! It'll fly in spring! |
bryanmmartin
Posted: Tue Jan 15, 2008 12:05 pm Post subject: Inspection Check-List |
The FAA maintains a list of kits that have been found to meet the 51%
rule, the C601XL is already on that list so you shouldn't have to bother
with this form.
See: http://tinyurl.com/2fw7wb
Tim Juhl wrote:
Guys,
Bryan Martin
Zenith 601XL N61BM
Ram Subaru, Stratus redrive
_________________ --
Bryan Martin
do not archive. |
