Lynn Matteson
Posted: Tue Jan 15, 2008 10:57 am Post subject: Battery Location |
We are all in a heap of trouble if I am! : ) No, there are FAR more
experienced than me in this group...I'm just one of the mouthy ones,
and I can't even take credit for that...they know who they are. : )
The static port has a specific location spelled out in the build
instructions. The original Kitfox kit builders did a lot of testing,
I'm told, to determine an area that was neutral to the airstream, and
thus a good location for the static port which should be
"static"...that is, "standing still, having no motion, quiescent." I
think it should be used as suggested. I also made another location,
directly across the fuse from the originally suggested location, to
avoid any discrepancies in airspeed when slipping the aircraft. I
hope yours is on the side of the fuselage, and not "on the back" as
you describe it. Maybe somebody has their builders instructions
closer than mine, and can answer this positioning question for you.
Mine's at the hangar, where I'm going pretty soon to make some marks
in the new snow. I'll look it up while there.
After I wrote the word "quiescent" I knew it was time to head for the
hangar and blow out the cobwebs...quiescent? Where in the world did
that come from? : ) ( I had to look up "static" and came upon
it...anybody that knows me knows damn well that I don't know that word.)
Lynn Matteson
flying w/460+ hrs
On Jan 15, 2008, at 12:33 PM, patrick reilly wrote:
Quote: | Lynn, Looks like you are one of the most experienced Kitfoxers on
this site. One more question on this mod 3 rebuild. There is a tube
running to the rear of the fusalage to a static port. It is a few
inches forward of the grab handle on the back of the fusalage. I
will leave it there, but is it necessary or more accurate located
back there. I think it was hooked up to the altimiter.
> From: lynnmatt(at)jps.net
> Subject: Re: Battery Location
> Date: Tue, 15 Jan 2008 09:02:56 -0500
> To: kitfox-list(at)matronics.com
> I guess this proves once and for all that the Jabiru is
lighter....my
> battery is on the firewall, engine side. (tongue firmly in cheek)
> Lynn Matteson
> Kitfox IV Speedster w/Jabiru 2200
> flying w/460+ hrs
> do not archive
> On Jan 14, 2008, at 9:05 PM, Marco Menezes wrote:
> > Based on the published info, the 912 weighs at least 25# more than
> > the 582. Thus the rearward battery placement. I have mine on the
> > firewall, cabin side. I'd say your guess is right on.
> > Pat Reilly <patreilly43(at)hotmail.com> wrote:
> > Kitfoxers, I am rebuilding a Model 3 that had a 912 engine and 2
> > (at)13 gallon wing tanks. At least I think they are 13 gals as
that is
> > the only wing tank option I am familiar with. The fuel header tank
> > is about 18 inches behind the seat back.The battery was installed
> > about 2 feet behind the seat back on the fusalage. I am installing
> > a 582 Rotax. My question is, should I move the battery to the back
> > of the firewall, where I see some other 582 engine batteryBe a
> > better friend, newshound, and_-
> > =================================== _-
> > http://www.matronics.com/Navigator?Kitfox-List_-
> > ========== _-
> > forums.matronics.com_-
> > contribution_-
============================================================ _-
contribution_-
_________________ Lynn
Kitfox IV-Jabiru 2200
N369LM |
patreilly43(at)hotmail.co Guest
Posted: Tue Jan 15, 2008 12:17 pm Post subject: Battery Location |
Lynn, THE STATIC PORT WAS ON THE SIDE OF THE FUSALAGE JUST IN FRONT OF THE GRAB HANDLE. Looks like I hit the caps lock. Did you join the 2 ports, right side and left side with a tee? Pat
[quote] From: lynnmatt(at)jps.net
Date: Tue, 15 Jan 2008 13:56:39 -0500
--> Kitfox-List message posted by: Lynn Matteson <lynnmatt(at)jps.net>
Lynn Matteson
flying w/460+ hrs
> lighter....my
> > Lynn Matteson
> > flying w/460+ hrs
> > do not archive
> that is
> > > ========== _-
> > > contribution_-
> ========== _-
> contribution_-
Float Flyr
Posted: Tue Jan 15, 2008 12:22 pm Post subject: Battery Location |
I’m in Newfoundland, Canada... As close as you can get to Europe on this continent without doing a lot of swimming. J
I’m going to hold on to the 582 until I get the 912 flying then it’s up for sale, lock stock and barrel.
What model Kitfox is your mount made to fit? That’s the big part I need now. My bolt pattern should be the same as the model II.
Noel
From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of patrick reilly
Sent: Tuesday, January 15, 2008 3:05 PM
Subject: RE: Re: Battery Location
Noel, Sorry, no, I do not have the 912 exhaust. I got this plane without the engine. I have the complete 912 engine mount and the firewall grommet door, however. What are you doing with your 582 firewall forward? Where are you located? Pat
Date: Tue, 15 Jan 2008 14:42:20 -0330
Pat
I’m going the other way installing a 912 where a 582 now lives. I’m considering moving my header tank, almost 14 lb full, behind the seat. Then putting the oil tank where the header is now, behind the instrument panel. I have to see if it will be easily removable form that location for cleaning. BTW you don’t happen to have an exhaust??
Noel
Sent: Tuesday, January 15, 2008 2:21 PM
Tom, Thanks for the advice. I have removed the battery. I am 90% sure it will have to come forward with the lighter engine. But, I will wait to reposition it with the new weight and balance. Pat Reilly
> From: nahsikhs(at)elltel.net
> Date: Mon, 14 Jan 2008 18:44:17 -0800
> --> Kitfox-List message posted by: "Tom Jones" <nahsikhs(at)elltel.net>
> > My question is, should I move the battery to the back of the firewall, where I see some other 582 engine battery installations?
> Pat, I would leave the battery where it is until the rebuild is complete enough to do a close weight and balance. Then you can move the battery forward if needed and you will be able to know how far. It will probably be easier to remove the existing cables at that time than to reinstall them if you need the CG to move back.
> Tom Jones
> Classic IV, Phase one
> 503 Rotax, 72 inch Two blade Warp
> Ellensburg, WA
> http://forums.matronics.com/viewtopic.php?p=158194#158194
> Quote: | http://www.matronics.com/Navigator?Kitfox-Listhttp://forums.matronics.comhttp://www.matronics.com/contribution arget=_blank>http://www.matronics.com/Navigator?Kitfox-Listp://forums.matronics.com | 0123456789 Quote: | http://www.matronics.com/Navigator?Kitfox-List | 0 Quote: | http://www.matronics.com/Navigator?Kitfox-List | 1 Quote: | http://www.matronics.com/Navigator?Kitfox-List | 2 Quote: | http://www.matronics.com/Navigator?Kitfox-List | 3 Quote: | http://www.matronics.com/Navigator?Kitfox-List | 4 Quote: | http://www.matronics.com/Navigator?Kitfox-List | 5 Quote: | http://www.matronics.com/Navigator?Kitfox-List | 6 Quote: | http://www.matronics.com/Navigator?Kitfox-List | 7 Quote: | http://www.matronics.com/Navigator?Kitfox-List | 8 Quote: | http://www.matronics.com/Navigator?Kitfox-List | 9 Quote: | http://forums.matronics.com | 0 Quote: | http://forums.matronics.com | 1
_________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
Fox5flyer Guest
Posted: Tue Jan 15, 2008 1:22 pm Post subject: Battery Location |
Noel, there is a 912s exhaust on Barnstomers. I just saw it a couple days ago. Search "Kitfox" and on page three you should run across it. It seems a little pricey, but I don't know what they go for.
Deke
Lynn Matteson
Posted: Tue Jan 15, 2008 1:58 pm Post subject: Battery Location |
Yes I did, Pat. That was one of the few things that my tech advisor
caught me on...I didn't have a support for the "teed" junction, and I
had to get in there from an inspection hole in the bottom of the
fuse, and install one...what a bear! The tubing is so stiff that it
would likely hold itself in place, but he insisted on it. Perhaps
vibration over time could break the tubes, what do I know?
I couldn't find the drawing of the exact placement in my manual, but
I measured my plane and the dimensions are: 5 and 1/8 inches from
the bottom of the lower longeron, and 44 inches forward from the
center of the cross tube back near the tailwheel....I think it's the
only crosstube that is near there that protrudes through the fabric.
This does place the port just in front of the lift handle, but quite
low on the side. Is that where yours is?
Lynn Matteson
flying w/460+ hrs
On Jan 15, 2008, at 3:16 PM, patrick reilly wrote:
Quote: | Lynn, THE STATIC PORT WAS ON THE SIDE OF THE FUSALAGE JUST IN FRONT
N369LM |
Float Flyr
Posted: Tue Jan 15, 2008 5:34 pm Post subject: Battery Location |
Found it but it is for a pusher configuration.
Thanks keep your eyes open for me
Noel
From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of fox5flyer
Sent: Tuesday, January 15, 2008 5:49 PM
Subject: Re: Re: Battery Location
Deke
Quote: |
----- Original Message -----
To: kitfox-list(at)matronics.com (kitfox-list(at)matronics.com)
Sent: Tuesday, January 15, 2008 1:12 PM
Pat
Noel
> Tom Jones
> Ellensburg, WA
> Quote: | http://www.matronics.com/Navigator?Kitfox-Listhttp://forums.matronics.comhttp://www.matronics.com/contribution href="http://www.matronics.com/Navigator?Kitfox-List">http://www.matronhref="http://forums.matronics.com">http://forums.matronics.comhref="http://www.matronics.com/contribution">http://www.matronics.com/c | | 0123456789 Quote: | http://www.matronics.com/Navigator?Kitfox-List | 0 Quote: | http://www.matronics.com/Navigator?Kitfox-List | 1 Quote: | http://www.matronics.com/Navigator?Kitfox-List | 2 Quote: | http://www.matronics.com/Navigator?Kitfox-List | 3 Quote: | http://www.matronics.com/Navigator?Kitfox-List | 4 Quote: | http://www.matronics.com/Navigator?Kitfox-List | 5 Quote: | http://www.matronics.com/Navigator?Kitfox-List | 6 Quote: | http://www.matronics.com/Navigator?Kitfox-List | 7 Quote: | http://www.matronics.com/Navigator?Kitfox-List | 8 Quote: | http://www.matronics.com/Navigator?Kitfox-List | 9
Kitfox III-A
Float Flyr
Lynn Matteson
Posted: Tue Jan 15, 2008 7:35 pm Post subject: Battery Location |
Huh? Are we talking about the same tube here, Noel? I was talking
about the 3/16" or 1/4" nylon tube that carries the static pressure.
In my case I had the two side static port tubes going into a tee,
and from there forward about 12" to a tie wrap around a fuselage
cross member. From there forward, the tubing was supported every 12"
or so with tie wraps done in the approved way...with standoffs. My
tech advisor wanted a bracket to support the tubes at the "tee." The
side tubes curved upwardly to the tee, thus there was some vibration
absorption going on via the curved tubing...nylon tubing. Are you
suggesting this nylon tubing is gonna foul my rudder cables or
elevator tube?
Lynn Matteson
flying w/460+ hrs
On Jan 15, 2008, at 8:35 PM, Noel Loveys wrote:
With the tube going forward it can exert a considerable stress on
the cross
tube. That in turn coulddamage your exterior finish. If the long
tube ever
broke or came free it could possibly foul your rudder cables or
elevator
tube.... Mr. Murphy is alive and well let's not tempt him
Noel
N369LM |
dave
Posted: Tue Jan 15, 2008 8:21 pm Post subject: Re: Battery Location |
You already know the right way. But I'll add that my 582/IV has the battery just behind the firewall and its CG is "too far" aft, which means I can't run 40 pounds in my baggage compartment at full gross without going aft of the rear CG limit.
Guy Buchanan |
Well, according to my manual for my Kitfox IV 1050 it states behind the seat is where battery goes with the 582 and the dash fuel tank.
Hundreds of Kitfox Movies
Most viewed Kitfox on youtube
Most popular on youtube
Highest rated on youtube |
avidfox
avidfox
avidfox
Posted: Tue Jan 15, 2008 9:42 pm Post subject: Battery Location |
Correction:
The battery installation link has been revised
Use the link below to go to the page that includes Chapter 10.
On Jan 16, 2008 12:33 AM, 84KF <avidfox(at)gmail.com (avidfox(at)gmail.com)> wrote:
[quote] That should read:
AC 43.13 1b not AC 43.13 2a
Although...., in AC 43.13-2a you will also find battery installation information
http://rgl.faa.gov/Regulatory_and_Guidance_Library/rgAdvisoryCircular.nsf/0/e533bb05389c90e486256a54006e47b2/$FILE/Chapter%209-13.pdf
Chapter 10
avidfox
Float Flyr
Posted: Wed Jan 16, 2008 6:05 am Post subject: Battery Location |
No... I was referring to the long tube you have properly supported. I can still appreciate why you friend wanted the “T” supported. That area of the inside of the fuselage could be a lower pressure area. That would make your Alt read too high and your ASI read too low. That and it’s just not right to have anything flopping around in the plane.
My set up is very primitive. It consists of a large static port just forward of the left door. There is no balancing port on the other side and to be honest I would be hard put to choose a worse location for a static port. When I run the engine up for the first few seconds the ASI,VSI and Alt go crazy. It all straightens itself out before I get up on step though. For that reason I have taken to flying with the static port open to the cabin. It’s a lot more consistent but I have noticed slight (very slight) differences in the static instruments when I open the door in flight.
Any chance the next time you are poking around in your fuse that you could take some pictures of your static installation. I have been considering installing a better installation.
Noel
Kitfox III-A
Float Flyr
Posted: Wed Jan 16, 2008 6:14 am Post subject: Battery Location |
Because every plane is different... not to mention the weights of the batteries that can be used, I still say the best thing to do is weigh the plane and calculate a W&B. Then you will know for sure where the battery should go. Weighing the plane before everything is torqued down permanently would be a good idea because the further back the battery goes the more heavy copper cable will be needed and the more complex the installation.
I like to keep battery cables short. There is less chance for getting the cable pinched or shorted. Less voltage drop and less weight.
Noel Loveys
AME Intern, RPP
Kitfox III-A, 582,B box
Ivo IFA, Aerocet 1100 floats
Kitfox III-A
Float Flyr
Posted: Wed Jan 16, 2008 6:41 am Post subject: Battery Location |
Glad to see lots of people here use AC43... It’s the basis on which good aircraft maintenance is built. I even have downloaded the whole of AC 43 to my PDA for quick reference when working on planes.
There is a word of caution though.... AC43 is the rule but there are exceptions that make the rules. Those exceptions are all well written in the aircraft manuals. In our cases we essentially write the manuals when we build the planes. There may be cases where things are done contrary to convention Fir good reason. It’s good to be aware such conditions exist.
If there was one thing in AC43 I would suggest everyone read and practice it is lock wiring (Safe tying). It is not difficult to learn to do well and nothing finishes a job off like a nice clean, even and taught job of lock wiring. Once you get good at it you will be using wire everywhere to do things you never considered before, both on the plane and around the house.
We are lucky we don’t have to contend with the paperwork the GA crowd has to contend with. A few years ago there was an essay question on the Transport Canada AME final examination on the procedure to adjust the flaps of a BPY or Catalina water bomber. The incorrect answer is: There is no flaps on a Catalina. (True but not correct) The correct answer is: The Maintenance manual for the Catalina does not describe an approved method to adjust flaps.
Noel Loveys
AME Intern, RPP
From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of 84KF
Sent: Wednesday, January 16, 2008 2:18 AM
And this link for the Static installation link...
AC 43.13 1B,
Chapter 12
SECTION 4. PITOT/STATIC SYSTEM
http://rgl.faa.gov/Regulatory_and_Guidance_Library/rgAdvisoryCircular.nsf/0/99c827db9baac81b86256b4500596c4e/$FILE/Chapter%2012-13.pdf
Hey. it's late. Forgive me.
I'm trying not to mention anything regarding LSA issues.
(Opps.., I did it again!!)
Steve Benesh
Quote: | http://www.matronics.com/Navigator?Kitfox-List | 0123456789
Kitfox III-A
avidfox
Posted: Wed Jan 16, 2008 7:28 am Post subject: Battery Location |
Quote: | "AC43 is the rule but there are exceptions that make the rules. Those exceptions are all well written in the aircraft manuals."
Exactly right.
A certificated aircraft's manual contains "Approved Data",
AC 43.13-1b, 2a contains "Acceptable Data", often used and referenced when seeking approval from the FAA for repairs and modifications to certificated aircraft when specific "Approved Data" is unavailable.
All of it can, and should, be applied to Experimental Amateur-Built when in doubt.
Steve Benesh
A&P, IA
5-912UL
Lynn Matteson
Posted: Wed Jan 16, 2008 10:07 am Post subject: Battery Location |
I'll try to attach the pics that I had in my files, but even though I
reduce then as Matronics asks, I always get a "rejection
letter"...and then they show up anyway. If they don't show up, I'll
send the three pics to you, Noel.
On Jan 16, 2008, at 9:02 AM, Noel Loveys wrote:
Quote: | Any chance the next time you are poking around in your fuse that
This is before I had installed the right-hand side tubing.
This is up through the inspection hole opening, with temporary stick
holding support in place while adhesive hardens. It's hard to not
make a mess with the adhesive when you're working through the hole.
Another shot of temporary stick. I had to install this support brace
with one hand through insp. hole. The support has many holes drilled
through it to allow the adhesive to ooze through and form a "rivet"
of sorts. It also jams between the fuse tubing and the antenna plate,
so there is mechanical, as well as adhesive attachment. Getting a
machine screw into the (eventual) adel clamp was a joy, too!
Description: |
Filesize: |
130.44 KB |
Viewed: |
394 Time(s) |
Description: |
Filesize: |
97.3 KB |
Viewed: |
506 Time(s) |
Description: |
Filesize: |
106.44 KB |
Viewed: |
438 Time(s) |
N369LM |
Posted: Wed Jan 16, 2008 10:11 am Post subject: Battery Location |
Noel, My 912 engine mount came off of a model 3. I don't know if it will fit your plane. I'm sure someone out there knows. I also have the grommet door that goes in the middle of the firewall. Shipping to Newfoundland must be expensive from almost anywhere. Pat Reilly
[quote] From: noelloveys(at)yahoo.ca
Date: Tue, 15 Jan 2008 16:51:50 -0330
.ExternalClass .EC_shape {;} .ExternalClass EC_p.MsoNormal, .ExternalClass EC_li.MsoNormal, .ExternalClass EC_div.MsoNormal {margin-bottom:.0001pt;font-size:12.0pt;font-family:'Times New Roman','serif';} .ExternalClass a:link, .ExternalClass EC_span.MsoHyperlink {color:blue;text-decoration:underline;} .ExternalClass a:visited, .ExternalClass EC_span.MsoHyperlinkFollowed {color:purple;text-decoration:underline;} .ExternalClass p {margin-right:0in;margin-left:0in;font-size:12.0pt;font-family:'Times New Roman','serif';} .ExternalClass pre {margin-bottom:.0001pt;font-size:10.0pt;font-family:'Courier New';} .ExternalClass EC_span.HTMLPreformattedChar {font-family:Consolas;} .ExternalClass EC_p.ecmsochpdefault, .ExternalClass EC_li.ecmsochpdefault, .ExternalClass EC_div.ecmsochpdefault {margin-right:0in;margin-left:0in;font-size:12.0pt;font-family:'Times New Roman','serif';} .ExternalClass EC_p.ecmsochpdefault1, .ExternalClass EC_li.ecmsochpdefault1, .ExternalClass EC_div.ecmsochpdefault1 {margin-right:0in;margin-left:0in;font-size:10.0pt;font-family:'Times New Roman','serif';} .ExternalClass EC_span.EmailStyle22 {font-family:'Times New Roman','serif';color:windowtext;font-weight:normal;font-style:normal;} .ExternalClass .EC_MsoChpDefault {font-size:10.0pt;} (at)page Section1 {size:8.5in 11.0in;} .ExternalClass EC_div.Section1 {page:Section1;}
Noel
Subject: RE: Kitfox-List: Re: Battery Location
Pat
Noel
Tom Jones
Ellensburg, WA
Fox5flyer Guest
Posted: Wed Jan 16, 2008 5:09 pm Post subject: Battery Location |
They came through here just fine Lynn.
Dekester
