Michel
Posted: Wed Jan 16, 2008 6:34 am Post subject: Static port WAS: Battery Location |
On Jan 16, 2008, at 3:02 PM, Noel Loveys wrote:
| Quote: | That area of the inside of the fuselage could be a lower pressure
area. That would make your Alt read too high and your ASI read too
low.
If there is a greater pressure difference between the pitot tube and
the static port, wouldn't that make the ASI read too high, Noel?
Cheers,
Michel Verheughe
Norway
Kitfox 3 - Jabiru 2200
Float Flyr
Posted: Wed Jan 16, 2008 1:22 pm Post subject: Static port WAS: Battery Location |
Yes... if there is a greater pressure difference. Pitot pressure is positive and a positive pressure on the static port will display a lower airspeed. A lower pressure on the static port will make the ASI read too high ( not good ) and the Altimeter read too high, also not too good. I may have got my jords wumbled.
BTW. For the benefit of others reading this I was reading a passage( just like the bible ) in AC 43 today that reminded me to never allow negative pressure differential in the pitot line of an ASI ( Negative speed )
When I was in school, the only thing we would hook up to a pitot static system was a Barfield tester or a bottle of nitrogen used to clean out and dry the lines when they were disconnected from the instruments.
Noel
_________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
avidfox
Posted: Wed Jan 16, 2008 2:15 pm Post subject: Static port WAS: Battery Location |
What I haven't seen so far is any mention of static drains or alternate static source for use in case moisture collects, and\or freezes in the line itself.
Just thinking out loud here..
btw...except for the alt encoder being plumbed into the altimeter, all my instruments static openings are just open, to cabin pressure. No big deal, no major errors.
Steve
84KF
patreilly43(at)hotmail.co Guest
Posted: Wed Jan 16, 2008 2:58 pm Post subject: Static port WAS: Battery Location |
Steve, I have wondered all along why in an unpressurized cabin why you need a static port to the outside? Especially in our type of planes that can't be and are never sealed worth a damn. Pat Reilly
[quote] Date: Wed, 16 Jan 2008 17:12:19 -0500
Subject: Re: Static port WAS: Battery Location
Steve
84KF
arget=_blank>http://www.matronics.com/Navigator?Kitfox-List
p://forums.matronics.com
| [b]
avidfox
Posted: Wed Jan 16, 2008 3:22 pm Post subject: Static port WAS: Battery Location |
Patrick,
The instruments on my PA-15 vagabond were open (no static lines, ports, etc.) and it worked fine for what it was. The downside was, when I opened the sliding side window, a slightly lower pressure was created in the cabin due to the air rushing by, causing a very slight change in indicated airspeed, maybe 3-5 mph. I would also get a slight VSI indication change (just a burp) Altimeter change,i f any, was so slight it's not worth mentioning.
If one want to get anal about these things then it matteres, but the changes were so slight that it was a non-issue.
Steve
84KF
akflyer
Posted: Wed Jan 16, 2008 3:23 pm Post subject: Re: Static port WAS: Battery Location |
Speak for your own plane... next time I am dumb enough to try and fly at -25, I am gonna have the ole lady bust out the duct tape once I get in.. I'll make sure that bugger is sealed up tighter than a frogs.... ahh orifice.
remember, if they cant find you attractive, they should at least find you handy.
Seriously though, the instruments on my brothers KF are just running off cabin static and GPS shows the VSI and airspeed to be darn near dead on.
_________________ DO NOT ARCHIVE
Leonard Perry aka SNAKE
Soldotna AK
Avid "C" / Mk IV
IVO IFA
Full Lotus 1450
I would rather die trying to live, than to live trying not to die.... |
dave
Posted: Wed Jan 16, 2008 3:58 pm Post subject: Re: Static port WAS: Battery Location |
I have a feeling the Dan Denney used to get some chinese ASI s ?
Mine read pretty good up to around 60to 70 then it outpaces it 's self
at 92 mph cruise in gps my ASI will show about 105 to 110 mph .
many times my ASI goes past the 120 or 125 red zone and around to about 20 or 30 mph. and below 50 mph it reads low
but really does it matter? Works well lower and I know where it stalls.
Hundreds of Kitfox Movies
Most viewed Kitfox on youtube
Most popular on youtube
Highest rated on youtube |
avidfox
Posted: Wed Jan 16, 2008 4:08 pm Post subject: Static port WAS: Battery Location |
"....next time I am dumb enough to try and fly at -25, I am gonna have the ole lady bust out the duct tape once I get in.. I'll make sure that bugger is sealed up tighter than a frogs"
Leni,
You'll have to send me the part # of your duct tape,
Mine tends become brittle and fall apart below +20F
Steve
akflyer
Posted: Wed Jan 16, 2008 4:13 pm Post subject: Re: Static port WAS: Battery Location |
nashau duct tape. IT is the only tape to buy. It is the only tape we have found that holds up to the harsh north slope weather and will stick when cold!.. the bad part is if you want to get out, you will have to be cut out of the plane cause you are not gonna bust it loose just by pushing on the door. ( I was only half kidding about having the wife tape me in lol.. )
Soldotna AK
Avid "C" / Mk IV
IVO IFA
Full Lotus 1450
Lynn Matteson
Posted: Wed Jan 16, 2008 4:32 pm Post subject: Static port WAS: Battery Location |
I listened to both arguments, and opted for the "finished" look of a
system where all the ports on the instruments were actually connected
to lines, looking like they did something. Call me anal, I guess. If
I was a weight freak, maybe I'da left 'em off.
The argument that sold it for me was opening a vent and having a
gauge go nuts...not very professional.
Lynn Matteson
flying w/460+ hrs
On Jan 16, 2008, at 6:23 PM, akflyer wrote:
find you handy.
darn near dead on.
DO NOT ARCHIVE
Leonard Perry
Soldotna AK
Avid "C" / Mk IV
582 IVO IFA
Full Lotus 1260
95% complete
http://forums.matronics.com/viewtopic.php?p=158651#158651
_________________ Lynn
Kitfox IV-Jabiru 2200
N369LM |
Lynn Matteson
Posted: Wed Jan 16, 2008 4:33 pm Post subject: Static port WAS: Battery Location |
Ever try Gorilla Duct Tape? That stuff is tenacious. It's hard to
even get it off the roll. I've used Performance Automotive's "racer's
tape" available in colors. I don't know the actual name of the tape.
Lynn Matteson
flying w/460+ hrs
On Jan 16, 2008, at 7:13 PM, akflyer wrote:
DO NOT ARCHIVE
Leonard Perry
Soldotna AK
Avid "C" / Mk IV
582 IVO IFA
Full Lotus 1260
95% complete
http://forums.matronics.com/viewtopic.php?p=158663#158663
N369LM |
akflyer
Posted: Wed Jan 16, 2008 5:08 pm Post subject: Re: Static port WAS: Battery Location |
the gorilla pales in comparison (at least the 2 rolls I tried). I have used the Nashua for float repairs, boat repairs etc. and it has yet to let me down.
And to keep this on topic, you could use a small piece of the tape, and cover the static ports for an experiment. The tape should be good for 150 mph.
Soldotna AK
Avid "C" / Mk IV
IVO IFA
Full Lotus 1450
Float Flyr
Posted: Wed Jan 16, 2008 5:43 pm Post subject: Static port WAS: Battery Location |
Until you open the door... then the effect is minimal but noticible.
Noel
From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of 84KF
Sent: Wednesday, January 16, 2008 6:42 PM
Steve
84KF
| Quote: | | http://www.matronics.com/Navigator?Kitfox-List | 0123456789
Kitfox III-A
Float Flyr
Posted: Wed Jan 16, 2008 6:15 pm Post subject: Static port WAS: Battery Location |
Use speed tape... it’s a super sticky aluminium foil. Great to have in the box for quick repairs of perforated wings etc. Only problem is getting the stuff off!
Noel
Sent: Wednesday, January 16, 2008 8:34 PM
Subject: Re: Re: Static port WAS: Battery Location
Leni,
Steve
Kitfox III-A
Guy Buchanan
Posted: Wed Jan 16, 2008 8:54 pm Post subject: Static port WAS: Battery Location |
At 02:12 PM 1/16/2008, you wrote:
| Quote: | What I haven't seen so far is any mention of static drains or
I did a pitot drain because of the dramatic height change. It's just
a loop with a stub at the bottom. Unfortunately I didn't make it very
easy to service. Too impatient. I didn't drain the static because it
is pretty much up-hill from the source to the instrument.
Guy Buchanan
San Diego, CA
Deceased K-IV 1200
A glider pilot too. |
shinco(at)bright.net Guest
Posted: Wed Jan 16, 2008 9:04 pm Post subject: Static port WAS: Battery Location |
akflyer wrote:
DO NOT ARCHIVE
Leonard Perry
Soldotna AK
Avid "C" / Mk IV
582 IVO IFA
Full Lotus 1260
95% complete
http://forums.matronics.com/viewtopic.php?p=158669#158669
Duck tape was invented in WW2,to field repair aircraft so they could be
put back into.service as soon as they could.so I guess if Duck tape was
good on fighter aircraft 300mph.it is good on a Kitfox to.WOW a kitfox
covered with all Duck Tape..it would make thing alot cheaper and
easer..Steve Shinabery 554KF KF2 little 582
