peteohms
Posted: Wed Jan 16, 2008 6:36 pm Post subject: Kitfox XL |
I have a brochure for a Kitfox XL kit which states it has a gross weight of 950. I thought the XL was a IV. It also claims it flys with a Rotax 503. Is it the same width as a IV?
Pete
<![endif]--> <![endif]--> [quote][b]
_________________ Pete
Leander, TX
Kitfox III, 912ul, Grove |
Tom Jones
Joined: 12 Mar 2006 Posts: 752 Location: Ellensburg, WA
Posted: Thu Jan 17, 2008 8:10 am Post subject: Re: Kitfox XL |
| Quote: | | I have a brochure for a Kitfox XL kit which states it has a gross weight of 950. I thought the XL was a IV. It also claims it flys with a Rotax 503. Is it the same width as a IV? |
Pete, all the old literature I have indicates the XL and Classic 4 airframe are the same.
_________________ Tom Jones
Classic IV
Ellensburg, WA |
Donroutledge(at)aol.com Guest
Posted: Thu Jan 17, 2008 11:16 am Post subject: Kitfox XL |
Could someone explain how to tell the difference between a Kitfox IV 1050 and a IV 1200? Thanks, Don
In a message dated 1/17/2008 10:14:21 A.M. Central Standard Time, nahsikhs(at)elltel.net writes:
| Quote: | --> Kitfox-List message posted by: "Tom Jones" <nahsikhs(at)elltel.net>
| Quote: | I have a brochure for a Kitfox XL kit which states it has a gross weight of 950. I thought the XL was a IV. It also claims it flys with a Rotax 503. Is it the same width as a IV?
Tom Jones
Classic IV, Phase one
Ellensburg, WA
http://forums.matronics.com/viewtopic.php?p=158794#158794
Start the year off right. Easy ways to stay in shape in the new year.
jhakes(at)emily.net Guest
Posted: Thu Jan 17, 2008 12:20 pm Post subject: Kitfox XL |
The Kitfox IV was a Kitfox III with the new wing and was rated at 1050 as was the Kitfox III. In about 1993 they changed to 1200 by beefing up the carry thru parts of the fuselage and stronger struts. The also heightened the rudder. In making my 1050 I did make changes and had it signed off at 1200.
Tom Jones
Posted: Thu Jan 17, 2008 1:14 pm Post subject: Re: Kitfox XL |
| Quote: | | Could someone explain how to tell the difference between a Kitfox IV 1050 and a IV 1200? Thanks, Don |
Don, besides the taller fin and rudder, the wing struts and tube landing gear main tubes are one inch OD on the 1200. On the 1050 those are smaller diameter tubes. There are some tubes in the fuselage that are larger on the 1200 also.
FWIW, the 1050 max gross weight on the Classic 4 with a 503 is a power limitation, not an airframe limitation.
Classic IV
Ellensburg, WA |
7suds(at)Chartermi.net Guest
Posted: Thu Jan 17, 2008 3:15 pm Post subject: Kitfox XL |
All,
I built an XL in 1996, they are a lighter version of the model IV. It was sold as a package with the 503 DCDI, width was same as a IV, Gross was 950.
Lloyd Cudnohufsky
Rebuilding Model V-912
Upper Mi.
l.morris(at)tx.rr.com Guest
Posted: Fri Jan 18, 2008 7:41 am Post subject: Kitfox XL |
Tom, I think you're getting your models mixed up, I have a Classic 4 and it has a max gross weight of 1200 lbs. ---- Leon Morris/Classic 4 (94)/Flower Mound,TX
---- Tom Jones <nahsikhs(at)elltel.net> wrote:
The Classic 4 is limited to 1050 max gross as a power limitation, not an airframe limitation.
Tom Jones
Ellensburg, WA
http://forums.matronics.com/viewtopic.php?p=158856#158856
Tom Jones
Posted: Fri Jan 18, 2008 8:09 am Post subject: Re: Kitfox XL |
| Quote: | | Tom, I think you're getting your models mixed up, I have a Classic 4 and it has a max gross weight of 1200 lbs. |
I edited my first message to say the "Classic 4 with a 503 engine is limited to 1050 as a power limitation...." The edits must not go to those using the email version of the List. Bear with me, I'm still struggling learning to use this forum.
Classic IV
Ellensburg, WA |
