Float Flyr
Posted: Wed Jan 16, 2008 5:33 pm Post subject: Battery Location |
My plane registered as a model III-A is buy the serial numbers a model II which the builder told me he had upgraded to a the same specs as a model III. I think in order for your mount to fit it would have to come off a model II.
Noel
From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of patrick reilly
Sent: Wednesday, January 16, 2008 2:36 PM
Subject: RE: Re: Battery Location
Noel, My 912 engine mount came off of a model 3. I don't know if it will fit your plane. I'm sure someone out there knows. I also have the grommet door that goes in the middle of the firewall. Shipping to Newfoundland must be expensive from almost anywhere. Pat Reilly
Date: Tue, 15 Jan 2008 16:51:50 -0330
I’m in Newfoundland, Canada... As close as you can get to Europe on this continent without doing a lot of swimming. J
I’m going to hold on to the 582 until I get the 912 flying then it’s up for sale, lock stock and barrel.
What model Kitfox is your mount made to fit? That’s the big part I need now. My bolt pattern should be the same as the model II.
Noel
Sent: Tuesday, January 15, 2008 3:05 PM
Noel, Sorry, no, I do not have the 912 exhaust. I got this plane without the engine. I have the complete 912 engine mount and the firewall grommet door, however. What are you doing with your 582 firewall forward? Where are you located? Pat
Date: Tue, 15 Jan 2008 14:42:20 -0330
Pat
I’m going the other way installing a 912 where a 582 now lives. I’m considering moving my header tank, almost 14 lb full, behind the seat. Then putting the oil tank where the header is now, behind the instrument panel. I have to see if it will be easily removable form that location for cleaning. BTW you don’t happen to have an exhaust??
Noel
Sent: Tuesday, January 15, 2008 2:21 PM
Tom, Thanks for the advice. I have removed the battery. I am 90% sure it will have to come forward with the lighter engine. But, I will wait to reposition it with the new weight and balance. Pat Reilly
> Subject: Re: Battery Location
> From: nahsikhs(at)elltel.net
> Date: Mon, 14 Jan 2008 18:44:17 -0800
> To: kitfox-list(at)matronics.com
> --> Kitfox-List message posted by: "Tom Jones" <nahsikhs(at)elltel.net>
> > My question is, should I move the battery to the back of the firewall, where I see some other 582 engine battery installations?
> Pat, I would leave the battery where it is until the rebuild is complete enough to do a close weight and balance. Then you can move the battery forward if needed and you will be able to know how far. It will probably be easier to remove the existing cables at that time than to reinstall them if you need the CG to move back.
> Tom Jones
> Classic IV, Phase one
> 503 Rotax, 72 inch Two blade Warp
> Ellensburg, WA
> http://forums.matronics.com/viewtopic.php?p=158194#158194
> | Quote: | | http://www.matronics.com/Navigator?Kitfox-Listhttp://forums.matronics.comhttp://www.matronics.com/contribution arget=_blank>http://www.matronics.com/Navigator?Kitfox-Listp://forums.matronics.com | 01234567
89 | Quote: | | http://www.matronics.com/Navigator?Kitfox-List | 0 | Quote: | | http://www.matronics.com/Navigator?Kitfox-List | 1 | Quote: | | http://www.matronics.com/Navigator?Kitfox-List | 2 | Quote: | | http://www.matronics.com/Navigator?Kitfox-List | 3 | Quote: | | http://www.matronics.com/Navigator?Kitfox-List | 4 | Quote: | | http://www.matronics.com/Navigator?Kitfox-List | 5 | Quote: | | http://www.matronics.com/Navigator?Kitfox-List | 6 | Quote: | | http://www.matronics.com/Navigator?Kitfox-List | 7 | Quote: | | http://www.matronics.com/Navigator?Kitfox-List | 8 | Quote: | | http://www.matronics.com/Navigator?Kitfox-List | 9 | Quote: | | http://forums.matronics.com | 0 | Quote: | | http://forums.matronics.com | 1 | Quote: | | http://forums.matronics.com | 2 | Quote: | | http://forums.matronics.com | 3 | Quote: | | http://forums.matronics.com | 4 | Quote: | | http://forums.matronics.com | 5 | Quote: | | http://forums.matronics.com | 6 | Quote: | | http://forums.matronics.com | 7 | Quote: | | http://forums.matronics.com | 8 | Quote: | | http://forums.matronics.com | 9 | Quote: | | http://www.matronics.com/contribution | 0 | Quote: | | http://www.matronics.com/contribution | 1 | Quote: | | http://www.matronics.com/contribution | 2 | Quote: | | http://www.matronics.com/contribution | 3
_________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
Lynn Matteson
Posted: Thu Jan 17, 2008 6:24 am Post subject: Battery Location |
Yeah, same here...strange, no "rejection" this time. Before, like I
said, I'd get a "form letter" email saying I had to name the files,
or they were too big, or something, and "poof", 5 minutes later, they
came through. Now maybe I have the procedure down to a science...that
could be scary!
Regarding the pictures, however...not my finest hour...nor was my
work on that support, but it got the job done, and is still holding
the fort so to speak.
Lynn
On Jan 16, 2008, at 8:06 PM, fox5flyer wrote:
<fox5flyer(at)idealwifi.net>
They came through here just fine Lynn.
Dekester
_________________ Lynn
Kitfox IV-Jabiru 2200
N369LM |
mclayton(at)rochester.rr. Guest
Posted: Thu Jan 17, 2008 6:57 am Post subject: Battery Location |
I am in the process of rebuilding a Model II that was damaged in an accident by the previous owner. In the process, all the fabric has been stripped off, and I have welded a height extension of eight inches onto the rudder and vertical fin. Also, I have installed an electric trim tab on the elevator. In rebuilding the wing, I need to replace at least the leading edge spars, and John and Debra have informed me that the replacements will be made of a heavier gauge tubing, as they will be the current design, and stronger than the originals. I am wondering what else I might have to do to bring the aircraft up to the specs of the Model III, as far as strength goes. Does anyone have any ideas?
Mike
mclayton(at)rochester.rr.com (mclayton(at)rochester.rr.com)
Mobile: 585-737-5506
Home: 585-352-1763
8 Adams Trail
Spencerport, NY 14559
N16AF (KF II Rebuild in Progress)
On Jan 16, 2008, at 8:29 PM, Noel Loveys wrote:
| Quote: | My plane registered as a model III-A is buy the serial numbers a model II which the builder told me he had upgraded to a the same specs as a model III. I think in order for your mount to fit it would have to come off a model II.
Noel
From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com (owner-kitfox-list-server(at)matronics.com)] On Behalf Of patrick reilly
To: kitfox-list(at)matronics.com (kitfox-list(at)matronics.com)
From: noelloveys(at)yahoo.ca (noelloveys(at)yahoo.ca)
Noel
Pat
Noel
| Quote: | Subject: Re: Battery Location
From: nahsikhs(at)elltel.net (nahsikhs(at)elltel.net)
--> Kitfox-List message posted by: "Tom Jones" <nahsikhs(at)elltel.net (nahsikhs(at)elltel.net)>
Tom Jones
Ellensburg, WA
| Quote: | =================
01234567
89012345678901234567890123
4 |
Guy Buchanan
Posted: Thu Jan 17, 2008 10:50 am Post subject: Battery Location |
At 06:54 AM 1/17/2008, you wrote:
| Quote: | In the process, all the fabric has been stripped off, and I have
The vertical stabilizer root bending moment is proportional
to the distance from the root times the area. You have added
substantially to that bending moment. Do you know the root structure
to be adequate? Have you verified that the structure you added to is
the same as that on the later models with the longer fin? (Don't take
offense, just trying to keep you alive. The Kitfox is short coupled
and VS/rudders can see very high loads.)
| Quote: | In rebuilding the wing, I need to replace at least the leading edge
They will also be stiffer so that when the wing flexes it
will twist. (They do flex a bit.) Since it will wash-in I doubt it's
a problem, but it will behave a little different than a wing with two
similar stiffness spars.
Guy Buchanan
San Diego, CA
Deceased K-IV 1200
A glider pilot too. |
GONER752(at)aol.com Guest
Posted: Thu Jan 17, 2008 2:14 pm Post subject: Battery Location |
Mike,
I happened across this on the list quite awhile back. Probably not something I'll be attempting, but I hung on to it because, well, I'm a pack rat and I guess that carries over to the computer. Never throw anything away, you might need it. Anyway, I hope I get this right and it comes through.
Cheers,
Greg G
Macedon, N.Y.
23NK
n375KL
Mod 2
582
Start the year off right. Easy ways to stay in shape in the new year.
dave
Posted: Thu Jan 17, 2008 3:04 pm Post subject: Re: Battery Location |
| Quote: | ?I am wondering what else I might have to do to bring the aircraft up to the specs of the Model III, as far as strength goes. ? Does anyone have any ideas?
There is a mod from the UK i think for something to strengthen the model2 I think. Email me if you want a copy. Noel has one already.
Also If i was rebuilding a 2 I would ask McBean about the leading edges that are used on later models if that would be ok to use to pick up a few mph but you have a under cambered wing so I am not sure.
While you talking to him ask him about a retrofit kit that would give you aileron differential which the model 1 to 3 never had. You might even get more usable flap but I not not 100% sure. Another note too would be adding extra riblets on the top of wing and possibly the bottom although with the under cambered it might not do much.
I think the wing struts are larger and heavier on the 3 than the 2 as well.
Hundreds of Kitfox Movies
Most viewed Kitfox on youtube
Most popular on youtube
Highest rated on youtube |
Float Flyr
Posted: Fri Jan 18, 2008 10:52 am Post subject: Battery Location |
There is an increase in the size of the wing strut carry through and a couple of extra pieces of tube in the area behind the seat I also think there is a difference in the insert in the spar... John Mc Bean should be able to help you with all that type of thing.
Noel
From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of Mike
Sent: Thursday, January 17, 2008 11:25 AM
Subject: Re: Re: Battery Location
Mike
Home: 585-352-1763
8 Adams Trail
Noel
Subject: RE: Kitfox-List: Re: Battery Location
Noel
Pat
Noel
> Tom Jones
> Ellensburg, WA
01234567
890123456789
| Quote: | | http://forums.matronics.com | 4 | Quote: | | http://forums.matronics.com | 5 | Quote: | | http://forums.matronics.com | 6 | Quote: | | http://forums.matronics.com | 7 | Quote: | | http://forums.matronics.com | 8 | Quote: | | http://forums.matronics.com | 9 | Quote: | | http://www.matronics.com/contribution | 0 | Quote: | | http://www.matronics.com/contribution | 1 | Quote: | | http://www.matronics.com/contribution | 2 | Quote: | | http://www.matronics.com/contribution | 3 | Quote: | | http://www.matronics.com/contribution | 4 | Quote: | | http://www.matronics.com/contribution | 5 | Quote: | | http://www.matronics.com/contribution | 6 | Quote: | | http://www.matronics.com/contribution | 7 | Quote: | | http://www.matronics.com/contribution | 8 | Quote: | | http://www.matronics.com/contribution | 90123
Kitfox III-A
