Mike Whisky
Posted: Fri Jan 18, 2008 8:40 am Post subject: CH Sticks and panel interference |
Group,
is there anyone who is using CH Sticks and has the problem that the stick colliding with the panel at full forward?
Michael
_________________ RV-10 builder (flying)
#511 |
Deems Davis
Posted: Fri Jan 18, 2008 10:09 am Post subject: CH Sticks and panel interference |
Michael, I had the problem, and 'solved' it by cutting the grip portion
of the stick away from the curved portion, and then rotating it back
(towards the pilot) aprox 20 degrees and then haveing it rewelded.
http://deemsrv10.com/album/Sec%2043.5%20Misc%20Interior%20work/slides/DSC03066.html
There are a series of 5 pics in the above link
Deems Davis # 406
'Its all done....Its just not put together'
Michael Wellenzohn wrote:
Mike Whisky
Posted: Fri Jan 18, 2008 11:31 am Post subject: Re: CH Sticks and panel interference |
Thanks Deems,
Michael
#511 |
poneill(at)irealms.com Guest
Posted: Fri Jan 18, 2008 1:14 pm Post subject: CH Sticks and panel interference |
Michael,
Out of curiosity, are you using the stock van's panel or one of the
aftermarket panels?
Best Regards,
Patrick #40715 / N690CT
Mike Whisky
Posted: Fri Jan 18, 2008 1:50 pm Post subject: Re: CH Sticks and panel interference |
Patrick,
yes I do, the strange thing is that the stick only interferes on the pilot side ( about 1 inch) but not on the co-pilot side. I got to check again if I installed everything correctly.
I am not sure if I might be able to adjust the max full forward travel by adjusting the rod end bearings on the push rods.
Michael
#511 |
rene(at)felker.com Guest
Posted: Fri Jan 18, 2008 2:17 pm Post subject: CH Sticks and panel interference |
I have an alternate panel and had the same problem. I used the same
procedure that Scott Schmidt has on his site. (cut the stick, added about an
inch and canted it downward a little. Also, my pilot side contacted the
panel more than the co-pilot side.
Rene' Felker
N423CF
40322
801-721-6080
dav1111(at)erfwireless.ne Guest
Posted: Sat Jan 19, 2008 4:19 am Post subject: CH Sticks and panel interference |
Mine do, so I made them angle towards the center of the panel (about 35 degrees). This helped a lot and they barely reach the panel now. I also like having the grips at an angle as they fit the normal angle of my wrist. One of my many RV buddies, Bob Kaufman flies right seat and he didn't complain about the angle of the stick grip while he was putting 5-7 hours on my -10.
I also use an ergonomic angled keyboard for the same reason and when I go to my laptop keyboard it feels weird.
Russ Daves
N710RV - 185+ hours
RV-7 QB in progress
