Posted: Sat Jan 19, 2008 4:46 am Post subject: rivet hardening |
HI guys and gals-
This is not absolutely purely RV related, so purists please delete now!
I was talking to a friend a while back about riveting. He is building one
of Monett's products, which is built almost exclusively with pulled rivets.
The only solid rivets are the big ones in the spar center section. What my
friend learned at a Monett factory seminar is to put the factory head in a
rivet set on an anvil and smack the shop end with a hammer. I believe they
were to use some sort of a striking bar or block to transfer the blow, but
I don't recall that detail perfectly at this point. Anyway, what my friend
was told at this seminar is that one of the various reasons for doing this
is that this technique will properly set the rivet in fewer blows than
using a rivet gun, and that this in turn would lessen the work hardening of
the rivet.
This is not an intuitive conclusion for me, and I was wondering what the
metallurgists / professional metal workers / other smart folks out there
think?
As a morsel for those purists who haven't already deleted, if this is a
valid point, perhaps we could make ever so slightly tougher structures by
using higher gun pressures while riveting.
Thoughts?
BTW, I ZnCrO3 most things, glued my canopy, have a constant speed, IFR
panel, and the little wheel is in the back...
glen matejcek
aerobubba(at)earthlink.net
rgf(at)dcn.davis.ca.us Guest
Posted: Sat Jan 19, 2008 7:52 am Post subject: rivet hardening |
I'm not a metallurgist. But as an engineer I'm guessing that the technique
described will increase a rivet's strength by just a very few percent. It
strikes me as something that a perfectionist would want, but an engineer
would disdain as not being worth the trouble, given the highly redundant
strength of our multiple rivets already. Obviously lots of planes have and
are flown built with rivet guns so I'm sticking with that. And I would not
start experimenting with different rivet gun pressures and so forth! Do
your experiments on something harmless unless you have formal education and
plenty of experience in the area.
d-burton(at)comcast.net Guest
Posted: Sat Jan 19, 2008 8:00 am Post subject: rivet hardening |
Hi Glen,
This is a real issue. We don't see it much with 99% of our little rivets
but driving the big ones in the spars is where we would. I drove my spar
rivets with a small sledge hammer using my C-frame. It worked great but I
had to really smack the rivet hard to have the least number of hits. They
definitely got harder to drive each time you hit them. I don't think that
it's a strength issue with work hardening but cracking and failure to flow
to fill the hole and form a good shop head.
DavdB
khorton01(at)rogers.com Guest
Posted: Sat Jan 19, 2008 2:47 pm Post subject: rivet hardening |
On 19-Jan-08, at 10:54 , David Burton wrote:
I drove my spar
but I
hits. They
The "getting harder to drive each time you hit them" isn't only due to
work hardening. The diameter of the shop head increases as you drive
the rivet, so it takes a harder and harder force to cause the metal to
move as you progress.
Given that there are over 5000 RVs flying that were built with the
traditional rivet gun method, and they aren't falling out of the sky,
I wouldn't worry about this, unless you are driving the big rivets on
a main wing spar. Those rivets either need a big rivet run, or a
hammer. The 3X or 2X gun used on the rest of the project won't cut
it, and most folks aren't prepared to purchase another rivet gun for
just that task. So out comes the hammer.
Kevin Horton RV-8 (final assemby)
Ottawa, Canada
http://www.kilohotel.com/rv8
Posted: Sun Jan 20, 2008 6:49 am Post subject: rivet hardening |
HI Ralph-
Re: But as an engineer I'm guessing that the technique
| Quote: | described will increase a rivet's strength by just a very few percent. It
and
| Quote: | are flown built with rivet guns so I'm sticking with that. And I would
not
| Quote: | start experimenting with different rivet gun pressures and so forth! Do
and
| Quote: | plenty of experience in the area.
I think perhaps you might have misunderstood my comments and question. I
wouldn't suggest folks start building RV's with hammers, and I have no
concerns about the strength of the 5K+ RV's out there. It's an issue of
gaining / verifying a bit of knowledge and exploring it's application.
Upping the gun air pressure somewhat isn't all that big a deal. Forgetting
you have full line pressure on tap after a drilling operation and then
trying to shoot a rivet can have less than pleasing results, er, or so I've
been told
Personally, I've come to prefer using higher pressures than Van's
recommends. As far as the part about formal education and experience
goes... well... if there were a riveting contest held between an average
A&P and an average homebuilder, I know where I'd put my money!
Hi Dave!
| Quote: | This is a real issue. We don't see it much with 99% of our little rivets
Interesting. In the conversation I had on the topic, it was presented as
relevant to all rivets. Perhaps the intent was that it was preferable to
use a hammer on rivets that would be a challenge for the average
homebuilder's rivet gun. Thanks for the clarification.
HI Kevin-
| Quote: | Given that there are over 5000 RVs flying that were built with the
Makes sense!
Thanks to all-
glen matejcek
