Garmin 296/396 losing location
Goto page Previous  1, 2
d-burton(at)comcast.net
PostPosted: Sun Jan 20, 2008 1:48 pm    Post subject: Garmin 296/396 losing location Reply with quote
I guess the question is how long did Lowrance consider the life of the Airmap to be? We replace these all the time in medical equipment and computer products. They don’t last the lifetime we expect out of the equipment… There are different types of lithium batteries and some last longer then others. I think 10 years would be about it. If you start with 100 of these, at the end of the “average” life 50 are dead, and some will be dead much sooner then average. I just changed a back-up battery in a 286 computer that had been working for more then 20 years. The iMac batteries can fail in 2 sometimes.
It wouldn’t surprise me too much if replacing the backup battery did not cure this problem, but given what Garmin’s flat rate is it may be worth trying. I would.
DaveB
From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Ron Lee
Sent: Sunday, January 20, 2008 10:07 AM
To: rv-list(at)matronics.com
Subject: Re: Garmin 296/396 losing location
I found this in the Lowrance Airmap 500 manual (page 11)
"Flash memory and an internal lithium battery will keep your stored
data safe and accessible for the life of the product."
ceengland(at)bellsouth.ne
PostPosted: Sun Jan 20, 2008 2:29 pm    Post subject: Garmin 296/396 losing location Reply with quote
Can't speak for the 396, but the III Pilot warns when the internal
backup battery gets low & warns every time you turn it on after it's too
low to sustain the memory while powered off.
You're not that far from DC. With all the tricks the military can play
with GPS, I wouldn't be surprised about anything going wrong up in your
area. Have you compared notes with others up there to see if theirs
displays the same symptoms if turned off the same length of time on the
same days?
Charlie
Bill Boyd wrote:
Good thought. Any problem with opening these things up for user service
(besides warranty, which I'm way beyond) - like a nitrogen-filled case
to mitigate condensation, that might be ruined?
-Stormy
On Jan 19, 2008 10:54 PM, Bob J. <rocketbob(at)gmail.com
<mailto:rocketbob(at)gmail.com>> wrote:
I don't know about the 396 but I had the same problem with a Garmin
GPS III Pilot. There is a coin size battery which is epoxied to the
inside of the case with leads going to the circuit board. This
battery keeps the real time clock powered when the main batteries
are discharged. My battery went bad and every time the GPS was
powered down it would lose track of the almanac, even though I had
fresh AA batteries in it. I didn't look at the board to see how the
coin battery is charged but I found a replacement and fixed mine. I
suspect the 396 also has an internal coin-sized battery for the RTC
and yours is probably dead also.
Bob Japundza
RV-6 flying F1 under const.
On Jan 18, 2008 6:36 PM, Greg Young <gyoung(at)cs-sol.com
<mailto:gyoung(at)cs-sol.com>> wrote:
I hope your 296 doesn't keep going south like my 396. My 396
loses it's location almost every weekend - for sure if I miss a
weekend flying. It takes 5-10 min to find itself if I tell it to
use a new location - but at least it's still useable. I've
talked to Garmin tech support a couple times and their drill is
to get the latest software update and to purge the satellite
almanac. Power up while holding the zoom out key for ~12 sec
will flush the almanac (at least for the 396) and then leave it
on in the open for 30-45 minutes to download a new one. That has
not cured my problem so they tell me the next step is to send it
in for the $350 flat rate repair... aaarrggghhh!
Greg Young
<mailto:owner-rv-list-server(at)matronics.com>
<mailto:owner-rv-list-server(at)matronics.com>] *On Behalf Of
*Bill Boyd
*Sent:* Friday, January 18, 2008 4:13 PM
*To:* rv-list(at)matronics.com <mailto:rv-list(at)matronics.com>
*Subject:* Re: APRS tracking technology as
alternative to SPOT
Replying to my own post, here- too many things wrong with
the flight so I stood down. Garmin 296 wouldn't lock onto
more than 2 birds, and thought the local time was 11:36 AM,
so it acts like the internal battery is going south (flown
as recently as last week) - but the unit powers up fine on
the bench using just its own battery, as I write this.
Directional control on the snow was awful, even though there
was lots of grass showing - just too much cover. I think I
packed the wheel pants with snow in short order. I couldn't
even hold brakes against a 1600 rpm run-up without sliding.
When I was about 50% beyond my normal rotation point and
still hadn't broken ground, weaving like a taildragger pilot
in a crosswind (gulp!) I balked the takeoff. Barely had
enough braking action to execute a 180 within the width of
the strip.
This is disappointing, since I wanted to fly tonight and
wanted to demo the APRS, but I guess I get an "A" for
decision making. Even if I had had hull coverage I don't
think I could have felt good about completing that takeoff,
knowing I'd have to return to that same runway in a few
minutes and try to stop safely, possibly with frozen brake
pads. The weather is supposed to turn here tonight, so that
was probably my one window to fly for the next week or two.
Snow expected again tomorrow and a deep freeze on top of
that. Should stay mushy out there till about April even if
the snow dissipates. Some days are like that.
I'll post a heads-up if /when I try the airborne APRS
again. Meanwhile I'm going to have harsh words with my 296.
-Stormy
ronlee(at)pcisys.net
PostPosted: Sun Jan 20, 2008 5:52 pm    Post subject: Garmin 296/396 losing location Reply with quote
Dave, it would appear that if you power up the GPS unit and the date/time is way off then suspecting
a bad internal battery would be my first choice. However, without an obvious way to replace that
battery in the GPS units I have, a flat rate of $300-400 to replace a battery seems outrageous.
Ron Lee
brian.kraut(at)engalt.com
PostPosted: Mon Jan 21, 2008 7:35 am    Post subject: Garmin 296/396 losing location Reply with quote
I have opened my 396 with no problems. It has been a while and I don't remember if there was a battery in there or not.
I used work in the marine electronics industry and with those products Lowrance was the only one that had nitrogen filled cases. Don't know if they ever did that on their aviation units or not. Would probably be way overkill. I have been in lots and lots of pieces of marine electronics and those with well designed enclosures (15 years ago they were few and far between, but now nearly all have watertight enclosures) would not get internal corrosion problems even around a salt water environment without any other special protection.
If you are really anal about the ultimate in protection put in a cortec VpCI-101 vapor corrosion inhibitor which can be found at http://www.cortecvci.com/Products/products.php?showonly=Electric or a small package of silica gel, but I wouldn't bother unless I was using my GPS on a float equipped open cockpit ultralight off of salt water.
Brian Kraut
Engineering Alternatives, Inc.
www.engalt.com [quote] --
steveadams
PostPosted: Mon Jan 21, 2008 10:22 am    Post subject: Re: Garmin 296/396 losing location Reply with quote
I have had the same issue with my 396 for the past 6 months or so whenever it has been inactive for a few days. I found that when it can't find the satellites, it gives you a screen with options like "start simulator" and "stored without battery." When I select "stored without battery", it almost immediately starts locking onto satellites normally. My unit is barely 18 months old and the battery should not be going bad already.
Steve
Page 2 of 2
