norriedh
Joined: 22 Jun 2006 Posts: 6 Location: Calgary, Canada
Posted: Mon Jan 21, 2008 8:55 pm Post subject: Firewall Boot for sealing Rudder Rods 701 |
Would appreciate suggestions for the firewall boots to seal the rudder rods on 701/Savannah. I followed up on Ben Haas's recommendation of the 2001 Yamaha Mountain Max snowmobile boots and bought them online at TEam Alpine in USA, but found them quite heavy and likely too stiff for our Canadian winter. Have searched all local auto part stores etc but havent found a substitute.
Just had a new suggestion from another list--- the Rakboot from Products That Work -- and this looks really good --- has anyone here tried them?
I was hoping to find one of those thin silicone boots as they remain flexible in the cold but so far havent found one.
Douglas N
victorbravo(at)sbcglobal. Guest
Posted: Tue Jan 22, 2008 12:51 am Post subject: Firewall Boot for sealing Rudder Rods 701 |
Sailplane pilot to the rescue !!! Make a conical "boot" out of
rubberized or weatherized ripstop nylon. The stuff they make tent floors
out of, or the stuff they make fabric inflatable boats out of. We used
to use these as pushrod seals on racing gliders and they worked great.
Measure the perimeter of the opening on the firewall. Add 3 inches. That
will be the large end of the seal, the extra 3 inches is to be able to
open out the "base" so it can be glued or mounted to the firewall.
Then measure the length of the nosewheel steering rod. That will be the
height of the cone.
Then draw a triangle on a piece of the weatherproof fabric using those
dimensions. Make the two long legs equal length, not a "right triangle".
At the small end of the triangle make it about an inch thick instead of
coming to a point. Carry that extra inch all the way back to the base.
That extra inch wide strip on the side is important. Cut out the fabric
into the shape of the piece.
Fold the triangular piece of fabric in half like a taco shell, with the
fold line running along the long axis (you will then have a narrower
"right triangle"), Have somebody sew the edges of the long side together
about halfan inch in from the edge. Sew it two or three times, using
heavy thread.
Open up the piece into a cone shape, then turn this cone inside out so
the sewn seam is inside. Slide the boot over the pushrod and glue the
base to the firewall using hi-temp silicone.Clamp the forward end of the
boot to the middle of the steering pushrod using cable ties (Ty-Rap) or
safety wire.
Do a function check to make sure the boot does not interfere with full
rudder travel, etc.
Thanks to Rick Wagner and Larry Lichina, the two guys who installed this
type of seal boot on my racing gliders a million years ago. RIP,
Lichina. Wagner get your S**T together.
Bill the New Guy
norriedh wrote:
n801bh(at)netzero.com Guest
Posted: Tue Jan 22, 2008 5:51 am Post subject: Firewall Boot for sealing Rudder Rods 701 |
I fly my 801 all the time in -25 f weather. Never had a bit of problem with them being stiff. I will go to the local dealer today and get a boot and put it on a scale.but my guess is they weigh 5-8 oz at the most.
Ben Haas
N801BH
www.haaspowerair.com
-- "norriedh" <norried(at)shaw.ca> wrote:
--> Zenith-List message posted by: "norriedh" <norried(at)shaw.ca>
Douglas N
http://forums.matronics.com/viewtopic.php?p=159695#15================================================================================================================================================ -Matt Dralle========================================
_____________________________________________________________
Click here and get the professional resume help you need.
darrellhaas(at)gmail.com Guest
Posted: Tue Jan 22, 2008 9:54 am Post subject: Firewall Boot for sealing Rudder Rods 701 |
I was told to get a boot that fits over the 4 wheel drive levers in an
older jeep etc. and then split them.
Darrell Haas
601 XL
On 1/21/08, norriedh <norried(at)shaw.ca> wrote:
Douglas N
http://forums.matronics.com/viewtopic.php?p=159695#159695
norriedh
Posted: Tue Jan 22, 2008 7:51 pm Post subject: Re: Firewall Boot for sealing Rudder Rods 701 |
Much appreciation to those who replied! Excellent ideas and I now have several approaches to try out. The "cone shape" from sailplane experience, I know I will use on at least another (different) application.
I think I will also weigh the snowmobile boots --- if they only weigh 8 oz and work in -25 F as Ben Haas says --- then they could really be worth a try -- although i am trying not to add weight if I can.
Thanks again
Douglas N
(do not archive)
