partner14
Posted: Mon Jan 21, 2008 7:32 pm Post subject: Insurance |
I am finishing up my both my RV10 and my pilot license. I am planning on transition training, but I know because I'm a new pilot I'll probably take a beating from the insurance people. Any recommendations?
40636 |
apilot2(at)gmail.com Guest
Posted: Mon Jan 21, 2008 7:59 pm Post subject: Insurance |
See if you can get a check out in 182 or Cherokee 235, with hi-perf
endorsement.
That should help, then get at least 5-10 hours transition training in
RV-10. Ins may dictate the number of hours of dual.
On Jan 21, 2008 8:32 PM, partner14 <building_partner(at)yahoo.com> wrote:
Don A. McDonald
40636
http://forums.matronics.com/viewtopic.php?p=159680#159680
coop85(at)cableone.net Guest
Posted: Mon Jan 21, 2008 8:54 pm Post subject: Insurance |
Don,
I agree with getting a "complex" checkout in hopes that it will lower
the rates, it's also not a bad idea anyway since the RV-10 has a lot going
on inside potentially.
I'd recommend really shopping around. I found significant differences
between quotes (one was twice the rest). I went with AOPA who lined me up
with Falcon Insurance as they had a 'good' price and minimal type
experience. When I first started shopping around I was told I'd get credit
for my RV-6 time, but things changed by the time I was ready to fly.
The only good news to offer is most companies will give you a pretty good
break in the price after the first year, so fly a lot. You can always use
it as an excuse for the high fuel bill that you are preparing for saving on
insurance!
Marcus
gerf(at)gerf.com Guest
Posted: Mon Jan 21, 2008 9:05 pm Post subject: Insurance |
I was in the same situation as you when my 9 first flew - Nation Air came in
with the lowest dollar quote by far.
g
dlm46007(at)cox.net Guest
Posted: Tue Jan 22, 2008 2:47 am Post subject: Insurance |
I believe that what you want is a high performance endorsement from a CFI.
Secondly don't even ask AVEMCO; Their quoted was double the lowest I found.
Tim Olson
Posted: Tue Jan 22, 2008 6:46 am Post subject: Insurance |
Not sure how much time you have until your RV-10 flies,
but you'll do well to get over the 100 hour point, and
the best thing you can do for yourself is to get your
instrument rating right away. It will keep your skills up
from the private pilot, and it will move them right into the
next level and give you some great knowledge. It will also
build hours very quickly, and force you to get over that
100 hour mark. If you have an instrument rating, they
may have lower hours requirements for insurance. If you
by some stroke of luck could get 200 hours and the instrument
rating, you'd be sitting very good. Oh, and some time in
that process, make sure to get a HP signoff.
partner14 wrote:
recommendations?
-------- Don A. McDonald 40636
Posted: Tue Jan 22, 2008 7:01 am Post subject: Insurance |
The correct endorsement is "high performance" unless you are building
the prototype RV-10RG. Complex refers to tucking wheels as well as
controllable prop and flaps.
On Jan 21, 2008 9:49 PM, Marcus Cooper <coop85(at)cableone.net> wrote:
Don,
insurance!
Marcus
GRANSCOTT(at)aol.com Guest
Posted: Tue Jan 22, 2008 7:52 am Post subject: Insurance |
In a message dated 1/22/2008 9:05:22 AM Central Standard Time, apilot2(at)gmail.com writes:
| Quote: | The correct endorsement is "high performance" unless you are building
And having a motor that's over 200+hp with a controllable pitch prop= High Performance...which is why many planes such as Mooney 201, Cessna Cardinals with the larger IO-360 are not High Performance aircraft...many have controllable prop's but the IO-360 many be rated only at 200hp thus not being over 200hp they do not comply with the requirement for High Performance.
Another way to get your rates a little lower is to obtain an IFR rating as soon as possible beyond you Private rating...adding Commercial may lower your rates even further. More safe flying hours, plus advanced rating and hull value and type aircraft generally make up the rate you will receive.
I don't believe that Falcon is an Insurance company...rather it is a brokerage company and they then will contact Insurance companies to get you quotes on your coverage...additionally they will also need to be a registered in your state before they can offer insurance for your policy...or something complicated like that.
P
Start the year off right. Easy ways to stay in shape in the new year.
Tim Olson
Posted: Tue Jan 22, 2008 9:18 am Post subject: Insurance |
As an addition to the Insurance topic, I just got a call from
NationAir after yesterday faxing them my numbers from my
pilot and airplane times. This year, like last year, my rate
dropped about $300. Last year I used the drop to take my
hull coverage up a bit, so it was a wash. This year though,
I'm leaving it as a decrease. It's just nice to know that
all the time I'm putting on has been moving me up the
scales for discounts.
So, get your HP endorsement, get your Instrument Rating, and
don't be shy about spending money on fuel, and that will
get you cheaper insurance. Of course, to get that discount,
I spent probably $6-8,000 on fuel last year. But, what good
is an RV-10 if it just sits in a hangar. You can buy much
cheaper planes that will give you nearly identical enjoyment
if you just want to park it in a hangar.
This year, I think I'll possibly get my commercial rating,
just to see if that helps a little too.
GRANSCOTT(at)aol.com wrote:
| Quote: | In a message dated 1/22/2008 9:05:22 AM Central Standard Time,
will receive.
P
Posted: Tue Jan 22, 2008 9:23 am Post subject: Insurance |
Oh, and some time in that process, make sure to get a HP signoff.
wouldn't getting the transition training with Alex or Mike get one this
signoff? I would think it would be wise for most to get the training as a
good step to that first flight.
Pascal
Tim Olson
Posted: Tue Jan 22, 2008 9:47 am Post subject: Insurance |
Yes, you should be able to get the HP signoff from Alex or
Mike, if you don't get it before then. The most important
thing is the signoff, but all of your HP time, and other
"special" sorts of time you have, may also qualify you for
better insurance rates too, so if you're renting, and can
rent a HP plane, you may actually benefit from that rental
choice too. Just don't forget to get the signoff, one way
or the other, because you'll definitely want HP endorsement
for the RV-10...unless you do something drastically different
in engine choices. Anyone want to try out that Rotax
that got advertized a couple days ago?
a good step to that first flight.
Pascal
Posted: Tue Jan 22, 2008 10:00 am Post subject: Insurance |
In a message dated 1/22/2008 11:27:03 AM Central Standard Time, rv10builder(at)verizon.net writes:
| Quote: | wouldn't getting the transition training with Alex or Mike get one this
signoff? |
I don't think this is automatic, you would need to inform the CFI that you're requesting this instruction and sign off and then perform the tasks required to get the sign off...not very complicated but you'll need to get instruction then the sign off. I don't believe there is a set hours on either HP or complex but just the sign off by the CFI.
One thing additionally you may want to question from your carrier is if you complete a formal training course on your aircraft or some other type of course could you receive a discount to your rate...such as the FAA's Wings course and follow up instruction with a CFI (part of your transition training) or a recognised course such as the Cessna FITS course...Mooney other courses set up by their associations. Sometimes these course cost is more than justify by the discount you'll receive.
I know this is pretty obvious but genreally, the largest portions of your insurance cost is the hull's value you list...certainly if you're a low time pilot with a fresh IFR to boot in an expensive high performance aircraft; your insurance will be pretty high the first couple of years and should decrease as you gain experience and additional ratings.
I understand that it pretty typical for some Cirrus pilots to be paying up to $5k or more for policies on the SR22, while a pilot of similar experience in a Dakota would only pay $1.5k. Happened to one of my original partners in our 235...went from that to a PA 28-300 then on to the SR 22...he additionally had more experience and rates by the time be bought into the 22 but with the accidents rates the pool is shark infested.
P
Tim Olson
Posted: Tue Jan 22, 2008 10:25 am Post subject: Insurance |
Actually, wasn't it just a couple years ago that brand-new
Cirrus insurance was costing some people $10K, and only
recently did they get some big drop in rates? I'm sure
that all still depends on the pilot qualifications, but
I thought the rates on 400-500K of hull were in that
10K range previously.
| Quote: | In a message dated 1/22/2008 11:27:03 AM Central Standard Time,
signoff?
P
<http://body.aol.com/fitness/winter-exercise?NCID=aolcmp00300000002489>
in the new year.
rene(at)felker.com Guest
Posted: Tue Jan 22, 2008 11:11 am Post subject: Insurance |
Just an idea to throw out.....bring on the flames. One way of building time
would be to find someone working on their instrument rating or just doing
practice approaches and fly with them. You must be able to act as pilot in
command for the aircraft being flown, but you can log the PIC time. Also,
you will get the benefit of learning a lot about practice approaches, holds,
etc.....actual IFR...not so much.
Rene' Felker
N423CF
40322
801-721-6080
Tim Olson
Posted: Tue Jan 22, 2008 11:40 am Post subject: Insurance |
You can't really use that to actually build time, because
you aren't PIC. Now, if you were the sole manipulator
of the controls, while the other guy was the PIC, that
might not be totally the case, but, what good is the
instrument approach practice to that guy if you're
the one solely manipulating the controls of the plane.
And, you can't log PIC time if you're a non-certified
pilot hauling passengers who are non-instructors.
Otherwise people wouldn't bother to fly the time to
get their rating...they'd just manipulate the controls
while a buddy pilot acts as the true PIC. I'm not
saying it's not of any benefit, but really, the only way
to honestly and legitimately build loggable time is to
go out and do the flying. Also, read this last month's
AOPA article by that legal column guy and find out how
the NTSB/FAA takes it when the right-seat pilot is
manipulating the controls. It got kind of spooky how
suddenly you assume the role as PIC and could end up
being "in charge" if there is any sort of incident.
What you want to add, if possible, is true, loggable PIC
time, to help with insurance rates. But, you're 100% right
that from a standpoint of getting yourself some IFR related
education, it would be fantastic to go along and fly with
someone doing their instrument rating....it may help when
it comes time to plan your panel. If you're going to do
that though, you may as well finish the Private Pilot, and
at least finish and pass the written for the Instrument
rating. You don't even need to take ground school to
take and pass the written, and there's a heck of a lot
of good info there.
Rene' Felker
N423CF
40322
801-721-6080
Posted: Tue Jan 22, 2008 12:15 pm Post subject: Insurance |
Just for clarification......
1. Pilot not flying, right seat guy/gal must be rated and current in the
aircraft to fly as safety pilot.
2. Pilot not flying, assumes PIC for a portion (while pilot flying is under
the hood) of the flight.
3. Both pilots can log time.
It is just a way to build a little time at little or no expense.
Also, pilot not flying is a required crew member ...........
I fly a lot with other pilots and always make sure that we agree on who is
PIC and who is not.....even with my instructor.
Rene' Felker
N423CF
40322
801-721-6080
Posted: Tue Jan 22, 2008 1:12 pm Post subject: Insurance |
In a message dated 1/22/2008 1:15:13 PM Central Standard Time, rene(at)felker.com writes:
| Quote: | | but you can log the PIC time. |
Rene,
Pretty sure you can log the time but not as PIC unless you're a CFI/I giving instruction to a student...
P
Posted: Tue Jan 22, 2008 1:38 pm Post subject: Insurance |
In a message dated 1/22/2008 2:17:46 PM Central Standard Time, rene(at)felker.com writes:
| Quote: | Just for clarification......
Rene',
You may want to take a look at FAR 61.51...PIC is the pilot flying the plane (the sole manipulator of the controls) while the other person is a "safety pilot" and not PIC unless 61.51(e) (3)..."an authorized insturctor may log as PIC time all flight time while acting as an authorized instructor"..."PIC time for a pilot is only when you are the sole manipulator of the controls for which the pilot is rated or has priveleges"...if you act as Safety Pilot and you are not manipulator of the controls you're not PIC...the pilot flying under the "hood" is PIC, you can log time but not PIC time, unless you are the CFI/I.
Your point on required crew member is only true if the aircraft you are operating is covered by 61.55 and this covers how the aircraft is certificated not the operation you're performing..I really don't think to many part 91 aircraft have a second in command (required crew member per operation certificate) requirement...
I don't think it says anywhere that the person acting as safety pilot needs to be current or have a current medical for that matter either just that they have to be rated for category and class.
If you and your mates are logging PIC time incorrectly, well that's your matter. But you may want to re-read the regulation and discuss it with a member from the FSDO or a master CFI/I...IMHO
Patrick
Posted: Tue Jan 22, 2008 1:59 pm Post subject: Insurance |
In a message dated 1/22/2008 3:41:14 PM Central Standard Time, GRANSCOTT(at)aol.com writes:
| Quote: | It is just a way to build a little time at little or no expense.
I'm sure you take the "safety pilot" as a serious position and keep a healthy scan going...if you read through the NTSB accident reports...note how many accidents occur to CFI's and pilots out practicing IFR conditions. It's more than one thinks...
P
