Engine Breather Fitting Change?
ericparlow(at)hotmail.com
PostPosted: Tue Jan 22, 2008 2:01 pm    Post subject: Engine Breather Fitting Change? Reply with quote
Does Van's in the FFw kit recommend changing the breather hose nipple fitting from the 3/4" fitting that was supplied with the engine to a 1/2" fitting?
ERic--
RV-10 40014
N104EP
jesse(at)saintaviation.co
PostPosted: Wed Jan 23, 2008 6:52 am    Post subject: Engine Breather Fitting Change? Reply with quote
Eric,
I haven't heard of any recommended change. The breather tube that comes with the FWF kit fits the same size hose as fits on all breather fittings on the engines I have used. The only time I have seen a reduction needed is when an air-oil separator is being used.
In answer to your question, I don't think so.
Jesse Saint
Saint Aviation, Inc.
Cell: 352-427-0285
Fax: 815-377-3694
ERic--
RV-10 40014
N104EP
wcurtis(at)nerv10.com
PostPosted: Wed Jan 23, 2008 9:15 am    Post subject: Engine Breather Fitting Change? Reply with quote
Nope, no change required. My only issue is that with the angled oil filter adapter on my TMX-IO-540 engine, the breather tube is too close to the oil filter. At best it will just touch the oil filter, at worst, it will make the oil filter difficult to remove. I'm in the process of re-positioning it. Aircraft spruce has the six foot length of 1" X 0.035" 5052 aluminum tube for $20. Now I need a 1" tube bender. Pre bent breather tube from Vans is $49.
William
http://wcurtis.nerv10.com/
"Be who you are and say what you feel because those who mind don't matter and those who matter don't mind."
-- Dr. Suess
pitts_pilot(at)bellsouth.
PostPosted: Wed Jan 23, 2008 1:13 pm    Post subject: Engine Breather Fitting Change? Reply with quote
Hit up your local electrician or a rental supply place and get a 1" conduit hickey. Should work just fine. But, be aware ..... I haven't done it!!!
Linn
William Curtis wrote:
[quote] [quote]--> RV10-List message posted by: "William Curtis" <wcurtis(at)nerv10.com> (wcurtis(at)nerv10.com) Nope, no change required. My only issue is that with the angled oil filter adapter on my TMX-IO-540 engine, the breather tube is too close to the oil filter. At best it will just touch the oil filter, at worst, it will make the oil filter difficult to remove. I'm in the process of re-positioning it. Aircraft spruce has the six foot length of 1" X 0.035" 5052 aluminum tube for $20. Now I need a 1" tube bender. Pre bent breather tube from Vans is $49. William http://wcurtis.nerv10.com/ "Be who you are and say what you feel because those who mind don't matter and those who matter don't mind." -- Dr. Suess ------
PostPosted: Wed Jan 23, 2008 2:14 pm    Post subject: Engine Breather Fitting Change? Reply with quote
William,
I have used the TMXIO-540 twice and have not had a problem with the angle adapter and the breather. Are you sure you have the breather in the right place? I don't want to insult your intelligence, so I could be missing something obvious, but I have never had an issue with that. Do you have a picture?
Jesse Saint
Cell: 352-427-0285
Fax: 815-377-3694
On Jan 23, 2008, at 4:08 PM, linn Walters wrote:
[quote] Hit up your local electrician or a rental supply place and get a 1" conduit hickey. Should work just fine. But, be aware ..... I haven't done it!!!
Linn
PostPosted: Wed Jan 23, 2008 7:53 pm    Post subject: Engine Breather Fitting Change? Reply with quote
Yeah, well I thought about that but threre is only one way to mount it. Picture attached.
William
 Filesize:  75.37 KB
 Viewed:  347 Time(s)
PostPosted: Thu Jan 24, 2008 5:38 am    Post subject: Engine Breather Fitting Change? Reply with quote
I remember what I did now. I wanted any oil that came out to hit the
exhaust stack in hopes that some or most of it would burn instead of
getting on the belly, so I swiveled the breather tube towards the
pilot's left which did that and gave more clearance to the oil filter.
I hope this helps.
Jesse Saint
jesse(at)saintaviation.com
Cell: 352-427-0285
Fax: 815-377-3694
On Jan 23, 2008, at 10:58 PM, William Curtis wrote:
[quote] Yeah, well I thought about that but threre is only one way to mount
William
