jindoguy(at)gmail.com Guest
Posted: Wed Jan 23, 2008 4:57 am Post subject: Dead Stick Approaches ( Holes in the sky) |
Tom, all, I don't think we're beating a dead horse. The discussion is forcing me to think the problem through and not just regurgitate what I learned in pilot training. What Einstein called a gedunken (sp?), a thought experiment. It's winter, bitterly cold outside here on the plains, the DAR is coming Friday afternoon, there is little left to do other than a few minor tweaks, and this is interesting.
From a physics of flight standpoint there is no such thing as unaccelerated flight. In straight and level, constant speed flight the acceleration forces are in balance. Lift equals weight and drag equals thrust. For all reasonable purposes, weight, the result of the local gravitational field acting on the mass of the aircraft, is the only constant of the four and its acceleration vector never changes, it is always toward the center of the earth. In turning flight the aircraft's inertia wants to keep it going straight, and gravity keeps accelerating the aircraft downward. Lift must counteract both. Wish though I might, there is no free lunch. You've added a new acceleration force, inertia, to the mix thereby disturbing the equilibrium. You've also changed the acceleration vector of the lift. It no longer directly opposes the gravity vector. The effect of inertia is to make the aircraft seem to weigh more. More weight requires more lift. More weight also means the aircraft's stall speed increases. Lift varies at the square of the speed. Speed must increase to keep whatever margin above stall speed you find acceptably safe.
Of course, one good test beats a thousand theoretical arguments. All that would be required is a recording accelerometer and a sensitive GPS.
Rick
On Jan 23, 2008 1:19 AM, possums < possums(at)bellsouth.net (possums(at)bellsouth.net)> wrote:
[quote]--> Kolb-List message posted by: possums < possums(at)bellsouth.net (possums(at)bellsouth.net)>
At 12:43 AM 1/23/2008, you wrote:
I should show you guys what you can do with the engine off & vg's &
no one watching.
But - I would get in trouble---------I'm legal now after 24 yrs.
Like they say in the song. "Dance like no one is watching".
I've got a one-seater - and an "iPod" tied into my helmet. = the many List utilities such as List Un/Subscription, w.matronics.com/Navigator?Kolb-List" target="_blank">http://www.matronics.com/Navigator?Kolb-List tp://forums.matronics.com" target="_blank"> = - List Contribution Web Site ; -Matt Dralle, List Admin. =======
Posted: Wed Jan 23, 2008 6:42 am Post subject: Dead Stick Approaches ( Holes in the sky) |
Morning Gang:
Got a G Meter and a GPS.
If I can get a flight in between rain showers, I'll fly over to Wetumpka Airport and shoot some dead stick landings to the north/south grass strip.
What are you guys looking for? Maintaining 1G during a dead stick approach while performing 180 deg turns?
I'll see what I can do.
I need to fly anyhow. I have a 400 rpm mag drop on one side. Talked to Ronnie Smith about it yesterday. He told me to double check to insure the throttle lever clevis's are lubed and free, where they attach to the throttle cables. Told me this can cause a mag drop by getting the carbs out of sync/balance. My first thought was spark plugs. I have a set to stick in if the throttle lube does not cure my mag drop. Never had this problem before, but there is always a first time.
Eric Tucker will be at Ronnie's tomorrow. Rotax classes begin Friday. Ronnie will coordinate a time for me to fly down to replace the gears in my 912ULS. If Eric can fit it in, he will incorporate my gear change with that portion of the 912 course.
Take care,
[quote] Of course, one good test beats a thousand theoretical arguments. All that would be required is a recording accelerometer and a sensitive GPS.
Rick
_________________ John Hauck
Titus, Alabama |
Posted: Wed Jan 23, 2008 8:37 am Post subject: Dead Stick Approaches ( Holes in the sky) |
John, Could your throttle cables have stretched or changed in such a way that your carbs got out of synch?
Rick
On Jan 23, 2008 8:39 AM, John Hauck < jhauck(at)elmore.rr.com (jhauck(at)elmore.rr.com)> wrote:
[quote] Morning Gang:
Take care,
Quote: | Of course, one good test beats a thousand theoretical arguments. All that would be required is a recording accelerometer and a sensitive GPS.
Rick
Posted: Wed Jan 23, 2008 8:49 am Post subject: Dead Stick Approaches ( Holes in the sky) |
Rick:
I doubt it, but anything is possible when Murphy is there to help.
I have put over 2500 hours on three 912 engines. Until this last engine, never synchronized the carbs with gauges. This is the first occurrence of a mag drop I have experienced, unless I had a plug trying to foul. Then, the problem was solved by some good hard running of the 912.
Rick
Titus, Alabama |
Dana
Posted: Wed Jan 23, 2008 9:48 am Post subject: Dead Stick Approaches ( Holes in the sky) |
At 12:43 AM 1/23/2008, The Kuffels wrote:
Quote: | ...Keep your speed constant, it keeps your total load constant and keeps
your stall margin constant. We are talking about 90 or 180 degree turns
here. In theory your decent rate will continue to increase at constant
airspeed in a bank. In practice the increased vertical component of drag
slows the increase in decent rate and things remain nicely stable on rollout...
If you roll into a bank and AND keep it coordinated (ball in center), then
you have to either pitch up by pulling back on the stick (thus pulling more
than 1g), or you have to yaw toward the bottom of the turn, which means
your nose drops (the plane naturally does this if you don't pull back on
the stick to keep the nose up). Thus you'll accelerate down and pick up
speed, since the drag doesn't increase that much (except as a function of
speed). Either way, in a bank at least one of three things MUST
happen: You pull more than 1g, or you're flying uncoordinated (slipping),
or your speed increases.
I do agree with what I presume was your original point, that you avoid an
accelerated stall by letting the nose drop and the aircraft accelerate...
though this is probably more effective in a slow draggy airplane like an
ultralight than a faster, cleaner GA plane.
Later, of course, you have to exceed 1g pulling out of the resultant dive.
-Dana
Televangelists: The Pro Wrestlers of religion.
Dana
Posted: Wed Jan 23, 2008 10:09 am Post subject: Dead Stick Approaches ( Holes in the sky) |
At 07:55 AM 1/23/2008, Richard Girard wrote:
Quote: | From a physics of flight standpoint there is no such thing as
You're confusing force and acceleration. The _forces_ are in balance, and
thus the _acceleration_ is zero.
Quote: | In turning flight the aircraft's inertia wants to keep it going
Inertia isn't really a force (although it can sometimes be treated as such
depending on your frame of reference).
In turning flight at a constant altitude, the lift vector is no longer
vertical (due to the bank). Lift must increase so that the vertical
component of lift is still equal to the force from gravity. The horizontal
component of lift is unbalanced, so it causes an _acceleraton_ to the side
(F=MA), causing the turn. This acceleration, multiplied by the mass of the
aircraft, is what you're terming inertia (the plane "wanting" to keep going
straight).
I realize this is basic, you clearly understand it despite incorrect
terminology, but in physics (and aerodynamics!) it's important to use exact
terminology.
To maintain 1g in a banked turn, the aircraft must accelerate downward as a
result of the reduced vertical component of lift, _and_ accelerate to the
inside of the turn according to the horizontal component of lift. The
result is a steepening spiral dive, which, over the course of a 180° turn,
may or may not develop to alarming speeds or pitch angles.
-Dana
Posted: Wed Jan 23, 2008 12:08 pm Post subject: Dead Stick Approaches ( Holes in the sky) |
Quote: | >...Keep your speed constant, it keeps your total load constant and keeps
>rollout...
Tom K
Quote: | accelerated stall by letting the nose drop and the aircraft accelerate...
-Dana
Dana:
You need to get out and fly a little. It did wonders for me. The computer
monitor is no substitute for some good old fashioned aviating.
I landed about 15 minutes ago after practicing gliding to touch down at idle
power and also dead stick. While gliding, I also practiced left and right
turns of 90 and 180 degrees, keeping my airspeed constant (well.........as
best I could ).
Results, 1 G all the way to the ground. Hard to get into an accelerated
stall at 1 G. Hard to stall a Kolb, unless you violate the minimum stall
speed.
mkIII - Still got a mag drop, even though I oiled up the throttle cable
clevis's at the carb throttle levers. Next, replace the spark plugs Travis
sent me yesterday. I might have gotten some heat sink paste too far down on
one or more of the plugs when I recently replaced them.
Titus, Alabama |
JetPilot
Posted: Wed Jan 23, 2008 12:20 pm Post subject: Re: Dead Stick Approaches ( Holes in the sky) |
jindoguy(at)gmail.com wrote: |
[b] |
This is what I have been saying all along. If you turn, you MUST generate more than 1 G load on your wings. You either load the plane with 1 G either during the turn, or after the turn to arrest the resulting dive, or both. But, as I said before, you don't get something for nothing. It takes force to turn a moving airplane, and that force is generated by the wings.
What is happening is that some guys are flying it so smoothly, that they don't realize that they are putting more than 1 G on the wings, but realize it or not, they are... Its a physical law that no amount of good piloting is going to break. Most likely they are putting some extra load on the wing, not much, but some during the turn, and again more than 1 G load while pulling out while leveling off, they just don't realize it.
What Tom suggested is good piloting and very good technique, if I was writing about it, I would not say you never put more than 1 G load on the wing, because it is just plain wrong. Teach your technique, but get the theory correct also when you teach it... It will be more credible and make for much happier readers It will also save embarrassment when pilots that are familiar with flight physics read your article.
Mike
Kolb MK-III Xtra, 912-S |
JetPilot
Posted: Wed Jan 23, 2008 12:24 pm Post subject: Re: Dead Stick Approaches ( Holes in the sky) |
[quote="Possums"]At 12:43 AM 1/23/2008, you wrote:
no one watching.
Now you have done it, I gotta see this !!! Just put the video on YouTube and post the link here
Mike
Posted: Wed Jan 23, 2008 12:44 pm Post subject: Dead Stick Approaches ( Holes in the sky) |
Quote: | This is what I have been saying all along. If you turn, you MUST generate
wings.
Mike
Mike B:
Read my last post reference gliding and turning pulling 1g. I just flew it.
No big deal. Keep the air speed constant and the turns will remain at 1g.
Sorry to disagree. Yes, I have a certified Accelerometer installed in my
mkIII. Rate of descent remained constant as long as I kept the air speed
contant.
I don't think Tom Kuffle has anything to be embarassed about. Maybe you
need to do some homework before you tell somebody else they are full of
crap.
Take care,
mkIII - Super 1g glider guy!
Titus, Alabama |
Dana
Posted: Wed Jan 23, 2008 3:06 pm Post subject: Dead Stick Approaches ( Holes in the sky) |
At 03:05 PM 1/23/2008, John Hauck wrote:
Quote: | You need to get out and fly a little. It did wonders for me. The
computer monitor is no substitute for some good old fashioned aviating.
You're right, I do! Just too damn cold here, right now.
Quote: | I landed about 15 minutes ago after practicing gliding to touch down at
idle power and also dead stick. While gliding, I also practiced left and
right turns of 90 and 180 degrees, keeping my airspeed constant
(well.........as best I could ).
speed.
John, how sensitive is your G meter? In a 30° banked turn you only pull
1.15g; 20° only 1.06g. And how much bank, and were all turns coordinated?
I'll stick with Mike here; no amount of good piloting can break the laws of
physics. An object moving along a curved path experiences acceleration in
the plane of the curve, perpendicular to the direction of motion. The
vector sum of that acceleration and the 1g downward pull of gravity is the
total g's you're pulling, so unless you push the nose down to reduce the
vertical 1g, that vector sum will be greater than 1.0... and if you push
the nose down you won't maintain that constant speed. It is impossible to
make a coordinated turn at a constant velocity in an airplane while
maintaining only 1g, unless you have some means to continuously increase
drag (or decrease thrust) as the airplane pitches down... and even then you
will see more than 1g pulling out of the resultant dive. TANSTAAFL (There
Ain't No Such Thing As A Free Lunch).
I _will_ believe it's possible (in a shallow bank), within the accuracy of
the instruments installed on most aircraft.
-Dana
It feels great to wake up and not know what day it is, doesn't it?
Posted: Wed Jan 23, 2008 3:41 pm Post subject: Dead Stick Approaches ( Holes in the sky) |
Quote: | >Results, 1 G all the way to the ground. Hard to get into an accelerated
>speed.
Quote: | I _will_ believe it's possible (in a shallow bank), within the accuracy of
-Dana
Dana:
My accelerometer is as accurate and sensitive enough to get a yellow tag.
Most folks that know me and my flying style will tell you me and Miss P'fer
don't know what a 20 and 30 degree bank are. We fly, and have a hell of a
lot of fun doing it. I can assure you my banks were well over 45 degrees
because it takes that and much more to to nice tight 90 and 180 degree turns
at 60 mph in a mkIII. If I made the turn and maintained altitude, it pulled
a g. If I maintained 60 mph until I touched down, I never pulled more than
1 g.
I just got back from doing some more maintenance and test flying. What a
beautiful day to fly. Calm air, 48F on the ground and 40F at 3,000. Makes
no difference whether you believe me or not. The mkIII still glides and
turns at 1g with constant airspeed. To be honest, I would not have believed
it entirely either, until I did it this morning.
Guess you'll just have to go out and do this exercise yourself to see what
the results are. I'd be glad to demonstrate if you are in the area.
Take care and watch your g meter.
Titus, Alabama |
kuffel(at)cyberport.net Guest
Posted: Wed Jan 23, 2008 5:43 pm Post subject: Dead Stick Approaches ( Holes in the sky) |
Dana,
<< The vector sum of that acceleration and the 1g downward pull
of gravity is the total g's you're pulling, so unless you push
the nose down to reduce the vertical 1g, that vector sum will be
greater than 1.0. >>
But we aren't keeping a vertical 1g. At constant airspeed and
level flight we are keeping 1g on the wings. Now rotate the
wings. The 1g load vector rotates with the wing to produce 2
components. One horizontal to produce the turning acceleration
and a correspondingly lower vertical to oppose (partly) earth's
gravity. Which is of course why we start descending more rapidly.
The point remains if you maintain a constant airspeed while
maneuvering to land you will never reduce your stall margin (+/-
the secondary effect of increasing and decreasing your decent
rate). This is most important in the 90 degree turn to final
where every year pilots try to hasten the turn with rudder. In
the 180 reversing turns on a dead stick approaches (remember dead
stick approaches, this is a thread about dead stick approaches)
it doesn't matter where you roll out left or right so just use a
constant shallow bank and constant airspeed. This is good habit
building practice for the 90 turn to final where you might want
to tighten the turn by increasing the bank angle without fear.
Tom Kuffel
Whitefish, MT
Building Original FireStar
Dana
Posted: Wed Jan 23, 2008 7:10 pm Post subject: Dead Stick Approaches ( Holes in the sky) |
At 08:40 PM 1/23/2008, The Kuffels wrote:
Quote: |
<< The vector sum of that acceleration and the 1g downward pull of gravity
is the total g's you're pulling, so unless you push the nose down to
reduce the vertical 1g, that vector sum will be greater than 1.0. >>
But we aren't keeping a vertical 1g. At constant airspeed and level
flight we are keeping 1g on the wings. Now rotate the wings. The 1g load
vector rotates with the wing to produce 2 components. One horizontal to
produce the turning acceleration and a correspondingly lower vertical to
oppose (partly) earth's gravity. Which is of course why we start
Right, you start accelerating downward if the vertical component is less
than 1g.
Quote: | The point remains if you maintain a constant airspeed while maneuvering to
land you will never reduce your stall margin...
That's the part I have a problem with, if you're accelerating downward your
airspeed won't be constant. Since you're _accelerating_ downward your
descent rate will continue to increase, as will your airspeed. The only
way to keep the speed from increasing is to slip the plane, which adds a
whole new set of variables.
A good example is the second half of a wingover (or the last quarter of a
standard Lazy- . At the highest point in the wingover, you're banked,
say, 45°, the ball is centered, pulling 1g or maybe even less, but you are
accelerating downward since the vertical component of lift is greater than
the airplane's weight. But the pullout at the bottom will be greater than
1g, since the wings then are both supporting the aircraft's weight but also
providing the force to accelerate the plane upward to slow the increased
descent rate.
But again, I agree as a matter of good technique: Let the nose drop in the
turn, which lets the plane speed up a bit while simultaneously reducing the
load factor.
Hmmm, just thought of something: In a pusher like a Kolb the instruments
(including John Hauck's g-meter) are well forward of the C.G., unlike a
conventional tractor plane. A g-meter mounted forward of the aircraft's
C.G. will show less than the actual g's while the aircraft is pitching
downward (just as a g-meter mounted on the tail would show a _greater_
reading). Not sure how significant (if at all) that would be, though.
-Dana
The secret of the universe is (at)*^^^ NO CARRIER
Posted: Wed Jan 23, 2008 7:29 pm Post subject: Dead Stick Approaches ( Holes in the sky) |
Quote: | (including John Hauck's g-meter) are well forward of the C.G., unlike a
-Dana
Dana:
When the aircraft is flying at 1g, in a glide, it is not pitching if the
airspeed is held constant.
I flew the maneuvers many times on two seperate flights today.
Based on the g meter and my own flying experience, I am quite satisfied the
turns were done without loading the aircraft to more than 1 g.
Guess the only way to convince you is take you for a ride.
Damn! The g meter is on the wrong side of the cg. (scratching my head)
Titus, Alabama |
lcottrell
Posted: Wed Jan 23, 2008 8:18 pm Post subject: Dead Stick Approaches ( Holes in the sky) |
Posted: Wed Jan 23, 2008 10:48 pm Post subject: Dead Stick Approaches ( Holes in the sky) |
Dana,
<< Since you're _accelerating_ downward your descent rate will
continue to increase, as will your airspeed. >>
Taint so on the second part. Your decent rate will increase
slightly until the vertical component of your drag cancels the
loss of vertical lift (if you turn long enough). But your
airspeed is your velocity forward, almost orthogonal to vertical.
In non-aerobatic flight it is a simple matter to adjust your
airspeed and accept the resulting descent rate.
And I say again, your vertical accelerations are a secondary
effect. Even a 500 feet/min descent is less than 1 percent of
your forward velocity at 60 mph. And a change in descent rate
from 250 to 500 ft/min is a change in your vertical velocity of
less than 3 mph. This is well within the ability of any pilot to
compensate as he maintains constant *forward* airspeed.
High-g pullout examples don't apply here because they involve
large changes in airspeed, power or vertical speed.
Go try it for yourself. In a simulated turn to final, holding
constant airspeed results in a 1g maneuver no matter what bank
angle (within reason, say 60 degrees).
Tom Kuffel
Whitefish, MT
Dana
Posted: Thu Jan 24, 2008 4:21 am Post subject: Dead Stick Approaches ( Holes in the sky) |
At 10:26 PM 1/23/2008, John Hauck wrote:
Quote: | When the aircraft is flying at 1g, in a glide, it is not pitching if the
It is if it's in a banked turn. (It pitches relative to its own lateral
axis, not relative to the horizon).
-Dana
Starve a feeding bureaucrat...vote Libertarian.
Dana
At 01:45 AM 1/24/2008, The Kuffels wrote:
Quote: | << Since you're _accelerating_ downward your descent rate will continue to
Taint so on the second part. Your decent rate will increase slightly
until the vertical component of your drag cancels the loss of vertical
lift (if you turn long enough)...
What causes this additional vertical component of drag?
-Dana
Rex Rodebush
Joined: 10 Jan 2006 Posts: 209 Location: Branson West area, Missouri
Posted: Thu Jan 24, 2008 5:35 am Post subject: Re: Dead Stick Approaches ( Holes in the sky) |
It's been awhile but I'll add my 2 cents worth.
Anytime you change directions you produce acceleration. It may not be much or enough to feel or register but it's there. Whether it's on a merry-go-round or on a bike going around a corner. If you're sitting in a centrifuge and are going around at 1 rpm you will still have slightly over 1 g on you as it is a function of radius and rpm squared. Even though your speed is constant your direction vector is changing.
Rex Rodebush
